3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build A Pair of Stereo Speakers
Step 11Preparing The Insides: Part 1: Crossover Unit and Drivers
  • last photo ←
We are almost done! the next thing to do is mount everything in place and wire it all up.
First we need to mount the crossover unit. I chose to mount it on the bottom of the box. All you have to do is drill a few holes into the bottom of the box and screw it down. I recommend placing some rubber between the crossover unit and the bottom of the box to prevent rattling. If you have a blown bicycle inner tube, those work perfectly, else rubber can be found in many places.
Next mount the speaker drivers. Get some machine screws and nuts that fit the mounting holes in the woofer and tweeter. Drill corresponding holes along the little shelf we routed out in the particle board and then bolt down the drivers! To enhance the look of your speaker, spray paint the screw heads a different color!
The wiring is VERY simple to do. Two wires for the positive and negative leads enter from the terminals and connect to the crossover unit. Two wires (positive and negative) leave the crossover unit and connect to the woofer. And lastly two wires leave the crossover unit and connect to the tweeter. See the wiring diagram for clarification. You will need a soldering iron and solder for this.
Some new stuff (added august 4th): Zobel Network!
Since the woofer is quite large, its impedance rises due to self inductance. The crossover does not take into account this higher resistance. This in turn causes the woofer to sound 'loud' at frequencies close to the crossover frequency. If your woofer is large like this, consider installing a Zobel network across the terminals of your woofer to improve sound quality. The Zobel network will help to restore the impedance to a lower value allowing the crossover to preform correctly. Here is more on Zobel networks. This network consists of a resistor and capacitor placed in series between the terminals of the woofer. For my speakers a 100V non polar electrolytic capacitor and a 10 ohm 10 watt resistor should do the trick (partsexpress has them for pretty cheap). I haven't actually added this in yet but am planning to in the future.
6 comments
Feb 21, 2011. 7:41 AMExiumind says:
Hmm how do i know the driver inductance in order to calculate the zobels components?
Maybe i'l try to build an active variable x-over..
thanks =)
May 4, 2011. 1:23 AMjedi2010 says:
"100V non polar electrolytic capacitor"
Did you mean 100uf,,i think microfarad is the unit of measurement for capacitance?
Jan 25, 2011. 11:46 AMjrigvd says:
couldn't you solder the speakers before you screw them in place???
(sorry for my bad english, im just a student)
May 4, 2011. 1:15 AMjedi2010 says:
im thinking this also,since its tricky to solder in twitter or tight spaces..
Oct 13, 2010. 6:21 AMueharaf says:
(sorry for my english) What happen if you put the (-) negative cable on the positive output of the amplifier, it can destroy the speakers?
Feb 10, 2011. 12:23 AMmwwdesign says:
Not much except that you would be running the speakers out of phase (by 180 degrees), which basically means the cone will move in when it should move out and vice versa. Would sound mostly the same, except bass could suffer most.
Deliberately running speakers out of phase is used to stop standing waves in audio installations (high and low points in the room from speakers interfering with each other).
Hope that helps?
Jan 16, 2011. 5:12 PMnatman says:
i think it would work as a basic microphone
Mar 18, 2009. 1:35 PMbmxking2727 says:
hey thanks your wiring diagram really helped me out.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:billbob
