Step 5High Voltage
The difficulty is that it is often difficult if not impossible to find an appropriate fully assembled DC supply of this voltage level that is affordable to the amateur scientist.
Pictured is my high frequency ferrite transformer pair, with a 4-stage multiplier seen behind it.
If a fully assembled power supply (typically manufactured by either Glassman or Spellman), there are a few options:
-Find an x-ray transformer, and if necessary either reverse the rectifiers for negative polarity or add rectifiers if it has none (an x-ray transformer core won't have rectifiers, it probably will if it is in its oil tank)
-Build a switching high frequency ferrite power supply. This is what I did, however it requires a bit of EE experience since several aspects must be resonant and if it is ever taken out of tune, the transistors will burn out. Probably not the best option for people with little electrical background.
is to be expected when the plasma runs?
GFWhell
