Bucket Chicken Feeder
3,473
68
Published
Introduction: Bucket Chicken Feeder
This is a easy and fast way to give your chicken there feed for a long period of time. It is even better for when they get older and eating a lot more feed. So if you want a easy fast way to feed your chickens then this is the project for you.
Step 1: Materials
5 gallon bucket (with lid)
three bolts 5/16 (three washers for each bolt)
A metal pan
Drill
1/2 wrench
Step 2: Cut Slots in the Bucket
Drill holes into the side of the bucket any where on the bottom of the bucket.
Step 3: Drill Holes for Your Bolts
Drill holes in the bottom of your bucket and metal pan so it will connect
Step 4: Put Bolts in the Holes
Put the bolts going up through the metal pan then through the bucket.
But before you put the bucket on the bolts put the biggest washer on then the bucket
Then but the other washer on and then the tap
and tighten the bolt when done (1/2) is the size
Step 5: Done
You are done and can add the feed to it and give it to the chickens.
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
    • Creative Misuse Contest
    2 Discussions
    Great idea and so much cheaper than buying one!! :)
