3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Automatic Window Blinds Controller (PICAXE)
Step 11Alternate Setup Method
If your computer is not close to the window or you just don't want to go through the setup procedures in the previous step there is an easier way to do it.
However, easier is not always better so read this carefully before you decide which method you want to use.
This alternate method requires that you open the blinds and use the position adjustment switches to set the open position exactly where you want it. That's it. You are finished. The setup is complete. However, you need to know that this method will possibly shorten the controller's battery life with the additional unecessary motor operation.
If you decide to use this method, you may want to increase the close pause time in the program by a thousand or two (1-2 seconds of motor run time). This will insure that the blinds close completely. This won't present a problem for the blinds or the controller. Most blinds can be turned several more turns after the blinds are actually closed with no problem and the gear motor has a slip clutch built in to prevent ripping its guts out in a stall.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
84
Author:biochemtronics
After a career in industrial electronics I went back to college and now do DNA research.
