Bubble Wrap Storm Window (Insert)
 by kc8hps
Featured
In this instructable I will show you how to make an INDOOR storm window that will keep plenty of cold out of a room, while letting light continue to come in. My version uses less than $4 worth of supplies, mostly from the DOLLAR TREE store.
THE STORY :)
I moved into an apartment on the 3rd floor. all windows were single pane. The building was built in about 1970, so there was poor insulation, and only single pane sliding glass windows.
It was very cold the first night and the pipes nearly froze in the bathroom. the window rattled and I knew I was in trouble.
By creating my bubble wrap storm window, I was able to raise the temperature in the room 15 degrees F in the first hour. As you can imagine the savings and comfort increased rapidly.
As you can see I do have some depth to the window so making this work was kind of easy. I suppose using clear tape , magnets, velcro etc, you might find another way to put a storm window of this type in place.
Step 1: Step 1
In picture 2 you can see I bought clear tape and 1ft by 6ft rolls of bubble wrap from the Dollar Tree, (where everything is actually $1.00). I then found 2 wire coat hangers and unwound them to make a frame for the project.
I first rolled out two 6ft rolls side by side and taped down the middle. I actually bought 3 rolls, more on that later.
Step 2: Step 2
I placed a dark towel under the project so the camera would pick up more details of how I put it together. I formed the wire hangers in an "L" shape and taped them to the bubble wrap. It might be good to mention my window is 2 feet wide and 3 feet tall. This amount of bubble wrap works perfectly with NO WASTE.
I placed opposing wire hangers on both sides of the bubble wrap. when taped in place I folded the other half back over them to give me my 2x3 ft panel.
Step 3: Step 3
I proceeded to tape all the sides and ends with the clear packaging tape. P.S. you may find the tape yellows a bit, its a simple solution so do it over next year !!! :) In picture #6 you can see the semi finished project. the hanger wires give it some support so I dont need tape (which would not stay in place in the shower).
Step 4: Step 4
In pic #7 you will notice two more strips of 2x3 bubble wrap. I had purchased all 3 rolls not remembering the exact measurements of the window. I thought if I needed the 3rd roll to make it longer or wider I would have enough. Turns out I didnt need it for the purpose.
I took the two strips and essentially added a 3rd layer to the storm window. I proceeded to lay the pieces in place LEAVING APROX 5/8" Gap in the middle and then taping them to the existing panel. this not only gives some extra on the outer edges, but also leaves a gap where the center of the tape will adhere to the original window and be some structural support.
After taping the outer edges yet again. I was done! TIME TO TEST IT OUT. See picture #8 notice the density has increased over the last picture.
Step 5: Step 5
I removed all items from the sliding single pane window shelf. The next things was to put the storm window in place. I uses no adhesive. The clothes hanger wire allows for some tension and holds it 95% in place with some tucking here and there.
The following 3 pictures show the insertion and the finished product.
****** This bubble wrap window is the second one I have made. Turns out the last one did have yellow tape and some shampoo bulid up, but it lasted 2 years ****** not bad for nearly FREE!!!
If you have questions feel free to ask.
If you liked this Instructable you might enjoy http://www.instructables.com/id/Weather-Strip-a-window-on-the-cheap/
Here I show you how I weather strip a window for just PENNIES.. I MEAN CHEAP!!!!
1-40 of 49Next »
kc8hps (author) says: Oct 3, 2012. 10:50 PM
It has been about one year since I have done much with this instructable.
UPDATE.. I have found the tape in a shower setting typically lasts one season. I think the time to remake it is well worth it..
The cost is still in the area of $2.50-$3.00 to do the project. If you are lucky enough to find free bubble wrap you can likely do a window for under a $1.
I have saved a ton of heat and a lot of discomfort from cold air while trying to take a shower. I also believe it has helped the shower pipes in the wall near by not to freeze and break.
Funny the apartment complex has a sign as you drive in the driveway.. :"leave your bathroom faucet on trickle to prevent freeze up" I Think I have found a better solution.
