Bring Your Music to Light! With LED Color Organ
Published
Introduction: Bring Your Music to Light! With LED Color Organ
Brighten up your favorite tunes with colored flashing LEDs! Ultra bright 5mm LEDs, red, blue, and yellow, respond to bass, middle, and treble frequencies for a dazzling audio/ visual show.
Watch it in action here!
If you want to build your own LED Color Organ there is a kit with a customized PCB, already labeled with all component placements.
Finally, check out the Jameco Workshop for full instructional video and helpful tips for the build.
Step 1: ICs U1 and U2
Take note of the orientation of the ICs and IC sockets by looking at the notch and matching the notch of the IC to the notch of the PCB.
Step 2: Diodes D1, D2, D3
The correct configuration of the diodes is shown below.  Pay attention to the stripe on one end of the diode indicating the cathode end.
Step 3: Transistors Q1, Q2, Q3
Polarities of the Bipolar Junction Transistors (BJTs) are extremely important. Here, we use the 2N3904, 3-pin package. Match the component to the symbol in the image above.
Step 4: Resistor Color Code (Non-Polarized)
R1, R2, R3, R16, R17: 1kΩ (Brown, Black, Red)
R4, R5, R6: 560k1kΩ (Green, Blue, Yellow)
R7, R8, R9: 6801kΩ (Blue, Gray, Brown)
R10, R11, R12: 39k1kΩ (Orange, White, Orange)
R13, R14, R15, R27, R28: 100k1kΩ (Brown, Black, Yellow)
R20, R21: 1601kΩ (Brown, Blue, Brown)
R18, R19: 4701kΩ (Yellow, Violet, Brown)
R22: 1M1kΩ (Brown, Black, Green)
R23: 47k1kΩ (Yellow, Violet, Orange)
R24, R25, R26: 20k1kΩ (Red, Black, Orange)
Step 5: Capacitors
C1 through C7, C15 non-polarized capacitors.
C1, C2 0.0022µF
C3, C4: 0.01µF
C5, C6: 0.047µF
C7, C15: 0.1µF
C8 through C14: These electrolytic are polarized with the negative side (shorter lead) indicated by a strip on one side, see image.
C8, C9, C10: 2.2µF
C11: 2.2µF
C12, C14: 4.7µ6µF
C13: 22µF
Step 6: LEDs
D4, D5, D6, D7: Yellow (represents the Treble)
D8, D9, D10, D11: Red (represents the Mids)
D12, D13, D14, D15: Blue (represents the Bass)
Be sure to have the cathode end (shorter lead) facing the side with the flat edge. See image.
Step 7: Audio Jack and Power Jack U4, U5
There is only one way to insert each of these components into the board, so just be sure to apply enough solder to ensure a good connection with each tab.
    • Oil Contest
      Oil Contest
    • Planter Challenge
      Planter Challenge
    • Casting Contest
      Casting Contest
    Note to Beginners Who are Interested in this Build:
    • Test the kit on the breadboard before soldering—it’s easy to get confused if you never soldered a circuit before.
    • If you never soldered before, don’t start this project a week before it’s due (if you’re doing this for a class)
    • This kit is a great transitional kit for beginners who want to build an analog LED organ circuit before building one with arduino/flora
    • On the image sample of the audio jack, “ground” refers to “channel”
