3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build A Net Gun
Build A Net Gun
I will show you how to build a net gun out of materials available at any big box home improvement store. This net gun is capable of firing a 90 square foot net 15 to 25 feet using 80-100 psi of compressed air. The net is reusable, assuming your prey doesn't destroy or run off with it. The launcher section is modular and can be removed in case you want to use a different design or add attachments. Thread on some 1" PVC pipe and you have a Christmas Cannon, or check step 11 for how to build a tennis ball launching attachment.
The net gun is similar to many pneumatic launchers, but instead of launching a single projectile, it launches four tractors that pull the net through the air. The tractors are based on the fact that the neck of a standard soda bottle fits very well over the outside of 1/2" PVC pipe. The cost to build this will range from approximately $40-$75.
Step 1Materials
Materials
Before you begin be aware that this project uses PVC pipe in an application it is explicitly not intended for. PVC is meant for water, not pressurized air or other gases. The problem is not the pressure, this project uses pressures less than half the working pressure of any PVC component, but the failure mode when pressurized by gas. If the PVC is compromised, by dropping, impact, or other means, it shatters into sharp pieces that are ejected by the pressurized gas. An excellent discussion and demonstration here, make sure to watch the video through to the end.
Nearly all of these items can be picked up at your local home improvement retailer. It is probably worth buying a full 10' length of 1/2" pipe, for all the other sizes see if you can buy shorter lengths or scrap. Alternatively, get some friends together, share the costs of the full length pipes, and build a lot of net guns. The tire valves are available at auto parts stores. The net is addressed in detail in the next step.
SUPPLIES
All PVC fittings are slip fit unless otherwise noted
All PVC pipe and fittings must be SCH-40 (SCHedule 40) unless otherwise noted
All PVC pipe should have a PSI rating of 200 or greater, absolutely no cell core ABS DWV pipe
  • Pressure chamber parts Fig 1
1 1" MPT (Male Pipe Thread) to 1" slip street elbow
1 1" elbow
1 2" to 1" reducer bushing
1 2" cap
1 2" coupler
1 foot of 1" pipe
minimum 9" length of 2" pipe
**1 valve stem, prefer a .453" as it corresponds to the readily available 7/16" drill bit
optional 1 pressure gauge
**There are two standard size automotive valve stems, one for a rim hole sized .453" the other .625". These two sizes correspond to fractional drill bit sizes of 29/64" and 5/8" respectively, the much more common 7/16" bit can be substituted in place of the less common 29/64". Additionally, most common drill indexes stop at 7/16" or 1/2" and do not contain the larger 5/8" bit.
  • Trigger valve parts Fig 2
1 Orbit Model 57461 1" sprinkler valve
1 Blow gun similar to this
1 1/4" NPT hex nipple, like this
  • Bending jig
3 2"(ish) wood screws
Wood scrap for base, a 16" length of 2x4 should work fine
  • Launcher section Fig 3
4 13" lengths of 1/2" pipe
1 1/2" cross
2 1/2" tee
4 1/2" street elbows
4 1-1/2" pieces of 1/2" pipe (coupler joiners)
1 1-1/2" pipe 9" long
1 1-1/2" coupler
**1 1-1/2" to 1/2" reducing bushings
** 1 1" MPT to 1/2" slip
1 nickel
** these transitions usually can't be made with one adapter, just make sure the starting and ending dimensions are correct.
  • Net
Memphis Net and Twine sku# 263 1lb minimum order is enough to make 7-8 nets
OR a substitute net computed using the net math spreadsheet and instructions in step 2
Nylon mason's twine (#15 or smaller), kite string, or some other thin durable rope
4 per net 16-20oz carbonated soda bottles
4 per net zip ties > 4" long
Hot glue/silicone/wax to pour in bottles to add weight
Optional additional items needed for high performance net tractors
4 per net 3/4" couplers
4 per net 3/4" caps
4 per net 8" lengths of SDR-21(Class 200) 3/4" thinwall PVC note: regular 3/4" SCH40 will NOT work!
4 per net 12" lengths of non-adhesive 1" ID foam pipe insulation. Pipe insulation is generally sold in 6' lengths.
  • Consumables
PVC pipe cement and primer
PVC safe pipe joint compound (pipe dope) such as this
Teflon tape
Sand, at least two cups worth (for bending the launcher arms)
2 1/2" pvc caps (for bending launcher arms, not part of gun)
Epoxy for modifying sprinkler valve
Thread locker (Loctite)
  • Tools & Safety
Saw, for cutting PVC pipe
Heat gun, propane torch, or candle for bending PVC
Drill
3/16" and 7/16" (or 5/8" see the **note in the pressure chamber section) drill bits
Tape measure
Utility knife
Dremel tool, or similar, with a sanding drum
Wrench for 1/4" npt hex nipple
Large adjustable wrench or channel-lock pliers, for tightening the trigger valve
A compressor or pump capable of attaching to a Schrader tire valve and attaining at least 80 psi
Safety glasses
Leather gloves
« Previous Step   View All StepsNext Step »
628 comments
1-40 of 628next »
Jan 4, 2009. 6:26 PMits_me says:
hehe, you used pythagoras theorm, nice. :)
Jan 6, 2009. 12:30 PMjoshlosh says:
What's up with this ABS talk? Are you an ABS sales rep? Let it go. Nobody is going to pressurize this to 800 psi. If they do they're not following the design. Besides, I'm pretty sure the joints or the valve would go out long before the pvc shattered. And good luck tracking down all this in ABS at your local Home Depot.
Mar 28, 2009. 12:23 PMPwnimusPrime says:
I built a potato cannon out of ABS, and all the parts were purchased at Home Depot. I agree that ABS is a bit of overkill, but Home Depot actually has every item he lists.
