3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Automatic Window Blinds Controller (PICAXE)
Step 9Program The PICAXE
Program The PICAXE
(You can download this code (Light Activated Blind Controller v.1.2.BAS) by clicking on the link at the bootom of this page.
The actual code starts after the line below:
symbol Relay = 1
symbol Motor = 2
BEGIN:
readadc 4,b1
' this line measures the outside light level
if b1 > 240 then goto OPEN
' increase this number (240) to make the blinds open later in
' the morning - decrease it to open earlier
if b1< 200 then goto CLOSE
' increase this number (200) to make the blind close earlier in
' the evening - decrease it to close later
goto BEGIN
OPEN:
if b3 = 1 then goto BEGIN
' this command prevents the blinds from trying to open again if
' they are already closed
high Relay
pause 10
' this command delays applying current to the motor until the
' relay contacts are closed
High Motor
pause 6600
' adjust this number (6600) to tweak the blind open position
' increase to open more - decrease to open less (see note below)
low Motor
pause 10
' this command delays opening the relay contacts until after
' current is cut off to the motor
low Relay
let b3 = 1
goto BEGIN
CLOSE:
if b3 = 2 then goto BEGIN
' this command prevents the blinds from trying to close again if
high Motor
pause 6150
' adjust this number (6150) to tweak the blind closed position -
' increase to close more - decrease to close less
' (see note below)
low Motor
let b3 = 2
goto BEGIN
' NOTE: when making adjustments to the open and closed blind
' positions, it is usually best to adjust only one of these
' settings as each will affect the other
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
84
Author:biochemtronics
After a career in industrial electronics I went back to college and now do DNA research.
