Picture of Build A Power Supply For Your Guitar Pedals
If you're like me, you know how annoying it is to use up 9V batteries on your guitar effect pedals.  Its wasteful, and brand name 9V's are almost $9 for a two-pack.  If you forget to turn off your pedals you've thrown away big bucks.  Its an extreme waste of money when you can build your own power supply for only about $25.The power supply I designed and built delivers steady, regulated 12 volts, 9 volts and 5 volts all at the same time.  Each voltage has two outlets, but they can be "daisy chained" with a custom cable to connect many more pedals.  The styling is an homage to the old days of vacuum tubes, when components generated so much heat they needed to be on the outside of the casing instead of inside.  I used some gigantic capacitors that I thought would look cool, other than that they are major overkill. In this Instructable I am going to assume that you know some basic electronic skills and know what I am talking about when I say capacitor, resistor, LED, transformer, AC and DC, etc.  There are lots of introductory electronics Instructables and soldering Instructables you can check out if you'd like to gain a better understanding of basic electronic principles and components.IMPORTANT NOTE:  Depending on what pedals you intend to use this for, you should take care to wire the DC connectors as pin-positive/ring-negative or pin-negative/ring-positive.  The latter is the industry standard way of doing it, although it poses issues when building a pedal that has a metallic housing.  I prefer pin-positive/ring-negative because of that issue, and I wired this supply in this way.  Please take care as to which way you wire the power supply to prevent damage to your pedals.
1-40 of 251Next »
sir i have a transformer 220v to 12v outputs my problem is the transformer is have 3 pins 12v 0v 12v what should i use the 12v and 0v?
There is a way to use a center-tapped transformer without getting too high a voltage if you just ignore the center tap. This is done with a full wave rectifier as shown here:
http://savedonthe.net/image/1761/full_wave.png
Just replace the bridge rectifier in my circuit with two diodes to make a full wave rectifier as shown.
hi sir in your diagram where did you put the the two 1000uf volts capacitor and 3 10 uf 63v because in the diagram only 100uf numbers no voltage included sorry sir im a newbie -_-
because i count all the capacitors in the diagram there are 6 and the one i saw in your pictures is only 5 can you plase create a diagram that shown all the name of capacitors thank you sir for all the help
The value and quantity of the capacitors really isn't that important, what is important is where they are located and that the voltage rating for them is higher than the maximum voltage they will be subjected to. Subjecting a capacitor to a voltage higher than its rating can and will cause it to burst or explode. Just google this to see why you don't want this to happen.
Capacitors after the rectifying diodes (before the regulators) and after the regulators (a requirement stipulated in the 78xx regulator datasheet) is all you need. If you have major noise problems being caused by the power supply after it's built, I would suggest to add some more capacitors in parallel with the existing ones to help smooth out the voltage.
The 10000uF capacitors are oversized. They are functional but their huge value is partly cosmetic. Feel free to substitute a single 1000uF if you'd like, there shouldn't be any issue.
More info if you want to learn about it
http://www.daenotes.com/electronics/devices-circuits/center-tapped-full-wave-rectifier
mau12.1628 days ago
Dude. I want to have 9v 8 outputs. What should I do? I already get it in replacing the other 12v and 5v regulators with 9v one. How to add another 9v in the circuit? Thanks
mattthegamer463 (author)  mau12.1628 days ago
Just add some more regulators and capacitors. If you add one more (4 total) you can put two pedals on each and have your 8 outputs.
JohnF74 months ago
ahhmm, i dont get it. im sorry, you have used 18v transformer right? so, i will remove the transformer there in your tutorial and replace a transformer that can work at 220v ac? im sorry man, i am confused.. by the way im from Philippines. we have 220v ac here
mattthegamer463 (author)  JohnF74 months ago
Sorry I misunderstood. I thought you were asking how you could do this without a transformer at all. The transformer outputs 18V but takes in 110V AC. Plugging a 110V transformer into 220V will cause the output to be 2x higher, but you will be able to buy a 220V to 18V transformer there in the Philippines. The input and output are referred to as "Primary" and "Secondary" coils, which will be rated for 220V and 18V respectively.
Hi.. So can I replace your transformer with 220v AC with 18v AC secondary rating?
Yep, that's the way.
JohnF74 months ago
man, thanks for this tutorial. but i live in a country which i get a 220v ac., what can i do if dnt wanna use transformer? thank you. im a newbie in electrnics.
You have to use a transformer. There isn't any practical way to make 9V DC from 220V AC.
