3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bubble Speakers
Bubble Speakers
Need a new pair of speakers? Got a pair of old head phones(not in-ear) and two plastic bubbles from that arcade trip last weekend? If so why not make a pair of bubble speakers?
Step 1Aquisation of Tools and Materials
Materials:
2 Plastic Bubbles(see image below if you don't know what I mean)
An old pair of headphones you don't want anymore(not in-ear)
Tools:
Dremel or other rotary tool
Hot Glue Gun
30 comments
Jan 28, 2010. 12:33 PMTSC says:
nice mp3 player!!
Jan 24, 2010. 1:35 PMTSC says:
nice job!!!!!!!!!!!!! look at this one /www.instructables.com/id/small-speaker/
Sep 28, 2009. 1:06 PMmr monoply33 says:
interesting idea.... probably not much in quality/distance, but to an extent it would work. Its got cosmetic potential.
Jul 18, 2009. 11:53 AMbounty1012 says:
XD I got the same model as you!
Jul 26, 2007. 1:13 AMvisus says:
headphone drivers don't make very loud speakers because they are usually 32 ohm ... without any technicals - higher impedance, less sound, for the most part. you can make louder unpowered speakers with drivers out of toys and old computer cases which are usually 4 and 8 ohm drivers.
Jul 27, 2007. 11:28 AMdrcrash says:
I'd expect that they'd have truly awful bass response as well. Speaker drivers are generally designed to work well in certain kinds of enclosures, and reasonable-sized rooms. The enclosure gives you an effective bass boost just below the plain bass response of the driver, and the "room response" gives you another, lower frequency bass boost below that. IIRC, headphone drivers are designed to work in an incredibly tiny "room"---the space between the headphone and your eardrum, while you're wearing it. They rely heavily on the "room response" being enormous and boosting a much larger range of frequencies than usual. If you use them in a normal room, you won't get that, and they'll be really wimpy. There are a few basic rules of thumb for designing good speakers, which nobody on instructables seems to know. If you want to design a good speaker, get a good book on the subject from the library. (I used to have one, but I've forgotten the name.) It's not difficult to design a much better speaker/enclosure than most of the stuff on instructables. Putting a random driver in a random enclosure is not a good idea. In particular, there's a "Q" factor you should know about. The Q factor tells you what size enclosure to use for a given driver; if you have a port (hole) in the box, it will boost the bass about a half an octave below where the driver's bass response would otherwise tail off. That "bass reflex" scheme is simple and easy and works well---it's just a box with a hole in it---and it's how most speaker enclosures work. You just have to know the Q of the driver, and look up the appropriate enclosure volume in a table. (If the enclosure is the wrong size, it will boost the wrong frequencies and usually make your speaker sound worse.)
May 27, 2009. 3:08 PMtoogers says:
these are like sterio systems, with out woofers and sub-woofers. just tweeters.
Dec 1, 2007. 10:49 PMKaitlinthegreat says:
Nice idea,I'll have to try it :D I have that Sansa too,much better than iPods,a WAY better deal too.
May 27, 2009. 3:06 PMtoogers says:
got mine refurbrished on woot.com for $50
May 22, 2008. 12:42 PMMakerBreaker says:
is that a e250 or e260?
May 27, 2009. 3:05 PMtoogers says:
looks like an e260
Aug 20, 2007. 1:55 AMSofa-King says:
Doing this tomorrow Few issues though 1. Wouldnt the bubble muffle the sound of the speaker? if so, why not add holes... 2. what do you do with a speaker that only puts out as much as one thats mounted to the ear... what would be amazing, would be if you would create a fullsize version of this, it would look great on a desk, on the road, ect... I might make it, who knows In the mean time, great idea, fast, fun, and useful in the end Awesome.
Oct 22, 2008. 7:14 AMPolymorph says:
The reason you can normally only hear tinny sounds from a pair of tiny speakers is because the sound from both sides cancel each other. Nothing stops the air being pushed from one side from meeting the air being pulled by the other side, and so all but the very highest frequencies cancel. The bubble isolates one side of the speaker, allowing the other side to send out sound without being canceled. That's why -any- speaker just sitting there, not in a box or a plate, sounds tinny. Cancellation is worse for the lower frequencies. Try it with your headphones without even tearing them apart. Make a cylinder with your hand and hold one earphone at one end of that cylinder. Or find a cardboard or plastic cylinder that is about the same size as your headphone and put it at one end. Suddenly it is loud and with some low frequencies! I know all this works because I started doing this long, long ago with mousse can tops.
Mar 18, 2008. 1:40 PMn0ukf says:
The bubble is around the back side, creating an acoustic suspension chamber. This actually reinforces certain frequencies based on the volume of the chamber, resonance of the driver (headphone speaker) and other factors (go read about designing speaker cabinets). Holes would make this a ported enclosure which has different dynamics.
Mar 22, 2008. 12:54 PMdz0004455 says:
good idea, i like to do the same thing with altoids boxes!! I also have sansa, but, its sansa view! much better than ipod!
Mar 15, 2008. 5:42 PMgamer says:
i have the same mp3 (e260) i payed 120 +tax, great deal
Nov 11, 2007. 7:37 PMedison142 says:
Wow this is a pretty cool idea. I have a sansa too (so much better then the ipod)
Aug 31, 2007. 6:25 PMjamnoopers says:
i have that player :]
Jul 26, 2007. 1:08 PMjammis says:
cool idea got a video of it in use??
Jul 27, 2007. 4:17 PMmmzdaniel says:
this is a cool idea BTW i have the sansa too lol...
Jul 25, 2007. 3:45 PMBran says:
So the bubble amplifies the sound? If so, pretty ingenious (well, to me, anyway)!
Jul 25, 2007. 3:48 PMTheCheese9921 says:
I don't think it amplifies it, the bubble acts more like (correct me if I'm wrong) acoustics like if a band plays in a concert hall compared to a stadium
Jul 25, 2007. 6:06 PMrobodud3 says:
if you noch a hole in the back as well and take off the blue part on the back the sound may not sound like its playing into a tincan mi sure that how it sounds now am i correct but relly tho just a helpful tip dont take it in a bad way
Jul 25, 2007. 4:04 PMtheRIAA says:
...oh, i get it, its a speaker enclosure. i thought the speakers faced in the bubble for a sec. yes, this should work pretty well it would work better if the enclosures were connected in one.
Jul 25, 2007. 3:43 PMrocketbat says:
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:sardines454
