3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build LED Glow Tubing
I love LED's and am always looking to use them in new ways. Especially for cool effects. I found a great way to couple a blue LED into 1/4 inch tubing. Then by filling the tubing with fluorescent liquid, a glow tube can be created. It took a little experimentation to get right and ended up being very simple. Here is what you will need:
1. Quarter inch clear Tygon tubing (Lowe's or Home depot carries it)
2. Ultra bright blue LEDs (5mm, clear lens, narrow beam i.e. 12-15 degrees)
3. A small plastic squirt bottle similar to a condiment dispensing bottle
4. a Fluorescent Highlighter (Available at most office supply stores)
Step 1Preparing the Florescent Dye
The first step is to prepare the dye. Take the back off of the fluorescent highlighter. You can ether pry the ink reservoir out. It is an absorbent cylinder soaked in the dye. My first try at this I pulled it out and used a lot of the dye. I put about a teaspoon into the plastic squeeze bottle. This was way to much. It causes the light to be used quickly and not travel far down the tubing.
What ended up working best and is easiest it to place the end of the highlighter over the mouth of the squeeze bottle and let the water absorb some of the die
53 comments
1-40 of 53next »
Nov 18, 2010. 6:53 PMsinepo says:
are these normal led or gree led?
Feb 16, 2012. 12:21 AMAttmos says:
i love this idea. i used this concept in something i made, thanks for the inspiration. i posted it if you want to take a look.
have fun
Nov 13, 2011. 1:34 AMOimi says:
Is there a better way of securing the batteries so they can be added and removed easier? I would be looking to swing these about for light painting but would be worried the battery would fly out as well.
Jul 30, 2011. 1:50 PMplmqaz1243 says:
Oops. I didn't read the next page yet.
Jul 30, 2011. 1:49 PMplmqaz1243 says:
Couldn't you use UV Leds?
Jul 25, 2011. 4:19 PMjconner3 says:
ok ill be hounest im lighting up my deadmau5 helmet and i cant figure out the resistor i need to wire 12 white leds too what even portable power sorce i need i need help i have a on off switch 12 white leds and the toobing
Jul 26, 2011. 10:47 AMjconner3 says:
soo what battery should i use
Apr 11, 2011. 4:04 PMJack Corsair says:
so for the blue color you used what?
Mar 27, 2011. 12:58 PMZeroXL91 says:
Come to think of it, couldn't you use use EL Wire to illuminate the water? It would be so much brighter!
Jan 29, 2011. 2:28 PMXiero says:
If your using UV led's, have you considered using tide detergent? I work on a tech crew and we have these 18" UV cannons that we shine at a wall which we painted with tide. the effects are pretty sweet. The only problems i forsee is coming up with a diluted solution that doesnt creat suds...
Jan 23, 2011. 10:40 AMdouks says:
who can send me The PDF Format of this Project please
Jan 20, 2011. 5:53 PMHuntman00 says:
How long it the tube in the last and second to last pic on step 5????????
Dec 31, 2010. 8:42 PMCaseBoy says:
how long is the biggest one?
Jan 1, 2011. 10:39 AMCaseBoy says:
so how long can the tube be without the glow dimming?
Dec 23, 2010. 1:31 AMscorpenzy says:
How do you manage the color, by the LEDs or the hilighter itself? And how do you make a red tube? Last thing, how long can you make the tube while still looking neon?
Dec 21, 2010. 2:04 PMphevtron says:
made one which is ''dancing'' to the beats
Dec 19, 2010. 2:01 AMkumiko says:
This sounds like a great idea in creating the leggings part of this costume:
http://vocaloid.wikia.com/wiki/Piko_Utatane
It might even be possible to attach tubes in a cross shape, but I can't be sure.
Have you tried blue highlighters with blue LEDs?
Dec 13, 2010. 10:19 AMilpug says:
could you use the button cell batteries taken from inside AA batteries to power this?
