3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Budget Chopper Bicycle
This is an instructable on how to build a chopper bike on a budget.
The main inspiration for this came from AtomicZombie and Koolkat's instructables.
I've recycled as many parts as possible, and used scrap materials when I could.
I took a 25 year old Raleigh Wisp ladies racing bike and converted it to something a bit out of the ordinary.
Materials needed:
*Donor bike.
*Welder (I used a gasless MIG welder - a Clarke 105EN)
*Steel tube(s) for the forks. These need to be quite heavy gauge as the forces involved will tend to bend the tubes.
*Steel tubing to extend the frame after chopping. The diameter of this tubing should be either slightly smaller than the existing frame tubing (to fit inside the cut tubes) or slightly bigger (to fit over the tubing). Butt welding tubes of the same diameter is more difficult and will not be as strong unless your an expert welder (and I'm not!).
*Some sheets of steel. I had some 1.4mm thick sheet steel which is perfect for the plates I made.
*New chains - if you're extending the frame significantly, the chain length will also increase. Buy two cheap chains to join together.
*Access to a pipe bender - you may need this if your angles change significantly and you don't want to cut the extension tubes at an angle.
Read on for instructions on how I did it, and the mistakes I made along the way.
Above all, enjoy building and don't give up!
Step 1Think about your source bike.
So... what have we got? My sister's 25-year-old Raleigh Wisp. I've wanted to build a chopper for a while, but surely we can't do anything with this Wisp, can we?
It's an unusual frame - it's got twin top tubes which go from the steerer tube all the way down to the rear hub. This is a really distinctive look and I wanted to keep it.
I could use the twin top tubes as a nice place to mount the seat.
OK, lets move on to the next stage - preparing the forks.
30 comments
Aug 10, 2009. 9:28 PMmickalobe says:
finished!
Feb 18, 2012. 1:05 AMmavado says:
hi, Mickalobe i love the way you have customized your bike. could you please send to me the dimension/measurement on how you have made that bike.
Feb 18, 2012. 1:00 AMmavado says:
Hi, Mickalobe i loved your bike, could you please send to me the measurements that you have used to make your bike please.
May 15, 2011. 10:28 PMTheMaker888 says:
unless the chainstays are tweaked the break mount hole should be aligned with orig mount..
you also may have the wheel poorly alighed making it look like the break mount is off or not centered.
Apr 28, 2011. 5:37 AMzhump says:
Great write up. I like the look. Proportions look good
Apr 16, 2009. 6:55 AM52 says:
the bike looks good but is 2 long
Sep 4, 2010. 10:40 AMHellchild says:
its supposed to be...?
Aug 9, 2009. 4:17 AMpteranosaur says:
...no such thing as "too long" on a chop !
Jun 27, 2010. 3:27 PMmason0190 says:
amen
Jul 16, 2010. 1:33 PMcool not lame says:
about how much does all o dis cost?
Jun 4, 2010. 8:24 PMjlmayes says:
love the look
Apr 19, 2010. 6:23 PMtheman123321 says:
 hows the steering?
Mar 12, 2010. 11:29 AMEli_Z says:
Very cool.  Very, very cool.  Thanks for the 'ble, enlightening.  Now I must learn to weld, grind, cut...
Very very rock'n'roll.
Feb 16, 2010. 7:44 AMgeoper2 says:
nice instructable very good work but with the seat u got in the pics i think that your "rear end" will be touching the wheel so i dont know if its good to ride ??probably u put another one
Sep 19, 2009. 1:03 PMJodex says:
And also can you give me some measurements? Like how long your front fork is and how long is the distance between the centers of the wheels? Centimeters may be better =) Thank you.
Sep 28, 2009. 11:14 AMJodex says:
Well okay. And I just have to say that that bike was veeery nice looking!
Sep 18, 2009. 1:25 PMJodex says:
I already have a bike like that bought new from store, but I'm gonna make another! That's so cool! Just need to get a bike to mod...
Sep 3, 2009. 3:20 PMguitarplayer873 says:
Do you ever have any issues with your builds flexing at all?
Aug 9, 2009. 10:36 PMmickalobe says:
here a more recent upgraded pic
Aug 9, 2009. 10:24 PMmickalobe says:
i built this bike and it turned out great.
Jul 6, 2009. 5:10 AMstrangebike says:
looks like some really tidy engineering going on on this bike. I much prefer the second version is it as structurally strong as the first one? or have you gained flex in the frame ? Really glad to seethe dry build stage and the test fit done fully before you wasted your paint on the final job . Really impressed fella !
Aug 9, 2009. 4:24 AMpteranosaur says:
hheyy Jinn-know how pro MC bilders join pipe? Bungs-machined to interior diameter,or pipe same external dia as inside of pipe being joined.Drill a few holes for rosette welds,circle the joint itself,and the bung helps prevent 'burn thru'...most bike tubing is in gen standard sizes for accessory porpoises,not to mention dolphins......har har
May 14, 2009. 7:58 AMr31skyline says:
hi i was wondering if you have the dimentions for this build and a bit more detale on wher to bend and how much to bend please email me with more detale @ anthony-murphy@virginbroadband.com.au
May 7, 2009. 2:35 AMDIYenthusiast= says:
I would recommend having a back rest to be added to the seat stays which will make more appealing and comfortable for the rider since the back rest can be welded to the seat stays easily.
Jul 2, 2008. 10:06 AMuguy says:
Bad to post an unfinished ible.!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:jinnan_tonnix