Huh? Of course you can do it with a Zener diodes. E.g., please read this: http://www.designercircuits.com/DesignNote1a.pdf The other question is that it is not always that safe and if you have crappy jumping power, then all your pedalboard might puff in smokes, once you use Zeners at the limit. Transformers are just nicer and safer.
mattthegamer463 (author)  bo.maryniuk1 month ago
I would never suggest someone not use a transformer for this kind of thing, especially for 220V AC. Not just for safety reasons, but for practical reasons too. If you do the math on a zener regulator circuit, the voltage drop resistor would need to dispose of more than 10W of extra power to get 50mA on the output, enough for only one or two pedals. Also, he says he is new to electronics, which frankly means he really shouldn't be messing around with 220V AC without the knowledge of how to be safe. Transformer or no, 220V AC is dangerous.
So with that transformer you can only use 300ma worth of pedals correct?
mattthegamer463 (author)  evan.stoddard1 month ago
Pretty much. Won't be hazardous to go over that a little bit though.
Gotcha.
Or do you get more since you're dropping to 9v?
Davidv36 months ago
is it a problem if you live in a country where you get 230 volt ac out of the power outlet?
mattthegamer463 (author)  Davidv36 months ago
No, you just need a transformer which has a primary rated for 230V AC and a secondary rated for 9V AC. Some transformers can be wired specifically for 115V or 230V, but probably most cannot.
what about SMPS?
mattthegamer463 (author)  Okoraokora12 months ago
An SMPS would work but the concern is that the SMPS high frequencies will cause noise and high frequency sounds.
Wouldn't a 230 – 12 VAC work too? And would the LM7809's be able to operate at all if the secondary was 9 volts? – The datasheet specifies a minimum input voltage of 11.5 volts.
It would, just that the more excess voltage you have at the unregulated DC stage, the more heat the regulator is going to generate and the less current you will have available at the output. Because the transformer current rating is selected to be higher than the current that is actually going to be used, it will be higher than 9V. The rectified and smoothed output voltage of a 9V secondary, with no load, t is probably 14-15V. Using a higher transformer rating would just produce more voltage the regulator will have to waste.
The dropout voltage in the datasheet is 2V @ 1A, but 1A is the maximum current for the part. It would probably take 8 typical pedals on one output to use that much current. The dropout voltage is lower at smaller current levels. A part like the TI LM2940CT-9.0 is an improved linear regulator design that only has a dropout of 0.5V @ 1A. It is pin compatible so it can replace the generic 7809 directly.
Thanks for the informative answer; exactly what I needed to know. :)
rocking0185 months ago
is this an isolated power supply or is that a whole different game?
mattthegamer463 (author)  rocking0185 months ago
One of these per output could be used to make a isolated supply. Cost could probably be about $20 + extra $6 per output.
http://www.digikey.ca/product-detail/en/PDS1-S12-S9-S/102-3012-5-ND/4006980
Totally different game. Isolated outputs require each output to have an isolating DC/DC converter (expensive) or a specialized transformer with many isolated output secondary windings (very expensive). With properly grounded cables, using an unisolated power supply shouldn't be a problem. Most retail units are not fully isolated either.
Jj.Diamante245 months ago
what will i do so that i'll have eight 9VDC outputs?
mattthegamer463 (author)  Jj.Diamante245 months ago
Multiply the regulators and output capacitors to get as many outputs as you want. For 8 outputs I would recommend at least 1A @ 9V transformer output current.
Matt,
I am a lil confused about your circuit diagram vs. your list of components. The diagram shows (4) 100 uF caps and (2) 10 mF caps. Your list is saying use (3) 10 uF and (2) 10 mF or (2) 100 uF for less overkill. I like your design and I wanted to build one, but I dunno if I should have 6 caps or just 5 caps?
You'll need a cap for each regulator output, so I would recommend you use one 10uF and two 100uF before the regulators, and a 100uF after each regulator, from the output to ground. To prevent any oscillations I would also add a 100nF in parallel with each of those output capacitors. This is good practice that I was not aware of 4 years ago when I did this Instructable.
LennertO5 months ago
What is the minimum current that the secondary side must be able to deliver?
mattthegamer463 (author)  LennertO5 months ago
The one I used only delivers 300mA. You could get away with less if you are only powering 3-4 pedals, and no vacuum tube pedals.
Hi Matt,
Very cool. Good work!
I just had to replace CO alarms. The old ones have 9V AC transformers. I recently bought a great pedal without a power supply that can take 18V DC. Can I simply run each of the two transformers from the CO alarms into diodes in a bridge rectifier configuration and connect the + and - from the diodes before sending them to a voltage regulator (I understand I lose some voltage). There isn't a good way to combine the transformer voltage before making it DC, is there?
Thanks!
mattthegamer463 (author)  stephen.silbert6 months ago
You should be able to do something like this
http://i68.photobucket.com/albums/i5/Morocotuco/XFORMERS-IN-SERIES.jpg
Putting the primaries in parallel and the secondaries in series will give you twice the output voltage. Be careful and test it out first.
THANK YOU!!!
1-40 of 251Next »
