loading
Step 4: Stitching And Rivets
I prefer to stitch by criss crossing the thread, as pictured. One thing I have a problem with is tying off the finished thread, so with nylon thread, you can melt it together. Be sure to use leather cement in between your seams for added strength. Punch any holes and rivet the holster as needed.
When I was making it I anticipated the snagging issue, so it's not a huge issue. You just have to allow for the sight to slide all the way through with ease.
Awesome design. Definitely inspired me to try for my Raging Judge. Does you front sight post snag very much? If so, any particular remedy?
This is really cool. If it didn't say scrap in the title you wouldn't even know it. It looks like you just designed it that way.
Thanks! I was going for an organic look while trying new techniques.
If you get an upholstery awl which it looks like you may already have, Harbor Freight sells them, and look online at y tube for how to do a lock stitch, it is a great way to finish out some stitching like that. It's also great for reinforcing any other areas that might need it. I've used the lock stitch to sew entire areas it's very strong. It is a little harder than it looks at first.
Thank you, I'll give it a try!
extremely nice.
Thank you
With the weapon resting that low, you will either need a really stiff backing the length of the holster, or a loop for a string around your leg. Otherwise it is really difficult to draw, because the holster follows the weapon.
You are correct, and I have been thinking about adding a leg strap. If you draw straight up then its pretty smooth.
About This Instructable
7,323views
114favorites
License:
Bio: I enjoy building things and being creative.
More by desertsniper:Scary Fairy Wand The Ultimate Prop Weapon Make A Custom Leather Wallet - FREE PATTERN
Add instructable to:
