Remove these ads by
Signing Up
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Fitting into the copper cap was a little tricky, especially keeping bolt heads clear of lenses - I had to file down the bolt head and particularly the nut. I'm running a 10xNiCad 1800mAh C-cell pack (i.e. 1.8 Amp hours total), which does indeed give well over an hour, and fits nicely into a bottle cage. When the voltage drops too low for both in series (they dim considerably), it's easy to switch to a single bright beam with plenty of further time left. Saved huge amounts thanks to supply by a friend who services medical equipment!, but finding a charger for a 10 cell NiCad pack was harder (ebay).
Future upgrade would be to use NiMH or LiPo to reduce the weight.
My pictures on Flickr http://www.flickr.com/photos/49238647@N07/sets/72157623837257712/ - I've also added a bit more silicone sealant since then.
Top tips - don't pre-test LEDs without a heatsink - one lens came unstuck; drilling caps without a vice is painful...
4 x AA NiMh batteries with >= 3000mAh should get you the 3-4 hours.
You can see his original instructions here:
http://www.racedaynutrition.com/features/bikelight.aspx
