Bring Dead Ni-Cad Batteries Back To Life by Plasmana
Contest Winner
Step 5: Add the battery holder an the switch
Then we need to solder the battery holder and the high power switch together with the black capacitor.
Solder the black wire of the battery holder to the lead of the capacitor that is the closest to the grey stripe.
Solder a piece of wire to the other lead of the capacitor.
Then solder the push-button switch to the red wire of the battery holder and the other wire.
Also, the battery holder you just added, that is where you put the dead Ni-Cad battery to zap them.
techno guy says: Apr 13, 2011. 6:56 PM
So the negative of the cap goes to the negative of the battery and same with positive?
chriskarr says: Nov 30, 2008. 5:29 PM
So I take it the stripe on capacitors means that it is the negative lead?
russtang says: Dec 4, 2008. 1:40 PM
On electrolytic capacitors (usually tubular can shaped) the stripe denotes the negative side. On most, if not all Tantalum caps (usually yellow, rectangular with brown stripe , the stripe marks the positive side.
Plasmana (author) says: Dec 1, 2008. 4:02 PM
yes.
chriskarr says: Dec 1, 2008. 4:07 PM
I thought so, but I wasn't 100% on that. Thank you.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