My instructable about weather sealing a sliding window is not so glamorous but still helps ALOT for very low money. Sorry the pictures on that one do not do it justice. :)
Peace, Bryan
Judith756 says: Apr 23, 2012. 4:22 PM
Check you local Craig's List for free bubble wrap. We have it on ours every week. I actually use the "pool noodles" bought at Dollar Tree for a buck for cheap pipe insulation. Have never had a problem. Just slice it in a spiral, "twist" it on and duct tape a couple of places. Has worked for 8 winters here on my outdoor faucets.
Thanks for the ible.
kc8hps (author) in reply to Judith756Aug 22, 2012. 6:32 PM
HI Judith,
I'm sorry I didn't see your post for so many months. YES I will check out craigslist for bubble wrap. IM about to do another version of the bubble wrap storm window. IT worked so well that I want to try and improve it a bit more.
Pool Noodles. I have seen those and have been dreaming of ways to use them. One I thought of was to use them on the edge of coffee tables, head boards so that they dont mar the wall if accidently bumped. I know that sounds over board but it might work.
Those noodles I would think would work great as pipe insulation. Actually as I recall they are a bit thicker if I am not mistaken.
Nice to hear from you.
Bryan
unreal_ed says: Nov 8, 2011. 1:51 AM
How important is it to cover the window completely?
I've taped it over most of the window but it does not quite cover the edges of the glass (nor does the tape run the length of the wrap's edges). I've also not necessarily taped all the strips of bubble-wrap together along their lengths (I'm doing a lot of windows...)
Your talk of eddy currents is making me worried that not completely covering the glass will make the whole installation pointless. Is this a legitimate/reasonable concern?
kc8hps (author) in reply to unreal_edNov 8, 2011. 8:44 PM
I would strongly suggest covering all edges, bubble wrap or glass. the idea is to seal the edges so that internal air can not move much.. this reduces the transfer of heat molecules from the inside of the room to the outside much slower. If you have gaps you are correct that it is pointless in a way.
unreal_ed in reply to kc8hpsNov 11, 2011. 8:57 AM
Thanks for answering!
Also, what if the bubble-wrap does not COMPLETELY cover the whole surface of the window (but almost all of it) but it's is properly sealed along the edges? Is that better, or also pointless?
kc8hps (author) in reply to unreal_edNov 11, 2011. 8:02 PM
Hi
If its sealed, I would say something is better than nothing
hms1018 says: Nov 6, 2011. 6:59 AM
I'm in Michigan and this is a sweet idea. Thanks
kc8hps (author) in reply to hms1018Nov 8, 2011. 8:59 PM
Hey, I'm glad you liked it. If you liked this one you might like my Instructable on how to weather strip a window on the cheap and I mean pennies!!!
tomas.savage says: Nov 4, 2011. 10:16 AM
nice. i usually use the specific window insulation made by 3M (clear plastic sheet, two sided tape and hair dryer), but this will probably work better.
kc8hps (author) in reply to tomas.savageNov 4, 2011. 12:21 PM
HI Tomas,
I have also used the 3M clear plastic sheet. I steered away from it due to tape in the wet shower conditions.
Keep in mind the bubble wrap keeps eddy currents in the air gap from moving due to temperature differences as heat molecules transfer places. if you can keep the eddy's under control you have greater insulation R values.
According to one of my professors an air gap of 3-4 inches or less makes this happen (keeping eddy's under control) this a double pane glass or triple pane situation.
tomas.savage in reply to kc8hpsNov 4, 2011. 5:38 PM
good info thanks. i have a different problem though, maybe you'll have an idea. i have 3 windows that are nothing but a screen and a swing-away glass pane that close flush with the wall. with the window closed, there is about 3-inches of space between the glass and screen.
a crude 'visual'
[outside] [screen] [3 inches] [window-pane flush with wall] [indoors]
do you think this will work if i place it right up against the screen?
[outside] [screen] [bubblewrap insulation] [2 inches] [window-pane flush with wall] [indoors]
being from michigan, you already know what kind of weather we get out here. i don't know if the bubblewrap can last exposed like that.
