Build Lifesize Space Marine Armor in 352 Terribly Complicated Steps
 by thorssoli
FeaturedContest Winner
Step 8: Parts That Don't Lend Themselves to Vacuum-Forming
Vacuum forming is swell.  The materials are relatively inexpensive, the process is pretty simple, and you can make lots of stuff fairly quickly.  But sometimes it's just not good enough.  Specifically, when you've got to make parts with fine details or undercuts that the forming machine just can't handle.
When this happens, it's time to invest in some silicone RTV moldmaking rubber and learn a whole new set of skills.  I'll refer you once again to Thurston James' excellent opus: the Prop Builder's Molding and Casting Handbook.  I own three copies of it because they keep getting abused and the pages are all stuck together.*  If you're going to tackle a project like this, I'd recommend getting at least one.
For this particular project, I used methods detailed in that book and made one-sided silicone rubber block molds for pieces like the charging handles on the bolters, and the teeth for the chainsword.  I made two-part molds for the pistol grip and some of the other small widgets.  But the most interesting molds were the rotocasting molds for the helmets and the ball vents on the backpack.
The process of making a block mold is pretty simple.  You build a watertight box big enough to fit your original into with at least 1/2" clearance all around.  Then you pour silicone in to fill it up and cover the original.  When the silicone cures, you remove the original and it leaves a hole with the same shape behind.  Now you fill that hole with a 2-part urethane resin which will cure and become an exact copy of the original piece.
For larger pieces, this starts to get expensive.  Instead, you can create a "glove mold" by brushing the liquid silicone onto the original, then adding layers until it's thick enough to hold up to being pulled and pried at.  Once that sets up, you create a rigid "mother mold" to help the flexible rubber retain its shape when the original is removed.
After the mold is made, you can make hollow "rotocast"  or "slush cast" copies by pouring a bit of mixed resin into the mold, then rolling the mold around so the resin coats the interior.  When the resin cures, it forms a hard shell in the same shape as the original.  By adding more and more coats to the inside, you can make the shell as thick/strong/heavy as you like.
There are countless tutorials available online that will tell you everything you need to make silicone molds.  I've read dozens of them and even written a few.  Here's one of them in my blog: http://protagonist4hire.blogspot.com/2011/07/star-wars-republic-commando-helmet-part_22.html  If that's not your speed, here's another one: http://protagonist4hire.blogspot.com/2011/02/warhammer-40000-space-marine-chaplain.html
My favorite video detailing the rotocasting or slush casting process is this one from Volpin Props:
Enjoy.
The original helmet was made in much the same way as all of the other pepakura forms built earlier in this tutorial.  A few scraps of other material were used to make some of the finer details. To differentiate them from one another, I left the hoses off of the cheeks until after I had copies out of the molds.  This way I could make them all different.
The cheek hoses are pieces of automotive wiring conduit fitted to 1/2" PVC pipe fittings which were heavily modified by grinding them down on a belt sander.
The ball vents for the backpack were made out of a styrofoam ball coated with resin and then smoothed out with bondo.  The vent details were pieces of MDF that were cut to shape and glued on.
*The pages are stuck together with glues and resins.  I don't know what you were thinking it was.
Quester55 says: Jun 8, 2012. 4:59 AM
You had my undivided attention up until your movie of how to get Drunk & make a a - - of yourself on, Instructables. Yes, I realize this is one of your friends, but the wrong messages are being sent to the youth that may be watching.
Getting Drunk in any shop, Leaves you open to Injuries or even Death!
That said. Wow !! What a great project, You must be the envy of Fathers everywhere. Keep up the great work and pass those skills along.
LordRussell in reply to Quester55Jun 8, 2012. 8:36 AM
Calm down... it isn't any of 'his' friends and what better way of not only showing you Slush Casting, but how NOT to do it.
I've taken many a grade schooler aside & asked them to jump off the roof of the building; all under the auspices of hitting the ground & walking off, whistling like an accordion like Wile E. Coyote. Not a one believed me. Music, Movies nor Video games cause kids to behave poorly - stop perpetuating the myth.
Take the "mystery" out of universe & people will stop hiding the truth about things or did you forget that this is what Instructables is about? This is about learning technical advancement, not necessarily 'your' moral fortitude. Opine elsewhere.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
