3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build A Fusion Reactor
Step 4Assemble The Deuterium System
Deuterium gas is used as the fuel for this fusion reactor. You will need to purchase a tank of this gas (unless you wish to do electrolysis on heavy water, this process will not be documented here but nothing more than a small Hoffman Apparatus is required - higher purity gas can be gotten from a compressed tank).
Attach a high pressure regulator directly to the tank, add an extremely fine-metering needle valve after this (or a laser drilled orifice in the range of 5 microns), then attach this to the chamber. A ball valve can also be installed between the regulator and the needle valve since needle valves are not shutoff valves.
See the attached diagram now updated with the deuterium handling system.
4 comments
Jan 2, 2011. 4:16 PMM4industries says:
Where is deuterium bought?
Apr 15, 2012. 12:06 PMgaragegenius says:
i was looking at airgas and one of the required field was a company affiliation. i was wondering what i should put in.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
28
Author:christensent
