Build Lifesize Space Marine Armor in 352 Terribly Complicated Steps by thorssoli
Contest WinnerFeatured
Step 10: Arm Extensions
Making a person look bigger in costume is a challenge in maintaining proportions.  If you make someone's legs longer, you'll also have to make their arms longer.
In this case, I needed to make giant hands and add an extra foot or so to the wearer's reach.  To achieve this, I sculpted out a pair of palms using oil-based clay.  Then I went ahead and sculpted individual knuckles for each of the hands using more clay as well as some wooden balls and scraps of PVC pipe I had laying around.  Then I made a mold of each of the parts and rotocast them in urethane resin to make them hollow and lightweight.
Once I had castings lined up, it was just a matter of choosing a gesture* and gluing the finger pieces into place on the palms.  For the hands that would be holding weapons, I had to build the fingers around the grips.  The assembled hands were then glued onto the end of a piece of 4" ABS drain pipe with a handle inside.  The pipe would slide over the wearer's arm inside the costume's forearm and act as a sort of brace to help the wearer wield the weapons and whatnot.
*It was very hard to maintain an adult level of maturity in this stage.  If you ever stumble across photos of Space Marines flipping peace signs, giving people rabbit ears, or poking each other in the eyes 3 Stooges style, know that I faltered in a future build.
Londonbrig0 says: Jun 7, 2012. 11:22 AM
You could theoretically create hollow articulated fingers with cords running down through the fingers, hand, and forearm to a set of five ring trigger things, one for each finger. Something like this toy: http://www.youtube.com/watch?v=00Mi3ffzmJU
Might be difficult to hold the prop weapons though.
thorssoli (author) says: Jun 12, 2012. 11:20 AM
I'm pretty happy with the solution I've got for the hands. I'll probably do a pair of hands with articulated fingers in order to allow for adjustable gestures.
Given the awkwardness of the extended arms and the bulk of the weapons, I can't count on the hands to have anything like the kind of strength needed to hold them.
skittlespider says: Jun 7, 2012. 12:13 PM
I have actually made something similar. It is a time consuming process, but the results are nice.
The only problem is what you said about the prop weapons. When using a "hand extension" (term I just made up), things are a lot harder to grab and hold on to. On top of that, even light objects feel about twice their normal weight.
But with enough practice, you can manage quite well.
criggie says: Jun 10, 2012. 6:32 PM
Magnets in the palms, steel bolts in the prop handles.
Should do most of the holding for you, but the weight is still an issue.
thorssoli (author) says: Jun 12, 2012. 11:22 AM
Magnets don't hold up well against shear strain. Given the length of the lever arm torquing against the grips (the chainsword is over 5 feet long after all) there's no magnet I can afford that will be able to keep these things in place.
skittlespider says: Jun 12, 2012. 12:54 PM
One idea that might work could be alternate hands. You could have a set of articulated ones and a set with permanently attached accessories.
Not sure where you would put the extra parts though...
skittlespider says: Jun 12, 2012. 12:52 PM
Yeah, those would have to be some serious magnets!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
