3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Budget Venetian Chandelier
After seeing an incredible Chandelier in Venice, I got the bug to make one. With all the supplies (~ $40.00) it took about a weekend to assemble and paint. More images and description can be found here.
Step 1Things You Will Need
- Black Foam Core (32x40 in, 0.2in thick) Two Sheets
- Matte board (32x40 in, 0.05in thick) Two Sheets
- Can of spray primer
- Can of spray color
- String of Lights (The BIG ones)
- Wire (~18 gauge)
- Glue (Used wood glue, other would probably work fine)
- Some String..
- Zip Ties
Tools
- Soldering equipment (Pencil iron, Solder, Electrical tape)
- X-acto knife
- Laser cutter, or hours to spend cutting material
5 comments
Aug 25, 2009. 5:15 AMselena1 says:
Do you think you could make me one?????
Aug 7, 2009. 3:49 PMJmae says:
It would be really cool to use the christmas candle lights too. I want to do this really bad, but don't know where to put it.
Aug 6, 2009. 3:50 PMinkstainedheart says:
This is a really cool idea! I've seen similar things made from wood, but I think a lot more people would be able to make one using foam core and mat board. When it comes to wiring though, I agree with omnibot. I would use different wire for the hot and neutral, and if possible, a ground wire as backup.
Jul 30, 2009. 12:51 PMomnibot says:
Beautiful! But your use of green/yellow wires is appalling, they are only to be used for the grounding wire. It works but if someone else is going to repair it it can cause injury's or worse, also I don't recommend soldering highvoltage wires like that, is there is a bit of rosin left inside the joint it can overheat and explode.
Jul 28, 2009. 3:12 PMfungus amungus says:
I really like this project. Sadly, it's not primarily made out of cardboard for the contest, though.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:rwistort
