Introduction: Bring New Life to Your Keyboard
Picture of Bring New Life to Your Keyboard
In this tutorial I will show you how to paint your keyboard with a normal coat of paint and some detail word work (also how to disable your sleep button). This might take up to a week or weekend (did all of this over a weekend and a week because I lost one of the weekend days so painting was held up) so have another keyboard.
Cost: about $20 with tax (for paint and paint brush)
Also I'm not held accountable if anything happens to your keyboard such as your warranty voiding for the keyboard (which it will or I'm pretty sure it will)
Step 1: Materials
Picture of Materials
Pictured:
-Any colour you want of Krylon Fusion paint for plastic (or any other bonding plastic paint Krylon's is just common and easy to find)
-Some sort of Clear coat (I picked Krylon Clear Glaze it allowed me every 1 coat it would be like 3)
-Detail work paint (I went with Delta`s white)
-Tape
-Pencil
-Paint brush (this one was too big so i went even smaller)
-Craft blade (and maybe an exacto knife if your craft knife is dull)
-Cutting Board (my mom's scrapbooking one did well :D)
Not Pictured:
-Word work paint brush
-Paper
-Decent sized cardboard to cover key holes
-possibly sandpaper (i used due to me messing up)
-Small Screwdriver
Step 2: Planning
Picture of Planning
Draw a plan for your keyboard and try to put as much detail as possible also its a good idea to write where certain keys go such as scroll lock, prt screen, home, delete, pause break because they are different for almost every keyboard (or whole keyboard if you do not have another it use as a template)
Note:that i didn't have my keyboard here so i draw without reference but I knew my keyboard pretty well so I did my best.
Step 3: Getting the Frame Ready Part 1
Picture of Getting the Frame Ready Part 1
Remove the keys with a screwdriver to start by pulling out one then pull out the rest in each section with your hands (safer). Also watch out for the keys with the metal bars under all longer keys have these to they stay level with the rest of the keyboard keep these bars and be careful not to break the connections under it (little plastic holds) its sometime hard to break them so don't worry. Also note that on some keyboards like mine have unremoveable keys. I put all the keys in a cup and put it somewhere safe.(Pictures 1&3)
Next flip it over and remove the screws with the screwdriver. My keyboard had 16 screws and two different sizes. I also Put these screws in a cup and into a safe place. (Pictures 2&3)
Flip it the right side up and remove the top (should come right of but be careful you may have missed a screw) (Picture 4)
Extra: Have a sleep key? want to disable that annoying thing? Just cut the little white board (or dark gray) piece that pushes down about half way down(were it gets smaller to bigger cut the smaller part off) with sissors. Make sure you pinpoint exactly where it is so you don't disable the wrong key. (Picture 4)
Step 4: Getting the Frame Ready Part 2
Picture of Getting the Frame Ready Part 2
Mark were you are going to cut the cardboard to cover the keyholes. For each area do this. Make sure they are tight but not too tight . (I remade this after the first coat my cardboard cover was much better and without tape in the middle). Pizza boxes work very well tape pieces together if needed.
Step 5: Painting Time
Picture of Painting Time
I'll keep it short and sweet
Cover your face and only spray outside, spray in quick little short squirts (same with clear), wait an hour in between coats with Krylon (except the clear wait 2 hours). I had up to 7 coats of red paint. and 6 coats of clear which i only sprayed 2. For detail paint slowly and if you mess up wipe off with an old damp towel, but I suggest practicing first. The first picture is after the second coat and the second picture is after the seventh coat. Third first coat of detail work. Fourth second clear coat
Step 6: Finished
Picture of Finished
Put the frame back on, screw it in, pop the keys back in and you are finished your newly painted keyboard for about $20.
finfan7 (author)2008-10-22
I think I will be doing this but I will be using a technique to make it look like steel. And I will probably do something with the keys too. The just seem to monotone.
Canadarocker (author)finfan72008-10-22
Sounds cool and I didn't do the keys because I don't type completely by touch.. and you should still take off the keys and paint them on the side unless you want to stick or you want to have to sand parts of it down
Treknology (author)Canadarocker2010-04-05
 I've modded plastic stuff like this before, and have two advantages.
First is access to a bead-blaster (far less harsh than a sand-blaster) to roughen up the plastic for the paint.
Second is access to a computer engraver. You can engrave the letters into the keytop and then paint them. When dry, you give them a wipe with a contrasting paint to collect in the engraving.
finfan7 (author)Canadarocker2008-10-22
I was thinking something like putting tape across the tops of all the keys, trimming excess with the exacto and then hitting em with a misted spray to give each key a kind of faded border.
Canadarocker (author)finfan72008-10-23
I see sounds like it will work good luck
Lance Mt. (author)Canadarocker2009-05-15
does sound cool
obj126 (author)2009-11-03
 check it out i did mine today. i did both keyboard and mouse.
gvince4 (author)2009-10-08
Looks great. Why do you need to cover the back with cardboard?
"G"
Canadarocker (author)gvince42009-10-10
You do it so your keys don't stick becuase of the paint in between where the key hits the actual slicon button
Kaiven (author)2009-10-10
Yours looks nice! Maybe I should mod mine...
SG1Oniell (author)2009-03-12
I'm thinking jet black with midnight blue highlights and blue leds
agis68 (author)2009-03-05
Very nice and clean job...what about to paint it with wood paint to make a fake wooden keyboard? 5/5
santy22 (author)agis682009-03-07
wood paint? im not sure if that exists....
agis68 (author)santy222009-03-08
exist for sure check google for it.....check here>>>>>>>
http://www.fauxfinishhowto.com/Faux_Wood_Graining.html
About This Instructable
13,095views
34favorites
License:
More by Canadarocker:Bring New Life To Your Keyboard
Add instructable to:
