3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Brown Puffed Rice Treats (aka Rice Krispies Treats)
If you're usually a healthy eater the idea of inhaling marshmallows mixed with butter and Rice Krispies may take a leap of faith.
Hence I decided to embark on the Caramelized Brown Butter Rice Krispies Treats recipe published in the New York Times. But wait is this an original instructable? Yes I used BROWN puffed rice cereal instead of the white Rice Krispies type. The result is a heartier and I'd-like-to-pretend healthier version.
Takes about 15 minutes total.
Original NY Times recipe: http://www.nytimes.com/2007/10/31/dining/311hrex.html
INGREDIENTS
8 ounces butter, salted or unsalted
1 10.5-ounce bag large or small marshmallows
10 oz puffed brown rice cereal (I used Erewon brand which has a 10 oz box)
sea salt (or regular salt but sea salt is yummy)
Parchment paper for the pan, or extra butter to butter it if you don't have paper
PAN: You can do whatever you want with the result. As you can see here in addition to spreading it across a thick layer in a 9x12 pan, we had enough to make balls. Making balls is almost more fun than boring old squares! Especially if you have child labor helping you. They'll love it.
Step 1Melt the butter & marshmallows
In a large pot, melt butter over medium-low heat. It will melt, then foam, then turn clear golden and finally start to turn brown and smell nutty. Watch closely and stir often.
If it's foaming a lot turn the heat down so it doesn't suddenly burn.
When butter is evenly browned, stir in marshmallows and salt if your butter isn't salted.
Melt and cook, stirring often, until mixture turns pale brown, then stir constantly until lightly browned but not dark, 3 to 5 minutes.
At a minimum make sure the marshmallows are all melted. If it starts sticking to the bottom of the pan it's probably a good time to stop.
2 comments
Aug 2, 2009. 11:57 PMCyberscann54 says:
I once made them with fruity pebbles super sugar rush do not feed to kids inside must be done outdoors if you like your home.
Jan 12, 2009. 11:19 PMporcupinemamma says:
I like your ideas. Thanks!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:susie(Susie)
My LED (I mean flashlight) Gummies profile photo is inspired by the LED Throwies.
