The concept for BaR2D2 was born when a friend showed up to an event with a radio-controlled cooler. We joked about taking the idea to the next level and in the Spring of 2008, construction began.
If you enjoy BaR2D2 as much as we have, be sure to rate this Instructable a 5 and vote for it in The Craftsman Workshop of the Future Contest!
Just a quick note about me - I am a regular DIY'r and don't have any formal robotics, electronics, or mechanical training. I have picked up most of my skills from various hobbies and projects, as well as my father who is a skilled woodworker. If you have a basic knowledge of woodworking and working with low voltage power, then you can build a mobile bar! Enjoy!
Remove these ads by
Signing UpStep 1Creating the Framework
Drill Press
Table Saw
Router/table
Hand Drill
Screwdrivers
Pliers
Wire Strippers
Soldering iron
Voltmeter
Various Clamps
Vise
Hammer
Dremel Tool
Utility Knife
Heat gun (hairdryer will work)
Welder
Air Compressor
Air Stapler/nailer
Socket Set
Belt Sander
First, purchase a sheet of 4ft x 8ft x 3/4 inch plywood. I used the flooring grade as it will be covered later.
Cut the sheet into 8 2ft x 2ft squares and mark their center points by drawing an X across the middle from the corners. Drill a 1/4 inch hole in the middle of them.
Using a router table, measure out 9 inches from the edge of the cutting bit and bolt your wood square loosely to it. Turn the router on and plunge it slowly upwards until it goes through the wood. Lock the router in place and proceed to rotate the squares until you complete the circle. Repeat eight times. This will give you 18 inch circles. Why 18 inches? I am using an off-the-shelf plastic dome that is that size. Specifically, it is a clear dome from Aspects used for bird feeders. This was purchased from a bird store for $35. The shot dispenser we are using is available on ebay new for $30.
Three of the circles will be cut into rings. To cut out the centers, I made a quick jig as pictured to be able to rotate the circles against it. Two of the finished rings should be 1.75 inches thick and one will be 1 inch thick.
Take one of the circles and setup the router to create a groove about 3/4 through the thickness for the dome to sit in.
![[funny] How to Act in a Bar: Bar Etiquette No-No's #6 - Challenging the Bartender](http://img.instructables.com/files/deriv/FWY/71GM/GNSNIW25/FWY71GMGNSNIW25.SQUARE.jpg)
![[funny] How to Act in a Bar: Bar Etiquette No-No's #7 -](http://img.instructables.com/files/deriv/FF1/47T4/GNSNIW3B/FF147T4GNSNIW3B.SQUARE.jpg)
http://www.sidebarbeverage.com/Sidebar_Instruction_Man.pdf
or another is have an electronic valve..
It looks like yours has a lot of weight up high, and a tripod wheel arrangement that looks even tighter than mine. How do you get stability? What is the total weight of the robot? Has anyone ever been "heavy handed" at a party and knocked it over? Mine gets overturned at Halloween.
I am taking a 2nd shot at getting the AGC schematic on the site (for the neon driver). Another comment about modulating lights to music: I have never seen anyone else have lights that are on and get dimmer with the music. Having lights in pairs (one dims, one brightens) guarantees that the amount of light is constant, but where it comes from changes. No blackouts when the song ends!
Trimpot V3 sets the level the AGC regulates to. Meter (or LED) indicates whether the circuit is getting enough/too little/too much audio.
Your neon driver probably will need work. You need an input that causes the neon to smoothly brighten/dim as the control voltage is changed. You will most likely want to regulate the current to the driver rather than the voltage. You can use LM324 (4 opamps in an IC) instead of 741.
You can run this on one voltage if you float +input of integrator to about +3V (use resistor divider between +V/GND), and feed GND into R18. You may also need AC coupling/bias network going into U1.
facebook name:
Bartwo Dtwo
http://www.instructables.com/id/Occupational-Therapy-DexterityCognitive-Aid/
Jamie
would be cool with some more pictures
jamie
I still do not understand your method of wiring between the radio controller/receiver and the speed controllers. Can you send me the sketches that you made for the wiring? Do I have to use the servo - and does it take signals from the radio controller? Thank you.
BaR2D2 rulez
Will you be my friend?? LOL