Apr 16, 2012. 11:07 PMengineering wizard says:
i agree i made one that used propane to shoot the potato instead of it shattering it just melted the seal of the plug oops my bad T-T
Mar 22, 2012. 10:18 AMDa Person who plays paintball. says:
Would it be possible to use a paintball tank to power it.
(my question mark is finnicky)
I mean, most tanks can be adjusted to have a low output.
Dec 18, 2011. 2:12 PMtvane1225 says:
how i met my girlfriend
Mar 12, 2012. 8:17 AMChuckmasterFlex says:
haha love it
Jul 15, 2011. 4:30 PMktung says:
where can I buy all the materials ?
Aug 7, 2011. 2:34 PMhunter55 says:
home depot tracktor supply harber frait autozone
*TRACTOR Supply; Harbor Freight. Good grief.
Jul 30, 2011. 8:28 PMJRFrank73 says:
i purchased most of the PVC at home depot, the sprinkler valve at homedepot.com, thinwall PVC at a plumbing store, and the psi gauge and valve stem at autozone.
May 31, 2009. 5:43 PMDnorton says:
Here is where it is leaking. It is passing the diaphragm and out the valve outlet but I cleaned it as well like the troubleshooting guide said and it made no difference. Is there anything else it could be?
May 31, 2009. 5:45 PMDnorton says:
Oops wrong image but the inner ring that the diaphragm seals is where it is leaking.
Mar 2, 2012. 8:41 AMkingcole816 says:
My valve is leaking air through the outlet and won't hold any pressure. My first inclination was that the diaphragm was defective, but i replaced it and I'm still having the same issue. My valve doesn't have the bleed hole in the outlet port, so I'm wondering if that could be creating the pressure issue. It still has the open notch that is connected to the bleed hole, but the hole itself isn't there. It's the model you recommended, but I'm working with it years after you wrote the article so they may have redesigned. Hopefully you still check this forum because I *really* want to finish this thing
Feb 23, 2012. 12:56 PMNobahd says:
PLEASE READ PPL!! word to the wise coming from a plumber of 6 years DO NOT USE PVC. pvc is the reason kids blow there fingers off building potato cannons its not ment for this type of use , use schedule 40 ABS just as cheap and you wont get hurt AGAIN SPECIALLY FOR THOSE KIDS THAT BUILD THIS TYPE OF STUFF BEHIND THERE PARENTS BACKS AND END UP GETTING HURT IVE SEEN AND HEARD IT MANY TIMES !!! DO NOT USE PVC !!! i realize pvc is "rated" over 100 psi but just because a test pipe at the factory could handle it does not mean all pvc pipe made will be able to take the pressure and thats how ppl get hurt always use ABS
Feb 22, 2012. 10:44 AMjoeyboi586 says:
i know this is my fourth time posting but i really need help i cant find net anywhere i cant find bird net at any of the home depots and i've seen pond nettign but i think that holes are to small i just really need help from where i can buy th enet other than online somewhere i can pick it up like gander mountain lowes home depot walmart please its all i need to finish this project and i really want to finish
Feb 20, 2012. 2:02 PMjoeyboi586 says:
sorry for the multiple comments but for the tractors can you use sdr 25 or is sdr 21 required
Feb 20, 2012. 1:46 PMjoeyboi586 says:
would you have a link to a website that excepts pay pal with a net that is correct
Feb 20, 2012. 1:44 PMjoeyboi586 says:
for the net could you give me a link for amazon cause i don't want to put my credit card on that website plus shipping is very expensive or a link from a website that excepts paypal
Feb 4, 2012. 9:43 PMredwizard87 says:
does anyone have a pic on what the blow gun should look like the link dosent work anymore
Jan 5, 2012. 2:30 PMthe purple panda says:
Thanks for the messages. I got only one more question for right now. how far does the t.ennis ball fly? Thanks so much for the anwsers to!
tu eres muy muy simpatico.
Jan 4, 2012. 2:25 PMthe purple panda says:
just got done with the net gun took me three days to build it. we have been launching it at 75 PSI. but whats the most you would put in it with out it exploding?
Jan 3, 2012. 3:39 PMthe purple panda says:
A another question sorry. There are diffrent a attehments for this. there is the net gun one and the tennis ball one. but how long does the tennis ball fly?
Jan 3, 2012. 3:28 PMthe purple panda says:
crispyjones, thank you very much! By the way awsome project it will make my son very happy. : )
Jan 2, 2012. 3:32 PMthe purple panda says:
a really i need some one to tell me please/ I have been waiting for some one to type back my last two messages. I have all the pieces and now I'v been stuck for a month now. Please someone read my two messages and anwser then if you can.
Dec 18, 2011. 3:15 PMblack hole says:
Handy for little brothers running off with your money. ; )
Dec 11, 2011. 10:28 AMthe purple panda says:
And why do you not wnat to get 3/4" SCH-40 for the tractors,will they not fit?
Dec 11, 2011. 10:14 AMthe purple panda says:
A dude awsome. Im building one and i dont get one thing.Do you need a 1/4" ball valve? Or is that to some other project of yours?
Dec 1, 2011. 9:27 AM1dog789 says:
EPIC XD
Jan 10, 2011. 8:05 AMMeGravity says:
What's the used CAD package... looks lovely. I have to permit that I didn't read through the whole article so far ;-)
Thx
Nov 4, 2011. 3:11 PMjmcconnell5 says:
it was Google Sketchup
i have that!!!
Nov 14, 2011. 5:19 PMstevenh429 says:
dumb question: would this work?
http://www.homedepot.com/h_d1/N-5yc1v/R-100098062/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
1-40 of 628next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
116
Author:crispyjones
