Step 9Warnings and Common MIstakes
1) Not being patient. It can take as long as a year to build one suit
2)Don't fiberglass the outside of the armor, and when applying your veil use small chunks, not big ones.
3)Don't forget to scale the armor to your body. The real master chief you are not.
4)Don't forget the under armor. It can be as simple as dark colored long johns, or as expensive as fancy pressure suits.
5)Not reading the safety instructions. Dust masks and eye protection a must.
like that in the desighner vesion?
or do you just pay to download?
what's bondo
a resin
and fiberglass the outside
do you mean fiberglass resin or fiberglass mats/installations
Resin means some form of 2-part chemically-cured adhesive - resin+hardener - which is applied to pepakura paper forms in order to harden them to allow them to be fiberglassed. It is also used in actual fiberglassing - see below. The resin can be applied to complex surfaces and be sanded and smoothed and painted, although using bondo on the outside surfaces can make it easier to make it really smooth. A surface which is JUST resin will be strong enough to stand on its own, but will be more brittle than a fiberglass piece and might break if dropped, which is why it is preferred to add fiberglass to pepakura armor parts.
Fiberglassing the outside (or inside) means applying fiberglass mat or cloth to a surface (inside or outside of an armor part - as I said, you want to FG the inside of the piece, so you don't lose outside details) and soaking it with the same resin mentioned above, allowing it to form a hard and strong form.
will that work for fiberglass mat
and fiberglass mat/installation supposed to be inside the armor and helmet
and what is foam padding used for?
please i need to know
i have most of the stuff
Yes, you want to put the fiberglass INSIDE the armor piece and resin it into place, as that will help you preserve external detail.
Foam padding would be used after the armor piece is actually built, in order to fit the part to the wearer (so the helmet will fit on your head, for example), and to keep sharp/rough parts off your body.
I will *STRONGLY* recommend to you and anyone else looking to make pepakura-style Halo armor (or any other kind of paper/cardboard-based fiberglass armor, whatever it's intended to look like) that you go to the 405th Infanty Division's forums at www. 405th. com (remove spaces) and check out the Noob Forum, where there are LOADS of tutorials and stickied threads for you to read up on all the stuff you need to buy and to do in order to build your armor. It's all right there.
can i ask more questions later if i need help again
I'd also like to note that for my first time it took me close to 8 months to build this. Granted I didn't work on it every day, but it much more labor intensive that you think. Each piece needs to be fiberglassed and you can only do so much at a time, cure for 2 hours, rinse repeat. Given I work 9-5, I could only do 1-2 curings a night and took me close to a month (working saturdays too) to get both coat down.
I didn't use the aqua resin, just the cheap stuff from Home Depot that's $15/gal. I used about 2 gallons of resin for the suit. Buy them in gallons at a time it's cheaper and you'll use it!
Also, when the fiberglassing is done, you'll need to sand the entire exterior of the suit. This was horribly tiring and itchy. You'll want to get a nice hand sander, old clothes that seal up completely (any dust getting on your skin will itch for days), goggles that completely seal around your eyes (bad news if dust gets in your eyes) and a good respirator rated for particulates, a simple cloth mask WILL NOT DO!
