3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bright Luxeon LED Bike Light
This instructable describes the construction of a bike light comprising three 3W Luxeon LEDs. This project had three main goals. 1.) Make a light suitable for use in 24-hour mountain bike racing. 2.) Use readily available material as much as possible. 3.) Offer the details to the community and invite any and all comments. I originally published this project at this site: http://www.racedaynutrition.com/features/bikelight.aspx
Step 1Basic Hardware
Basic Hardware
Pictured here are some of the basic hardware items required for this project. On the left is a 5W halogen light from a VistaLite system (ca. 2000) from which the handlebar mount will be salvaged. At top are radio controlled helicopter motor or "280" size motor heatsinks. The other items follow the goal of using readily available material: 3/4" copper plumbing caps, 1" corner irons, and a 2" long binder clip. See Step #3 for a parts list.
53 comments
1-40 of 53next »
Sep 27, 2010. 11:00 PMamdivoff says:
if that is your garage im totally jealous! so much space,half of mine is taken up by boxes:(
Aug 24, 2010. 3:10 PMs3ntinel says:
Awesome design - I based my 2 light design from this, plus a 3-pole 4-way rotary switch allows for wide, narrow, wide+narrow in parallel, wide+narrow in series (super bright off-road only - traffic will flash!)
Fitting into the copper cap was a little tricky, especially keeping bolt heads clear of lenses - I had to file down the bolt head and particularly the nut. I'm running a 10xNiCad 1800mAh C-cell pack (i.e. 1.8 Amp hours total), which does indeed give well over an hour, and fits nicely into a bottle cage. When the voltage drops too low for both in series (they dim considerably), it's easy to switch to a single bright beam with plenty of further time left. Saved huge amounts thanks to supply by a friend who services medical equipment!, but finding a charger for a 10 cell NiCad pack was harder (ebay).
Future upgrade would be to use NiMH or LiPo to reduce the weight.
My pictures on Flickr http://www.flickr.com/photos/49238647@N07/sets/72157623837257712/ - I've also added a bit more silicone sealant since then.
Top tips - don't pre-test LEDs without a heatsink - one lens came unstuck; drilling caps without a vice is painful...
Apr 12, 2010. 3:43 PMelinventor21 says:
 and u might want to make the leds weather proof maybe some type of protector and clear silicone or something just as idea
Apr 12, 2010. 1:31 PMelinventor21 says:
wouldn't i be able to use a micro puckbuck per led?
Mar 14, 2010. 12:52 AMJayvis Vineet Gonsalves says:
I too have the same 15 degree lens but I don't undrestand how to open the lens? Could you please help me out.
Aug 11, 2009. 9:03 PMmarc92 says:
I'm hoping to build something similar to this, and I have a few questions. Because I would like to use a bike dynamo (at 6v, 3w, 500mA) to power this, I am unsure how to safely configure my 2009 Minipuck converter for maximum efficiency. It would be powering a single 1W Luxeon white LED. Can anybody help me out?
Oct 6, 2009. 4:19 PMbiolethal says:
you probably want to add a voltage/current regulator in there (and while you are at it a battery or a supercapacitor), because the minipuck probably cant handle the current and voltage from the dynamo when, for example, you are going down a hill. even if it has the ability to take a vareity of input voltages, just to be safe i would put a regulator in there.
Aug 14, 2009. 8:00 PMmarc92 says:
Moreover, does the 2009A know what voltage to supply the LED's with, or is it a function of the input voltage? None of the documents I have read said anything regarding this.
Sep 18, 2009. 2:34 AMrodeobob says:
If you use a centre punch to mark the holes and pilot drill with a (sharp) 1/8 or smaller drill bit you should be able to reproduce the holes accurately. Use an offcut of bar stock or pipe that the cap slips over mounted in a vice as an anvil.
Nov 24, 2008. 5:49 PMslindblom says:
This is brilliant. I'm very tempted to build this, but I'm wondering if you could give some tips on how to set up the battery pack suitable for riding ~3-4 hours. Thanks!!!!
Aug 21, 2009. 10:15 PMpablosartor says:
I made this light and run it off a 4.8v battery. made up of four AA NIMH. This lasts me about 1hr with the three heads going. I just finished making a battery pack eith 4 times the amount of batteries (still 4.8v). This should go for over 4 hrs easy.
Aug 21, 2009. 10:09 PMpablosartor says:
just made your light. It is amazing. good work. Drilling the clip is insane, drilled my finger twice. It was worth the pain THANKS!!!!
Mar 26, 2009. 12:44 PMelinventor21 says:
what did you use to power all of this?
Mar 23, 2009. 7:01 AMneuromonkey says:
Would someone post the total parts cost for this project? I'm searching the listed sites for the parts, but it's taking a while to find them all. Poor or no search functions!
its all going to mount up to about $110
Feb 9, 2009. 11:06 AMkrapez says:
I ordered from ledsupply.com and payed with mastercard... all done in few seconds... all OK. For shipment i used Fedex expres... 3 days and package was in my country in Europe.
Nov 29, 2008. 9:17 PMlordofthedonuts says:
I just oredred from ledsupply.com, don't pay with paypal, i ordered and they didn't redirect me to the paypal website to confirm with my password and username, I'm waiting for them to send me an email about my unpaid (or sohuld I say un-payable) order. If you don't mind paying by credit card, do so, it will save you a lot of trouble.