Dec 11, 2010. 12:25 PMG-Nugget says:
I've been experimenting with these tubes for use around the edge of a clock I'm making with an acrylic face. I am using 3/16" internal diameter tubing and been successful with getting the LEDs a few millimeters into the tube and sealing with silicone.
I found a solution that is a very pale yellow without light but glows very well when lit. The problem that I'm having is that the dye appears to be disappearing. The tubes go from glowing green to eventually being all blue with no fluorescence over a period of usually a couple of days. I noticed that the pictures here show the tubes being mostly blue; is that just the camera? I tried exposing the tubes to UV from a strong black light for days, heating the tubes, and just letting them sit for a while, but the fluorescence only disappears when lit by the LEDs in the ends. I haven't been able to rig something up to expose the tubes to external LEDs. I'm out of ideas for what would cause the dye to decay. Am I doing something wrong or is this normal?
Dec 11, 2010. 2:52 PMG-Nugget says:
I'm using a highlighter I had laying around at home. it's just a basic yellow fluorescent highlighter. I have been adjusting the solution and when I first noticed that the tubes were losing the color I added more and it stayed for longer. I'm going to add some more and make another and see if that helps more.
I know it sounds crazy, but the the fluorescence disappears from the ends first, then moves towards the middle. I can't say anything for sure about the mix chemically, but it definitely doesn't fluoresce and doesn't become more concentrated in the areas that still do. The ends are very well sealed and nothing has leaked out. I'm going to take some pictures tonight so what is happening is easier to understand.
Dec 11, 2010. 3:35 PMG-Nugget says:
pictures: http://s264.photobucket.com/albums/ii173/GNugget0/projects/
Both tubes were made identically and the only difference is that I have had tube 2 lit on the LEDs for about four days and tube 1 for about one day.
Dec 11, 2010. 5:12 PMG-Nugget says:
I originally tried adding some isopropyl alcohol to the mix, but for a reason that I don't remember, I decided that just water worked better.
Dec 13, 2010. 10:21 AMilpug says:
best solution: use mineral oil and put in a bit of rubbing alcohol, then add your highlighter stuff and proceed.
Dec 19, 2010. 1:53 AMkumiko says:
What does the mineral oil and rubbing alcohol do?
Where do you suggest adding the mineral oil, in the alcohol/highlighter/water solution?
Dec 1, 2010. 2:42 PMerfror says:
If you wrap aluminium foil around the ends (up the size of the LED), and then tape it, you will have a mirror effect at the ends and the light will go more into the tube. Just like gosugenji said.
Nov 20, 2010. 9:54 AMKegtapper says:
Several suggestions:
Diluted Mountain Dew in water will create that same effect as the dayglo marker. (its the phosphorus in the soda that causes the glow under blacklight)
Also if you 'frost' the tube it will glow like neon.
-- How to frost the tube?
a fine grain sandpaper (depending on materials surface)
or hold over a cleaning tank that uses freon and rotate it in the vapors
I've experimented with the tubes 10 years ago.
Good Luck
Nov 19, 2010. 7:44 PMWRIF101rocks says:
I've been trying to make this using hot melt sticks but the light never made it far. These look great and just the color I was looking for! I had one question though. In the pictures it showed a yellow highlighter used for the florescent liquid. When you used blue leds, does it look more yellow than blue in person?
Nov 19, 2010. 8:19 PMgosugenji says:
You should tape the ends with the led's so you dont have so much light bleed. Electrical tapes works wonders well for this.
Nov 18, 2010. 8:22 AMnh4x4Jeep says:
How about the solution that they use for Liquid Cooling CPU's?
They have fluorescent, and UV reactive dyes. They are non-conductive and also have anti-microbial properties.
Just one of ta thousand sites: http://tinyurl.com/2ugtgez
1-40 of 53next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
45
Author:DJJules
I started taking things apart when I was 6 started putting them back together at 8 and they actually worked again when I was 10 or 11...
