-This project includes lethal voltage levels. Make sure you know your high voltage safety or have a qualified electrical advisor.
-Potentially hazardous levels of x-rays will be produced. Lead shielding of viewports is a must!
-Deuterium, an explosive gas, will be used. Make sure to check for fuel leaks.
-All the other inherent dangers of a home engineering project of this degree (a wide gamut of potential injuries, damage to the checking account, and the loss of general sanity)
Here are the minimum required materials:
-A vacuum chamber, preferably in a spherical shape
-A roughing vacuum pump capable of reaching at least 75 microns vacuum
-A secondary high vacuum pump, either a turbo pump or oil diffusion pump
-A high voltage supply, preferably capable of at least 40kv 10ma - Must be negative polarity
-A high voltage divider probe for use with a digital multimeter
-A thermocouple or baratron (of appropriate scale) vacuum gauge
-A neutron radiation detector, either a proportional He-3 or BF3 tube with counting instrumentation, or a bubble dosimeter
-A Geiger counter, preferably a scintillator type, for x-ray detection and safety
-Deuterium gas (can be purchased as a gas or extracted from D2O through electrolysis - it is much easier and more effective to use compressed gas)
-A large ballast resistor in the range of 50-100k and at least a foot long
-A camera and TV display for viewing the inside of the reactor
-Lead to shield the camera viewport
-General engineering tools, a machine shop if at all possible (although 90% of mine was built with nothing but a dremel and cordless drill, the only thing you really can't build without a shop is scratch building the vacuum chamber)
Remove these ads by
Signing UpStep 1Assemble The Vacuum Chamber
Get two stainless steel hemispheres, purchase two corresponding conflat-flanges (8" flanges in my case), bore out holes for accessory flanges, and then TIG weld it all together. Flanges are typically either of the KF or the conflat style. Conflat can be seen in the image below as the flanges with bolts, and KF (kwik-flange) are seen as those with only clamps holding an o-ring on the mating surface. Only weld on the inside, never on the outside (since virtual leaks can be formed if both inside and outside are welded). If you've never TIG welded before, it would be wise to have someone with experience do it as the welds must be flawless with no pin-sized holes or porous areas to hold a vacuum.
After machining, thoroughly clean the chamber and avoid getting fingerprints in it since these will outgas, which means at vacuum pressure molecules in the oil of finger prints or machining oil will become vapor and make it hard to maintain plasma stability or reach a good ultimate vacuum level.
P.S. impressive
But is it possible to use nitrogen to fuel the reaction instead of Deuterium gas?
I've read that one problem with Farnsworth type fusors is that the central wires have small radius ergo a high voltage gradient ergo much of the 2H is ionized near the center of the chamber (which is bad). I wonder if this problem could be lessened by inducing large gradients on the interior of the vacuum chamber with, say, a bunch of steel pins welded on?
The ionization location can be easily solved by placing an ion gun near the outside of the chamber, although it isn't necessarily that big of an issue.
Can you give me an estimated cost to build what you did?
Also do you have to TIG weld the parts or can another type of welding work?
One last question what type of shielding other than the lead did you use?
and thank you for the information
Once again thank you for the info
I was just reading another instructable about how to make tasty cupcakes, and before that how to make leggings that glow in the dark, but this takes instructable.com to a whole new level! keep up the good work
