1. Quarter inch clear Tygon tubing (Lowe's or Home depot carries it)
2. Ultra bright blue LEDs (5mm, clear lens, narrow beam i.e. 12-15 degrees)
3. A small plastic squirt bottle similar to a condiment dispensing bottle
4. a Fluorescent Highlighter (Available at most office supply stores)
Remove these ads by
Signing UpStep 1: Preparing the Florescent Dye
What ended up working best and is easiest it to place the end of the highlighter over the mouth of the squeeze bottle and let the water absorb some of the die
Visit Our Store »
Go Pro Today »
Jules
For those considering different colour options with UV-sensitive liquids, this page has a decent list of substances with different colour results under UV:
http://chemistry.about.com/cs/howthingswork/f/blblacklight.htm
Jules
I need something smilar now for one m new projects. Question is how long that fluid is fluorescent? The chemical rods are just for short time, the EL wires for a few months maybe...What do you think about this?
Thanks
Jules
You can also buy Fluorescein as a dry powder. And check out this instructable; might come in handy, if you want to make sumthin bright, i guess: http://www.instructables.com/id/Building-a-Lightsaber/
Is there anyway i can get in contact with you?
Im looking at using this idea in a product im making and would be intrested in any new developments or better solutions to use in the tubes for my product
Thanks Elliott, Chaspudz@gmail.com
have fun
Jules
Have fun!
Jules
Post a pic when you are finished!
Jules
Jules
http://vocaloid.wikia.com/wiki/Piko_Utatane
It might even be possible to attach tubes in a cross shape, but I can't be sure.
Have you tried blue highlighters with blue LEDs?
I found a solution that is a very pale yellow without light but glows very well when lit. The problem that I'm having is that the dye appears to be disappearing. The tubes go from glowing green to eventually being all blue with no fluorescence over a period of usually a couple of days. I noticed that the pictures here show the tubes being mostly blue; is that just the camera? I tried exposing the tubes to UV from a strong black light for days, heating the tubes, and just letting them sit for a while, but the fluorescence only disappears when lit by the LEDs in the ends. I haven't been able to rig something up to expose the tubes to external LEDs. I'm out of ideas for what would cause the dye to decay. Am I doing something wrong or is this normal?
I know it sounds crazy, but the the fluorescence disappears from the ends first, then moves towards the middle. I can't say anything for sure about the mix chemically, but it definitely doesn't fluoresce and doesn't become more concentrated in the areas that still do. The ends are very well sealed and nothing has leaked out. I'm going to take some pictures tonight so what is happening is easier to understand.
Both tubes were made identically and the only difference is that I have had tube 2 lit on the LEDs for about four days and tube 1 for about one day.
Jules
