3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bubble Wrap Storm Window (Insert)
In this instructable I will show you how to make an INDOOR storm window that will keep plenty of cold out of a room, while letting light continue to come in. My version uses less than $4 worth of supplies, mostly from the DOLLAR TREE store.
THE STORY :)
I moved into an apartment on the 3rd floor. all windows were single pane. The building was built in about 1970, so there was poor insulation, and only single pane sliding glass windows.
It was very cold the first night and the pipes nearly froze in the bathroom. the window rattled and I knew I was in trouble.
By creating my bubble wrap storm window, I was able to raise the temperature in the room 15 degrees F in the first hour. As you can imagine the savings and comfort increased rapidly.
As you can see I do have some depth to the window so making this work was kind of easy. I suppose using clear tape , magnets, velcro etc, you might find another way to put a storm window of this type in place.
Step 1Step 1
Step 1
In picture 2 you can see I bought clear tape and 1ft by 6ft rolls of bubble wrap from the Dollar Tree, (where everything is actually $1.00). I then found 2 wire coat hangers and unwound them to make a frame for the project.
I first rolled out two 6ft rolls side by side and taped down the middle. I actually bought 3 rolls, more on that later.
47 comments
1-40 of 47next »
Apr 23, 2012. 4:22 PMJudith756 says:
Check you local Craig's List for free bubble wrap. We have it on ours every week. I actually use the "pool noodles" bought at Dollar Tree for a buck for cheap pipe insulation. Have never had a problem. Just slice it in a spiral, "twist" it on and duct tape a couple of places. Has worked for 8 winters here on my outdoor faucets.
Thanks for the ible.
Nov 8, 2011. 1:51 AMunreal_ed says:
How important is it to cover the window completely?
I've taped it over most of the window but it does not quite cover the edges of the glass (nor does the tape run the length of the wrap's edges). I've also not necessarily taped all the strips of bubble-wrap together along their lengths (I'm doing a lot of windows...)
Your talk of eddy currents is making me worried that not completely covering the glass will make the whole installation pointless. Is this a legitimate/reasonable concern?
Nov 11, 2011. 8:57 AMunreal_ed says:
Thanks for answering!
Also, what if the bubble-wrap does not COMPLETELY cover the whole surface of the window (but almost all of it) but it's is properly sealed along the edges? Is that better, or also pointless?
Nov 6, 2011. 6:59 AMhms1018 says:
I'm in Michigan and this is a sweet idea. Thanks
Nov 4, 2011. 10:16 AMtomas.savage says:
nice. i usually use the specific window insulation made by 3M (clear plastic sheet, two sided tape and hair dryer), but this will probably work better.
Nov 4, 2011. 5:38 PMtomas.savage says:
good info thanks. i have a different problem though, maybe you'll have an idea. i have 3 windows that are nothing but a screen and a swing-away glass pane that close flush with the wall. with the window closed, there is about 3-inches of space between the glass and screen.
a crude 'visual'
[outside] [screen] [3 inches] [window-pane flush with wall] [indoors]
do you think this will work if i place it right up against the screen?
[outside] [screen] [bubblewrap insulation] [2 inches] [window-pane flush with wall] [indoors]
being from michigan, you already know what kind of weather we get out here. i don't know if the bubblewrap can last exposed like that.
Nov 8, 2011. 2:49 AMMaxCrunch says:
Yes it will,
see my answer below, I used it folded over, tape the edges on all three open sides.
Nov 8, 2011. 5:44 AMtomas.savage says:
thanks. my upstairs "studio" gets very cold in the winter due to these badly designed windows and they're not a standard size so replacing them means expensive custom work.
i'll give this bubblewrap a try since it seems to be an easy and inexpensive 'fix'.
Nov 7, 2011. 11:19 PMGiorgiodeste says:
great idea, i have a similar problem ... I'm going to buy materials :-) thanks
Nov 5, 2011. 10:56 AMjbrune says:
Great job, I'm definitely gonna try this on our bathroom and basement windows.
Nov 5, 2011. 5:00 AMbcccool says:
Just to let you know you can use the bubble wrap and be done in 5 minutes with each window and its NO WORK except for measuring the window and cutting the wrap;
I live in Wisconsin and my winters are horrendous, measure windows and cut wrap to fit your window. THE EASY PART,
MUST PUT WATER ON IT AND APPLY THE WRAP. THATS IT! ! ! ! It keeps out the cold radiating from each window. Course you cannot see outside but the light still comes in. Great for bathrooms if you want to keep your neighbors from looking in
Nov 4, 2011. 7:16 AMbri322 says:
This is a really great idea! I think I'll use it on windows we don't really look out: bathroom, basement, closet. YAY. We have old windows, so I might just leave it up year-round. Thanks!
Nov 4, 2011. 8:17 AMrpearse says:
Great idea. Thank you for sharing.
Nov 3, 2011. 8:25 AMsugarandfat says:
I was doing that for a while, but bubblewrap isn't actually the best stuff to use, as the cell size is fairly large, and a lot of the area ends up being single wall. Much better is polyethylene foam wrap, otherwise known as that thin semi translucent stuff they sometimes wrap electronics and stuff in.
