Build A Surfboard Episode 3: Laminating and Vacuum Bagging
Learn to make a surfboard from the famous Johnny "V" Voxlund in Haiku Maui.
Continues the saga begun at
Build a Surfboard and
Episode 2: Sanding
Johnny invited me over to explain his bagging setup and watch him pull the board out of the bag. It was too hectic for spectators when he bagged the board due to a severe windstorm.
There's a lot going on in this photo.
He used UV cure resin so he had to make it dark.
He set up a tarp tent over the front of his shop to keep out sunlight. High winds made the tarp flap, making work very stressful. If the tarp blew away the board would be ruined by sunlight in mere seconds.
Step 1All in the Bag
All in the Bag
This board has a woven bamboo flame job on the deck.
It's structural as well as decorative. It makes the deck stiffer and prevents heel dings in the deck.
At the moment the vacuum is still sucking air out of the bag around the board. That compresses the whole board and clamps the bamboo matting down tight.
How did it all get in there?
Before putting the board Johnny worked on it outside in the dark tent.
He catalyzed some normal polyester resin and spread it on the underside of the bamboo matting. Now the clock starts ticking. That resin will set up in 1 hour.
Then he laid the glass over the top of that and squeegeed in the UV cure resin.
Now the board is vulnerable to sunlight.
1 comment
Apr 13, 2010. 1:00 PMImmortalSoFar says:
When I worked in a plastic bag factory, that's how the customers filled bread bags. The bags are on wickets, the fan blows open the top one and then a piston pushes in the bread, breaking off the top bag and allowing the fan to inflate the next one.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1186
Author:TimAnderson
Tim Anderson is the author of the "Heirloom Technology" column in Make Magazine. He is co-founder of www.zcorp.com, manufacturers of "3D Printer" output devices. His detailed drawings of traditional ...
more »
