Brook One Piece Mask
3,688
34
8
Published
Introduction: Brook One Piece Mask
I love the characters of One Piece manga so I built this mask for my son,
I modified with a 3D software character brooke then I imported into the software pepakura and have created the parts, then I printed the pdf (which I have attached, if you use it as a source mentioned this instructable)
Step 1: Print and Cut
materials:
A4 paper for printer
cutters and scissors
glue
polyurethane /epoxy resin
putty
sandpaper acrylic paint
Print the pdf on cardboard, cut and paste parts with glue PVA.
Step 2: Resin
When the glue has hardened,
externally coated with resin,
when the resin is hardened,
strengthen internally with paper mache,
Step 3: Teeth
add teeth white foam following the design in pdf
Step 4: Futty
putty externally to round sides and finish with sandpaper, then fill it again and smooth.
Now paint the outside with acrylic enamel.
behind the eye sockets I put blacks cylinder of foam to deepen the look, then I attached two elastic blacks to wear it.
before wearing the mask wearing a black balaclava and sunglasses blacks then wear an Afro wig and brook is ready to play.
Step 5: Brook Is Redy
Good luck and have fun.
    • Stick It! Contest
      Stick It! Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    8 Comments
    Hi, you are really talented!! Brook is my favourite one piece character and I love your work! I can't read the file, could you send me the pdf? Thanks ?
    https://cdn.instructables.com/ORIG/FJH/U65A/IFGNPLTZ/FJHU65AIFGNPLTZ.pdf
    good luck
    Hello ! Very impressive! I realy like your work ! Can you give me the file pdo (some number's can't be read) tank you !! :)
    I haven't heard of this manga, but this mask looks super good! The costume looks great all together too!
    tx , but really do not know one piece? is the best-selling manga shoen with 320 million copies, 803 chapters since 1997 and still in progress, is in the Guinness Book of Records, and has a anime among the most viewed and theme parks in Japan
    hi can you put the pepakura too please on the pdf some numbers can't be read thx
    http://onepiece.wikia.com/wiki/Brook