This: https://zeorymeromega.files.wordpress.com/2011/08/polyethylene-foam-closeup.jpg
It's the best stuff for insulating pretty much anything, as it's essentially free (can be dug out of a variety of skips in large quantities), very insulative, and with a reasonably high melting point. I tested the last two by putting some over my hand and pouring boiling water on it. Felt slightly warm...
Nov 4, 2011. 3:48 AMsugarandfat says:
Rigidity? We're talking about different stuff (I may have the name wrong).
This material is a mm or two thick and completely flexible.
Nov 3, 2011. 6:35 AMCrispie J says:
This is awesome!! In addition to being simple and cheap, it also looks good - gives the impression of that fancy pebbled glass.
I sure could have used this a few years ago when I lived in a huge house heated by an oil furnace. All of the oddly-sized single pane wood-framed windows had serious leaks. After the first $600 fill-up I shut off the heat to most of the 5 zones in the house and kept the thermostat at 15 degrees C (60 degrees F) all winter (and this is in Canada). I was having "cash flow" problems (all my money was tied up in real estate :p) and I tried (and failed) to come up with a cheap solution to this problem. Ironically I now live in an apartment where I have the opposite problem - heat and hot water are included in my rent. but the place is always so hot that I keep the thermostat off and appreciate the ill-fitting windows.
Nov 3, 2011. 7:55 AMstevepuk says:
Do you have any problems with condensation getting trapped between the bubble wrap and the window?
Nov 3, 2011. 9:23 AMSquee says:
Guys doing the same thing here, they just use water to get the bubble wrap to stick to the windows, no having to make an armature.
http://www.builditsolar.com/Projects/Conservation/bubblewrap.htm
Nov 3, 2011. 2:14 PMTigerMoon says:
Nice! I live in a 41 year old trailer so I know about inadequate insulation! Have been using bubble wrap (the big bubbles) for a couple of years now. I actually like the way it looks too, nice diffuse light and it provides a bit of privacy, tho double layers would work better. Maybe I'll add an extra layer this year.
Nov 3, 2011. 3:04 PMMargueritaM says:
This is awesome! I was just trying to think of a way to do something similar :) I might use tension curtain rods, instead of the coat hangers. You can buy adjustable tension rods (meant for curtains) at WalMart. They have an inner spring and rubber caps on the ends. I use them a lot and I love the fact that they are not permanent. I can't wait to put some bubble wrap on some and try this out!
Nov 3, 2011. 3:25 PMdangerine says:
I think you just saved me $15 - $30 a month in heating bills for the winter. Hope to remember to check back in around March to let you know what the actual savings were because of your awesome storm window! THANK YOU!
Nov 3, 2011. 6:01 PMdahut says:
Ive used bubble wrap to insulate chicken coops and cold frames, so this is another good use of the material.
Im thinking a more rigid frame of wood or aluminium strip stock would allow the film to be drawn taut and look a bit more "finished."
Secure the frames with some sort of removable fastener or cleat, and then store them in a closet or attic once winter is passed. They would take up very little room that way.
Great idea.
Nov 3, 2011. 3:56 PMveeisme says:
This is a brilliant idea. I too live in a mobile home that was manufactured in the '70s and hate how the single-pane windows ooze cold into the house all winter long, but I also have cats who do their damnedest to rip plastic out of the windows if it's the transparent stuff!
I'll definitely be trying this, because the bubble wrap seems like it would be a decent deterrent to my cats, since I've had a "bad" habit of randomly walking up behind them and popping bubble wrap for as long as I've had both of 'em. >:D
Nov 3, 2011. 4:08 PMzanne101 says:
To keep the cats away, put some lemon (slices, juice, potpourri, air freshener etc) in front of where you want to reduce the cat visits. I also use cedar oil to keep them away from things. Figure out what they hate and put it there.
Nov 3, 2011. 1:55 PMMaxCrunch says:
This is a good instructable, thanks.
In my camper I did a very similar thing. I used bubble wrap, double the size that I needed.
Fold over the bubble wrap, use clear plastic tape to seal the 3 sides that way no air escapes.
Insert into the window or over the window.
Some are inserted directly into the window between the window and screen, another is covered by a clear plastic sheet that holds the bubble wrap in place.
Two areas, have the folded bubble wrap held in place by Dollar store Sun Shades, the reflective type. Those windows are by far the warmest, though not too much more than the one that is held by the screen. I did the sunshade thing to cut out the sun as it is close to my eyes in my sleeping area.
Look forward to your next instructable.
Nov 3, 2011. 12:32 PMraviolikid says:
Great idea! I think I just may try bubbly wrap for insulation in my bedroom this winter. Dollar Tree - here I come!
Thanks!
1-40 of 47next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:kc8hps(Bryan)
I am a transplant to Denver, CO from Michigan. I like to make friends with similar interests to mine. I read a lot and try to make every day a productive learning experience. I enjoy building project...
more »
