Step 10How to use the plasma speaker
The 10K potentiometer is used to change the TL494's internal oscillator frequency - from 5KHz to 50KHz. If you want to play music on the arc, tune the frequency up until you don't hear it and play the music. Note: The 10K potentiometer does NOT affect the input audio (music).
I am not too sure what the 22K potentiometer's job is, but it seems to change the volume of the audio, fiddle with the 22K potentiometer until you can hear the music loudly. Note: Making the music louder will shorten the length of the arc.
I haven't even built it or tried it. It will be just as hot as the original, but avoids the cost of the inverter driver IC (since the TL494 already has an inverter built in).
It probably runs cooler than the Instructables circuit, though, since it has a driver FET for each power FET, which should cause them to turn on and off faster and waste less time getting hot. (But again, I haven't built any of these.)
Also the two pots are labeled. The 22k pot sets the frequency in this circuit.
Full-size:
http://www.instructables.com/files/orig/FVE/I3SC/FR123O01/FVEI3SCFR123O01.png
Here's a good explanation:
http://homepages.which.net/~paul.hills/SpeedControl/Mosfets.html
Yes, you could do this with only the two main MOSFETs, but it will be even worse for heat and efficiency, since the driver FETs in this circuit serve the same purpose as the driver ICs. Replacing these driver FETs with dedicated driver ICs would be best.
What 555 timer design are you looking at?
http://homepages.which.net/~paul.hills/SpeedControl/MosfetBody.html#4
