3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bubble Wrap Calendar
Step 6Stick the bubble wrap down
Next we need to put some double sided tape on the paper to stick the bubble wrap to. This is best done as a two person job so that one person can hold each end and get it lined up just right. Just stick one side at the moment, leaving the top paper on.
Trim then ends of the tape with a craft knife to neaten it up
Lay the bubble wrap back in position on top of the numbers, and roll back the top 6 inches of it when it is perfectly aligned. Remove the top of the double sided tape from the the top 6 inches of the tape, and lay it back down again in the correct position over the exposed tape. When that is perfect, lift the unstuck bubble wrap out of the way, and peel off the rest of the top of the tape.
Working from the stuck end, lay the bubble wrap in the right position on top of the exposed tape. Again, this is easiest with two people.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:millmore
