iImage Information
I use a backpack when I commute to meetings on my bicycle. A few days ago I stooped down to pick up something and the extra stress on the backpack straps caused the plastic ladder lock buckle to snap. The rest of the backpack is in good condition. Backpacks are only one item that uses nylon straps with adjustable buckles.
This Instructable will provide two solutions to a broken ladder lock buckle. One is for those who can weld and one for those who cannot. The welded version will show how to make your own ladder lock buckles. The non-welded version will show you how to use "D" rings, either those you purchase or those you fashion yourself.
If you make the "D" ring version, you will need "D" rings you purchase and a hacksaw or a Dremel tool with a cutting wheel.
If you make the ladder lock buckle version, you will need a hacksaw, a grinder, a vise, a hammer, and a wire feed welder.
Step 1Stitching
iImage Information
I wanted to fix my backpack without cutting the stitching on any of the nylon straps. My wife says it is not difficult to make new stitches. But, I am trying to avoid that and leave the original stitching undisturbed. That means I will make a ladder lock buckle that begins by feeding part of it through the nylon strap loop sewn to the backpack. Shown is the beginning of the welded version. The next steps will describe using "D" rings for the non-welded version. Then I will explain how to make the welded ladder lock buckle. The ladder lock buckle will be easy to release with one finger. The "D" ring, non-welded version will be easier for most people to manufacture at home, even if a little more difficult to release.
Worst case: While in Georgia [U.S.A.] I had an occurance of one or both of my own Dogs being upset with me and chewing through 3 of the 4 seat belts. Coat hanger, rivits, hammer, pliers, screwdriver, and a propane torch got us back on the road safely, in just a few hours.
Nice job with the welding!
http://www.uscargocontrol.com/Rigging-Supplies-Hardware/Anchor-Bow-Chain-and-D-Shackles
Bodging things is definitely an important life skill!
For those of you who do not have a welder, metal buckles are available from various suppliers. Here is one here:
http://www.ohiotravelbag.com/FlipBook/hardware%20catalog%20p210/index.html?pageNumber=163
I threw out a backpack I'd had for years after I trod on the buckle while overseas and broke it. If I'd thought of the 2 D-ring approach I could have been up and running again quickly.
It wasn't an expensive backpack and I have others so it wasn't a great loss. Still irritating though.
Thank-you for a great idea.
I am also someone who soldered my daughters cracked metal tip on her cowboy boots back together. And I LOVE those popular mechanics issues! esp vintage/antique articles. I've met my match in you! This is exactly like something I WOULD DO!! LOL! Good stuff Phil. I feel less alone! :D
One step closer to unbreakable backpack.
It is a shame the amount of money we spend on cool backpacks that break at the least opportune moment.
http://www.speedystitcher.com/
A manly sewing awl.
They're slow and it takes practise to make a neat job, as with any manual skill., but they definitely work.
I like the D-ring solution, too. Works great on helmets, you get used to them.
If I had a welder, I would always be on the lookout for reasons to use it! This is yet another clever solution (2, really) from Phil B.
I went for many decades without a welder and am very grateful to have one now. If you have not seen it, check my Instructable on Learning to Weld, especially Step 19 on some ways to make your own stick welder with "junk" parts. By applying the method in this Instructable, it would be possible to use a stick welder and some 1/16 inch electrodes to make the ladder lock buckle shown here.
It is sad to watch, but in recent months monetary inflation has done terrible things to the price of welders.
One suggestion: when you need to make bends at an angle more or less closed on a heavy rod, you can do with the grinder a recess in either the inner or outer of the angle. This greatly facilitates the work, and usually requires no further strengthen it. In this case, yes, because that buckle makes a bit of force. A touch of welding is generally enough.
