Build Adjustable DC-DC Converter on Flowerpad Protoboard by ElecFreaks
Featured
Step 8: Power and debugging
Double-check the circuit again before power on it. Make sure there is no any short current between IC pins. Check whether connection between components is reliable. 、
Finally, confirm the input and output poles is no short circuit. Power on the converter  then rotate the potentiometer,you can adjust the output voltage, and the voltage display on voltmeter.
I use this DCDC converter to power a 5W HB LED over 30 hours. As the tested result, it works stable and reliable.
Thant’s All. Thanks and Enjoy !!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
