Step 5Build the prototype on the bread board
Why on a bread board and not build it directly onto the veroboard?
Well, it is a very good idea to build the prototype on the bread board before you solder the components onto the veroboard because...
- You will get a better idea on how to build a 'real' one on the veroboard.
- You can make sure all the components are working fine, if not, you can replace it easily.
- You can modify or tweet the circuit a bit to give the plasma speaker a better performance.
To connect the flyback transformer to the circuit, wind 5 or more turns of thick solid-core wire on the ferrite core. That will be your primary coil.
Wouldn't it be much easier to drive the MOSFET with a micro controller though? You'd pretty much only need 2 components (aside from the flyback stuff).
im 16, a junior in high school, and i decided to do your plasma speaker experiment for my science fair project. i brought the idea with all the info to my chemistry teacher and she said it was the most incredible thing in the world. she agreed along with another school science teacher to help me out with it. i have ordered all the parts u have specified and now im just waiting for them to all arrive. im just wondering do you have any tips or helpful pointers to keep me from screwing this thing up? thanks!
Look, its internal... the WHOLE POINT of mosfets are to give square pulses. This is possible because of the diode inside it and the electrical switch.
To lower Amparage you could use a larger resistor value. But the amperage is NOT the only issue. Too long to explain, but there is just too much stress on the mosfet in this schematic. I created the original, the stress is halved... so mine is fine.
You CAN add a diode... I feel I should add this.
However, there is no reason to... theirs already a diode IN the mosfet.
He posted it, but w.e. Yeah, its actually old. Steve has posted more recent ones that are better (I recommend an AC circuit, audio is usually better.)
If you do use that schematic make sure R5 and R11 have a higher amp rating.
4hv.org
Feel free to ask questions there... the author is actually a MOD there :)
Good luck with your project, I had alot of fun with mine.
You could use the primary that alredy is there, but it has like 30 windings.... so it would be better you would wind a new...
There is One secendary and it has one wire Red thick... the older ones don't have a rectifier but the newer have.. and the other wire is gnd some pin on the bottom.... and if it has no rectifier then you can mesure the resistance... you could get like 70 Ohm.... or so.. but those with diodes and cups in them(the newer ones) you can't mesure...
Also you have a fiew more secenderis.. and they have much less windings compered to the secendery you use for hv. and you don't use them.... becose the voltage is verry low.. like 100V... or so.
you need the red thisck wire.. and the gnd.. and if you use the primary on the flyback your hv will be lower.. because of this it is better to wind 5 turns of wire on the core...
as for the gnd pin, take the red thick wire. and move it neer the pins.. (ofcors you would need to turn on your driver for this ) and from witch pin you get the longest arc.. use that.. solder a wire on it. and use ti.. and the other connector insulate ... with hot glue or something else...
It would be nice if you could ground that wire... but separate from the driver....