MaxCrunch in reply to tomas.savageNov 8, 2011. 2:49 AM
Yes it will,
see my answer below, I used it folded over, tape the edges on all three open sides.
tomas.savage in reply to MaxCrunchNov 8, 2011. 5:44 AM
thanks. my upstairs "studio" gets very cold in the winter due to these badly designed windows and they're not a standard size so replacing them means expensive custom work.
i'll give this bubblewrap a try since it seems to be an easy and inexpensive 'fix'.
kc8hps (author) in reply to MaxCrunchNov 8, 2011. 5:19 AM
I agree MaxCrunch,
It will actually work better due to the inside air space. being STILL AIR. you might have to create a falls frame say the outside of a card board box to keep the wrap up against the screen and keep the 2 inch space open..
let me know what you think..
Giorgiodeste says: Nov 7, 2011. 11:19 PM
great idea, i have a similar problem ... I'm going to buy materials :-) thanks
jbrune says: Nov 5, 2011. 10:56 AM
Great job, I'm definitely gonna try this on our bathroom and basement windows.
bcccool says: Nov 5, 2011. 5:00 AM
Just to let you know you can use the bubble wrap and be done in 5 minutes with each window and its NO WORK except for measuring the window and cutting the wrap;
I live in Wisconsin and my winters are horrendous, measure windows and cut wrap to fit your window. THE EASY PART,
MUST PUT WATER ON IT AND APPLY THE WRAP. THATS IT! ! ! ! It keeps out the cold radiating from each window. Course you cannot see outside but the light still comes in. Great for bathrooms if you want to keep your neighbors from looking in
bri322 says: Nov 4, 2011. 7:16 AM
This is a really great idea! I think I'll use it on windows we don't really look out: bathroom, basement, closet. YAY. We have old windows, so I might just leave it up year-round. Thanks!
kc8hps (author) in reply to bri322Nov 4, 2011. 12:24 PM
Hi Bri,
In my old house I would use peices of R-11 fiberglass batting in the basement windows.. I know that is sort of over kill but hey I was never down there.
Windows to me are like open holes as far as heat loss goes.
Most of my north windows were well insulated during the winter months as they yielded zero gain as far as sun was concerned.
Bryan
rpearse says: Nov 4, 2011. 8:17 AM
Great idea. Thank you for sharing.
sugarandfat says: Nov 3, 2011. 8:25 AM
I was doing that for a while, but bubblewrap isn't actually the best stuff to use, as the cell size is fairly large, and a lot of the area ends up being single wall. Much better is polyethylene foam wrap, otherwise known as that thin semi translucent stuff they sometimes wrap electronics and stuff in.
This: https://zeorymeromega.files.wordpress.com/2011/08/polyethylene-foam-closeup.jpg
It's the best stuff for insulating pretty much anything, as it's essentially free (can be dug out of a variety of skips in large quantities), very insulative, and with a reasonably high melting point. I tested the last two by putting some over my hand and pouring boiling water on it. Felt slightly warm...
kc8hps (author) in reply to sugarandfatNov 3, 2011. 6:30 PM
Thanks so much for the information.. Yes I had considered using it and may in the future. the rigidity of it seems like it would be more suited for larger windows than regular bubble wrap..
sugarandfat in reply to kc8hpsNov 4, 2011. 3:48 AM
Rigidity? We're talking about different stuff (I may have the name wrong).
This material is a mm or two thick and completely flexible.
Crispie J says: Nov 3, 2011. 6:35 AM
This is awesome!! In addition to being simple and cheap, it also looks good - gives the impression of that fancy pebbled glass.
I sure could have used this a few years ago when I lived in a huge house heated by an oil furnace. All of the oddly-sized single pane wood-framed windows had serious leaks. After the first $600 fill-up I shut off the heat to most of the 5 zones in the house and kept the thermostat at 15 degrees C (60 degrees F) all winter (and this is in Canada). I was having "cash flow" problems (all my money was tied up in real estate :p) and I tried (and failed) to come up with a cheap solution to this problem. Ironically I now live in an apartment where I have the opposite problem - heat and hot water are included in my rent. but the place is always so hot that I keep the thermostat off and appreciate the ill-fitting windows.
kc8hps (author) in reply to Crispie JNov 3, 2011. 6:37 PM
Crispie I can relate..
