3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bubblesteen Bubble Machine
Is it a 3D Spherical Atmosphere Encapsulated Phosphorous Printer?   YES!
Is it a CNC Anti Gravity transparent Orb Machine!   YES!
Its The Bubblesteen Bubble Machine! The spherical miracle that kids and cats have been waiting for. It comes complete with robotic edge detection( when a bubble hits an edge it pops, thus the edge has been detected).
Turn up the sound and watch Lester the cat battle it out with the Bubblesteen!
* No animals were harmed during testing.
This project came about after playing around with pan and tilt using servos. Most of the pan and tilt senereos I saw involved using webcams or some type of camera, which pan and tilt is perfect for. There are some good instructables and how-to's on the web for this very thing.
I may not have an available camera, but I did have some bubble mix :)
http://bernardkatz.com/
Step 1Things you will need
This list is mostly for the electronic and mechanical stuff. How you create your own Bubblesteen will depend on your creativity and what you have laying around.
I will also include small tips on the materials I used and things to be careful of
  1. 1. Arduino Duemilanove  $30.00
  2. 1 motor shield  $19.50 (www.adafruit.com) * It is made to fit the Duemilanove
  3. 2 micro servos- I used Hextronik HXT 500 $3.50 each (www.hobbyking.com)
  4. 1 DC toy motor- something between 3v and 12v - easy to find, motor shield docs will help you decide if what you may already have will work.
  5. 1 thing of bubble mix. - find at CVS or a dollar store. Some work better than others
These things I used, but are not critical. This is where your own creativity will need to come to play.
  1.  1 roll of perferated metal tape- any hardware store
  2.  nuts and bolts of various sizes - thread count not critical :)
  3.  diamond plate- local scrap yard
  4.  aluminum channel- local scrap yard
  5.  1 threaded rod hanger/ plate
  6.  earthquake putty or museum wax
  7.  5 minute epoxy
  8.  1/4" acrylic sheet- about 6" x 6" worth
  9.   acrylic adhesive
The tools you need will once again depend on what you build yours out of.
32 comments
Oct 8, 2011. 8:21 PMpfred2 says:
What is not to love about yet another frivolous use of a microcontroller? That is my problem with them, I've never found a valid use for one yet. I'm still hoping that someday I will...
Oct 9, 2011. 1:39 PMpfred2 says:
Probably? You mean you've some doubt? You cause me wonder as to why you wouldn't share a more worthwhile project. We're worlds apart.
Apr 3, 2012. 9:52 AMbears0 says:
Why share a companies research? that is how they stay on top. Honda cant tell Ford and Chevrolet how they program their traction control systems because they will just copy them. car companies want something fresh that no one else has. they may tell you the features, but they wont tell you how they designed them.
Apr 3, 2012. 10:35 AMpfred2 says:
Non sequitur?
Sep 20, 2011. 3:32 PMthorn says:
Second video refuses to play. "This video contains content from SME, who has blocked it in your country on copyright grounds."
Jun 29, 2011. 1:05 AMmischka says:
Cool, I am loving that machine!
May 9, 2010. 8:23 PMDanDiego says:
It would be fun to build a simpler version of this using one of those drinking birds that dips its beak in water. The bubble wand would be fastened to the bird's head to dip into the bubble solution, and the fan could be triggered by a mechanical switch or light beam. http://www.drinkingbirdshop.com/
May 7, 2010. 12:19 PMmicobanff says:
 That is hilarious and awesome! I would love to try this with a multiple hole bubble stick. If there is a way to slow the fan down, I think it would increase the number of bubbles in each go.
Great job, and love the diamond plate idea.
May 1, 2010. 2:41 PMyoyology says:
There's a few good recipes for making your own bubble solution (along with lots of other bubble lore) at The Bubblesphere.
May 6, 2010. 4:57 PMMr.NHRA says:
 Maybe its just me, but i thought bubbles were made by adding dish soap to tap water until you could blow bubbles with it. :) great instructable!
May 6, 2010. 2:56 PMmikeythev says:
 I think I'm in love...
May 6, 2010. 10:44 AMEdgrs says:
 It's sooo sweet and funny
May 6, 2010. 9:15 AMNinzerbean says:
 Bravo!
May 3, 2010. 12:19 PMdlfynrdr says:
Dude, you have WAY WAY too much time on your hands!!  (I love it by the way)
May 3, 2010. 12:23 PMdlfynrdr says:
One other thing, did you use that "catnip bubbles" to make that video?  If you'rre not familliar with the stuff, they sell it on amazon.  http://www.amazon.com/8-1-Kookamunga-Catnip-Bubbles/dp/B000084E76/ref=sr_1_1?ie=UTF8&s=home-garden&qid=1272914508&sr=8-1
May 1, 2010. 4:09 PMbulsatar says:
The fan may be rotating too fast and blowing the bubble solution out of the surface tension balance.  Might want to regulate the amps for about half  and you should get more bubbles  :)
Apr 30, 2010. 4:08 PMkarossii says:
It would seem to be more efficient (and less messy) if the bubble wand only dipped down and lifted, without the need to rotate...
May 1, 2010. 7:25 AMzascecs says:
 I had the same thought...
May 2, 2010. 9:36 AMCulturedropout says:
There's no laser!  How can you expect to have a silly, over-the-top, expensive machine without LAZORS?!!?  ;-)
May 6, 2010. 9:28 AMheathbar64 says:
this just confirms once again my theory that the more ridiculous and useless an item is, the more fun it is to design and build. The laser would be cool if you could actually illuminate the bubbles with it.
May 6, 2010. 7:20 AMmjcwr14 says:
 Make sure its only set to stun
May 1, 2010. 1:13 PMkelseymh says:
No better answer could exist.  Bravo!
May 1, 2010. 6:43 AMzanderjones says:
 That is beautiful, a true work of art.  I can see this sitting quite happily in the Tate Modern.
Apr 30, 2010. 10:07 PMXOIIO says:
LOL the second video is epic!
Apr 30, 2010. 8:18 PMnickodemus says:
This is great! And very entertaining also, I'm sure it would make a great center piece for a table. Nice work, keep it up!
Apr 30, 2010. 5:16 PMkcls says:
Very cool! I like the second video :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:belliedroot(Bernard Katz Glass)
I am a glass sculptor with a shop and gallery located in the Manayunk section of Philadelphia. Besides being a dad and running my business, I have a strong interest in electronics, and physical comput...
more »
