3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build A Nok Hockey Table
This was one of my favorites when I was a kid. However, after moving to the midwest from the northeast, no one here seemed to ever hear of Nok Hockey.
If you know what this is, welcome back to your childhood.
If you never seen this before, here's your chance.
This is a pretty easy build, and inexpensive too.
Build List
1x3x8 Pine - 2 pieces
2'x4' Hardboard
Nails or Screws or Glue
Small piece of hardwood (for pucks and sticks) 1/2" thick
Step 1Cut the base
Cut the base
Cut your hardboard to 2 feet by 4 feet.
You can use a table saw or circular saw. Regardless of tool, cut it as square as possible.
Whew, that was hard.
28 comments
Aug 14, 2009. 1:35 PMSolidStar says:
Would it be possible to make it bigger? Maybe instead of 2'x4', it'd be like 3'x6'?
May 22, 2009. 7:27 PMSpider64 says:
there it is :) do u own the real nok hockey board?
May 23, 2009. 6:55 PMvtstruct says:
I just built one of these and put the center of the guard pieces 4" from the inside edge of the vertical backpiece. Seems to work okay for double bank shots. Also, the blue defense line should be about 1/4 the table length from each end. Also noticed after I built this one that "real" nokhockey tables come in two sizes, neither of which is the same as this one. They are 36" x 24" and 48" x 36". That makes it easier to get a single bank shot in because the table has more proportional width. Also, their corner pieces come all the way up to the top of the frame, so a high shot still corners in.
May 21, 2009. 6:17 PMSpider64 says:
Thank you for the instructions :) im 14 and made one of these for 10$ in wood shop in school. there so fun like we have competitions and stuff.putted one coat of gloss the waxed it and it slides real smooth. the only concern i have is the goalies are good 6 inches away but i would say about 4 because on 6 inches you cant do the bumper to goalie shot :( but its still fun at 6 :) Thank you 4 stars :)
Mar 2, 2009. 2:32 PMsmarino88 says:
I masked and painted the lines and circle on table with kids craft paint. After drying, I finished the table with 2 coats of high gloss poly. Ran some extra fine steel wool over it just to smooth it a bit. The most important step was to spray "pledge" polish over it, and that table is as slick and fast as can be. Just make sure your kids don't walk on it in their socks!
Feb 14, 2009. 8:05 AMsmarino88 says:
Great instructable! I just made this, but changed the dimensions as follows: 48" x 36" table, 5" wide goals, and goalies placed 5" from the goal. I have yet to finish the surface, but am thinking of a nice coat of high gloss poly, but plan to paint lines and circles first. Anybody have any suggestions for finishing? I liked the earlier comment about using plastic, but its a little pricey. I did remove quite a bit of the friction by waxing the surface of the puck. It goes much further. I also used poplar for the sticks and pucks, but they just don't feel right. Next time I'd use a denser wood like oak.
Jan 22, 2009. 8:02 AMmamsis says:
we made 3 or these games for our grand-kids. Great directions, though we guessed at where to draw the defense lines. We used wood glue and an air-nailer/stapler to fasten things together. Then we used paint pens to decorate the "ice" - didn't seem to affect the slickness of the surface too much. I even painted on team logos (Red Wings, Avalanche, and Wild) to match my grand-kids locale. Thanks for bringing back a great memory - and help me pass it on to the next generation!
Jan 15, 2009. 8:02 PMkokosmack says:
you could also cover the surface with something like wax paper to make the puck glide more, just a thought
Dec 15, 2008. 12:47 PMoutlate says:
I used to play this game daily at the youth center as a kid. We used to play it without the sticks and a plastic checker instead of the puck. Why is it better that way you ask? Our favorite part of the game was the corner/goalie combo shot :) HUH you say? Check this out. You can shoot the checker along the wall and have it ricochet off the corner and then again off the goalie square and POW! a goal, in one shot. Here's how. Place a checker against the wall (lets say the right wall), put your right thumb against the left side of the checker while your other fingers are on the outside of the same wall (basically pressing the checker in to the wall), then squeeze the checker till it shoots forward. practice and you'll get it. we had a rule that If you could touch the checker and the wall at the same time, with the same hand (spreading your fingers) you could move the checker over to the wall and shoot from there. All other shots we would just use our thumb on top of the checker and flick forward. Hope this adds to the fun. PS> This may require that the goalie and corner pieces need to be correctly positioned.
Jul 2, 2008. 7:39 PMKoming100 says:
i never knew u can make ur own nok hockey board thingy
Jul 28, 2007. 8:49 AMservant74 says:
Hmm, could do the same thing for air hockey. use a 1x6 or 8 rather than a 1x3, put the solid 2x4' hardboard on the bottom and a 2x4' of pegboard on a top layer about 3" down from the top of the 1x3. Duct in an electric leaf blower, use a CD or 3 laminated together. The could be a slot about an inch wider than the CDs and about an inch tall (rectangular would work OK here). ... sounds like a weekend project! ... BTW, great instructable!
Jun 9, 2008. 10:15 AMross353 says:
do you think you couild use a few computer fans for the air flow or sould it be to weak?
Jun 18, 2008. 3:56 PMservant74 says:
I would suggest going with a vacuum cleaner. (The wife knows I would never use one otherwise ;)
Jul 28, 2007. 11:32 PMmoomoocows says:
I'm from Wisconsin and I've not only heard of it I play it quite often at my neighbors house. I like the instructable.
Jul 28, 2007. 5:35 AMKiteman says:
Very nice. I've never heard of Nok Hockey (are you sure it isn't Knock Hockey?). Being British, the only hockey I know is played on grass, against bloodthirsty teenage girls but this looks good.
Are there any special rules to Nok Hockey, or is it just "hit it until it goes through the hole, try not to break any knuckles"?
Jul 28, 2007. 12:01 AMSpectrace says:
thats pretty cool how you make that. I've seen the tables for sale in sporting goods stores. You can buy a hockey stick/puck set for cheap. but making your own is more fun. another thing is, the goalies should be only about 3-6 inches from the goal. 12 seems like you can make a goal too easy around it. Great instructable by the ways.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:lee_schnitz