I had a house in Michigan. when I first moved in it had no attic insulation, no sidewall or bandjoist insulation.. the yearly oil bill was $2,500.00 for only a 24x30ft house.. YIKES..
that was 14 years ago. I wrapped the water heater. put an R-38 in the attic, and R-17 in the sidewalls. the first years winter heat bills after that were a total of $235.00
when I first moved in I could stand 3 feet from an outside wall and feel cold radiating off the walls. YES insulation helps! btw I used to live in Edmonton Alberta.
stevepuk says: Nov 3, 2011. 7:55 AM
Do you have any problems with condensation getting trapped between the bubble wrap and the window?
kc8hps (author) in reply to stevepukNov 3, 2011. 6:31 PM
not typically since the window it is over leaks air a bit so moisture there has an easy way out..
If it were not an apartment I would do the work to replace/caulk/seal it. but I dont dare violate my lease by trying to fix it myself.
Squee says: Nov 3, 2011. 9:23 AM
Guys doing the same thing here, they just use water to get the bubble wrap to stick to the windows, no having to make an armature.
http://www.builditsolar.com/Projects/Conservation/bubblewrap.htm
kc8hps (author) in reply to SqueeNov 3, 2011. 6:26 PM
HUMM water on the window neat Idea.. Ill have to think that one over next time.
TigerMoon says: Nov 3, 2011. 2:14 PM
Nice! I live in a 41 year old trailer so I know about inadequate insulation! Have been using bubble wrap (the big bubbles) for a couple of years now. I actually like the way it looks too, nice diffuse light and it provides a bit of privacy, tho double layers would work better. Maybe I'll add an extra layer this year.
kc8hps (author) in reply to TigerMoonNov 3, 2011. 6:24 PM
Thanks, the first time I built this I had just moved 1200 miles, I had the bigger bubble wrap so I used it.. it worked well. this time the DOLLAR TREE had the smaller bubbles so I went for it and did three layers instead of two.
MargueritaM says: Nov 3, 2011. 3:04 PM
This is awesome! I was just trying to think of a way to do something similar :) I might use tension curtain rods, instead of the coat hangers. You can buy adjustable tension rods (meant for curtains) at WalMart. They have an inner spring and rubber caps on the ends. I use them a lot and I love the fact that they are not permanent. I can't wait to put some bubble wrap on some and try this out!
kc8hps (author) in reply to MargueritaMNov 3, 2011. 6:22 PM
HEY HEY,, I like the tension rod idea.. next time around I am going to add that to the project.. thanks so much for reading. look at some of the other money savers I just posted in my profile.
dangerine says: Nov 3, 2011. 3:25 PM
I think you just saved me $15 - $30 a month in heating bills for the winter. Hope to remember to check back in around March to let you know what the actual savings were because of your awesome storm window! THANK YOU!
kc8hps (author) in reply to dangerineNov 3, 2011. 6:21 PM
I know the last two years I have saved a fortune in heating dollars let alone the added warmth and comfort. we were at 18 F last night here.. with out it in the window my tub would have likely froze up. get back to me on your savings.
dahut says: Nov 3, 2011. 6:01 PM
Ive used bubble wrap to insulate chicken coops and cold frames, so this is another good use of the material.
Im thinking a more rigid frame of wood or aluminium strip stock would allow the film to be drawn taut and look a bit more "finished."
Secure the frames with some sort of removable fastener or cleat, and then store them in a closet or attic once winter is passed. They would take up very little room that way.
Great idea.
kc8hps (author) in reply to dahutNov 3, 2011. 6:18 PM
Yes I like your idea.. this one being inside the shower I knew eventually I would end up with soap scum or residue (like the first one :) and would just want to throw it out, so I went for cheap.
veeisme says: Nov 3, 2011. 3:56 PM
This is a brilliant idea. I too live in a mobile home that was manufactured in the '70s and hate how the single-pane windows ooze cold into the house all winter long, but I also have cats who do their damnedest to rip plastic out of the windows if it's the transparent stuff!
I'll definitely be trying this, because the bubble wrap seems like it would be a decent deterrent to my cats, since I've had a "bad" habit of randomly walking up behind them and popping bubble wrap for as long as I've had both of 'em. >:D
zanne101 in reply to veeismeNov 3, 2011. 4:08 PM
To keep the cats away, put some lemon (slices, juice, potpourri, air freshener etc) in front of where you want to reduce the cat visits. I also use cedar oil to keep them away from things. Figure out what they hate and put it there.
1-40 of 49Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
