3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build A Net Gun
Step 11Et cetera
Et cetera
Thanks for all the positive responses so far. I will post updates to the build and attachments here. I came up with the safety after negligently discharging a net while filling the pressure chamber. It is so easy to make, every responsible net gun owner should have one. I developed the tennis ball attachment while working on an older net gun design that had a 2" net holder, it is a lot of fun for the $3 it costs to make.
Mechanical Trigger Safety
A very simple mechanical safety that will prevent the net gun from firing in the event the trigger is unintentionally actuated.
  • Supplies
Scrap 1/2" pvc pipe
Small rubber band
Assembly
  • Cut a short length of 1/2" pipe, probably between 1/4" and 3/8", it will depend on the specifics of the blow gun. It needs to fit under the blow gun handle and be thick enough to prevent the handle from depressing the valve underneath. You made need to cut a wedge out of one side of the ring to allow it to slip under the handle.
  • Loop rubber band around one end of ring, and through itself. Take the free loop of the rubber band and slide onto the body of the blow gun valve.
  • To put ON SAFE, slide ring around brass valve underneath lever Fig 1. To take OFF SAFE, slide ring down and out of the way of valve and lever Fig 2.
Tennis Ball Launcher
The inside diameter of a 2" PVC coupler fits a tennis ball perfectly. If you own a ball chasing canine, this will forever associate the bang of compressed air with the joy of the chase.
  • Supplies
1 1" slip to 1" MPT adapter
1 2" coupler
1 2" to 1" reducing bushing
2" length of 1" PVC pipe (scrap from pressure chamber assembly)
At least one tennis ball
PVC primer and cement
Assembly
  • Fig 3 is a view of all the components needed for this attachment.
  • Glue the bushing into the coupler.
  • Glue the 1" pipe into the slip end of the of the 1" MPT adapter.
  • Glue the exposed 1" pipe from the MPT adapter into the bushing. Let set for 24 hours.
  • Unscrew and remove the net attachment, and thread on the tennis ball attachment. With tennis ball on the ground push the launcher attachment over the tennis ball until it is firmly seated Fig 4.
  • Pressurize and fire. Repeat as necessary. If you have a slobbery dog Fig 5 you will appreciate not having to touch the drool covered ball.
updated
« Previous Step   View All StepsNext Step »
14 comments
Oct 9, 2009. 7:58 AMNykus79 says:
Look like I has found weapon non-leathel to use on police who chase me after i did something break laws. it should slow them down
Jan 22, 2011. 9:38 AMToddisI says:
lol
Aug 29, 2009. 2:57 PMmazingbrainiac says:
about how fast, (fps) or (mph) does the tennis ball go?
Oct 29, 2009. 5:29 PMqwiboh says:
 so above 2' per hour
Apr 13, 2010. 8:06 PMElectricMan1 says:
Use Distance (m) = S (speed in m/s) * T (time in sec)
then multiply what you get by .44070
Theirs your speed in MPH.
Mar 19, 2010. 11:26 AMgadgetgizmo says:
 Have you designed a more polished trigger system?
Sep 13, 2009. 6:31 AMfart muffin says:
cool dog :)
Jul 6, 2009. 2:44 AMPurpBeast says:
I made a wine cork attachment. Shoots those things hard and fast.
May 20, 2009. 5:08 PMknoxville says:
Would you recommend drilling the PVC piping to make sure that it has an extra hold on each other, or would the epoxy glue be enough?
May 21, 2009. 8:20 AMknoxville says:
I was wondering with the constant release and increase of pressure would the glue hold it in place? I was wondering if i could/should use screws to help hold the gun in place.
May 21, 2009. 2:17 PMknoxville says:
alright good point thank you very much.
Apr 26, 2009. 7:23 PMsasha098 says:
well, it took me two days but i did it.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
116
Author:crispyjones