Nov 30, 2008. 1:24 AMQuackMasterDan says:
I ordered from them and got the same problem, upon e-mailing them about the issue, they informed me to go the paypal.com and send a payment to orders@ledsupply.com for the total amount of my order. My order has already shipped and should be here soon. Hope that helps.
Nov 30, 2008. 11:54 AMlordofthedonuts says:
thanks, I thought they were going to emial me, but it's probably better to be proactive.
Nov 20, 2008. 1:21 PMlfryling says:
Any idea of roughly what you spent on this project? I've got some old BLTs that I could refurbish. I think it would be alot brighter with your system.
Nov 14, 2008. 11:08 AMArnie1066 says:
NIce instructable, i might try this, but with lower power LED's. I'm not convinced your circuit diagram is correct though, it looks like your taking the +ve side of your supply voltage to the negative side of the LED's Is this a typo or something peculiar to these specific lights? ie normal LED wiring... (+) --|>|-- (-) sorry cant draw it better :)
Nov 16, 2008. 8:24 PMpanstar1 says:
very good work ! there are drill bits that can drill through the metal clip ease ,it was called cobalt bit I had bought it for a few dollars. It takes the hassel of drilling through hard metals or a cement bit could work also. I used for drilling through some stainless steel ,very good stainless steel when i was making a knife a while back. the stainless I was using came from a band saw blade which was from a lumber mill. They had to use a plasma cutter just to cut the blade up , a oxy acet torch was not even hot enough !!!
Nov 15, 2008. 5:24 PMnelelr says:
this is a dumb question. But can u use this technology to make a light for a car or truck heaDlight or wouldn't it go far enough?
Nov 13, 2008. 4:48 PMdll932 says:
Nice instructable, thanks! One thing I might add: acid core solder is for pipes and fenders. Rosin core is safer for electronics.
Nov 13, 2008. 5:32 PMSpokehedz says:
Agreed. Your connections will likely fail as the water in the air combines with the acid to form pits on your copper. Or, you could clean it up with some alcohol. Oh lovely alcohol, is there anything you cannot do?
Nov 14, 2008. 1:41 PMdll932 says:
It is always good to preclean before soldering, but the function of flux is to help conduct heat and to keep air out, so there's no oxidation.
Nov 15, 2008. 8:01 AMSpokehedz says:
Not exactly, DLL. But very close. Flux is there to help prevent oxidation that is formed when the metals in the solder and wire and/or circuit traces heat up. It also cleans off any oxidation already present on any of those materials when the actual soldering is taking place. And it also is a mild degreaser which cleans off the oils your fingers put onto the wire to allow solder to stick. I used to do a demonstration when I was teaching kids how to solder by taking a wire and cutting it in half. Stripping the ends off with a set of wire strippers, and then twisting the wires with my fingers in both hands. On one, I simply tried to solder wire straight to them. It would stick in some places, but not in others. That is the oil burning, and turning into carbon--which nothing will stick to. On the other, I would wipe a quick swipe of a flux pen--and the solder would stick perfectly. A lesson that they all could see, and they used flux ever since. For all my soldering work, I always wash my hands with a very strong soap--getting as much oil off as I can, so that it will transfer onto my projects as little as possible. But I am paranoid like that. :P
Nov 15, 2008. 4:30 PMdll932 says:
Well put-I stand corrected.
Nov 15, 2008. 4:19 PMchalky says:
NOTHING SHORT OF GENIUS! You could actually make and sell these little baby's,i for one would buy one:)
Nov 14, 2008. 11:33 AMHoochamajigger says:
Be careful when applying arctic silver adhesive to electrical components, it is not electrically neutral. For a thermal epoxy that is electrically neutral and much cheaper, try Arctic Alumina adhesive from the same company.
Nov 13, 2008. 1:45 PMjmengel says:
kwschofi- Hey, nice light. It looks like great minds think alike. I spent some time recently in the plumbing section of my hardware store and came up with the same 3/4" pipe caps for holding a LED star board. I wrote up an Instructable on the experience as well. In my case I used 3 Luxeon Rebels on a single star and enclosed the buck puck. Do you find that the heat sinks on your light get hot? Have you run the lights without the heat sinks? Did you glue the heat sinks to the copper or otherwise provide a thermal compound to fill any voids? I really wish there was some more fin area on those RC motor heat sinks. Thanks for sharing your project!
Nov 9, 2008. 2:38 AMomnibot says:
Cool build. I noticed you have two wires from each LED, couldn't one be connected to common ground?
Nov 8, 2008. 11:55 PMprofpat says:
Great work! now i have some ideas for my mountain bike head light projects, my present led array head light is not bright enough...thanks..
Nov 7, 2008. 6:12 AMmdj817 says:
At this point, it seems like you're more blinding the drivers than letting them know you're there :-D
Nov 8, 2008. 6:14 PMTwoShort says:
It is considerably more light than you need to let motorists know you're there. It is even more light than you need for seeing where you are going on pavement. The intro mentions 24hr mountain bike races; an environment in which there probably isn't anything that is too much light if you want to carry the batteries.
Nov 7, 2008. 7:10 AMjeff-o says:
Nah, not even close. At a total 240 lumens, you're not even close to the 1000+ lumens produced by a car's headlights.
1-40 of 53next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:kwschofi(racedaynutrition.com)
