3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build Mini War Gaming Bunker Hill -Free
This instructable will show you how to create several different items for your favorite table top mini war game.  Its suggested that you read through the whole process before attempting, and be creative.
Step 1Materials
Materials
The first thing you are going to want to do is gather your materials, this can include nearly anything from wire to pop cans.  To build the featured hill you will need to start with poly styrene this is a dense insulation for the inside of commercial/industrial building foundations and can be found at nearly any hardware store, or on a construction site (ask your Foreman before you grab some).  You may also require Foam Board if you are building a bunker this material is easy to work with and is fairly cheap, it can be found at most craft stores (Micheal's) or places that sell stationary items (Staples), it is basically a foam sandwich with paper making up the bread.  Finally the one material you will need to build most terrain is box board (card stock), from cereal or a beer case, not corrugated board but there is a use for that i may get into later.  Don't be afraid to experiment with different items go check out your recycle bin for odds and ends, straws and pop or soup cans can also work well.  You may want a hand full of 1/4" gravel this will be helpful to cover up the gaps when you put your buildings together.  Finally Gather your tools you will definately need a utility knife something to draw with (Pen or Pencil) a Ruler is very important -one with a metal edge works best- scissors a steak knife and some cheap white glue.
12 comments
Apr 15, 2012. 1:55 PMnix125 says:
lol looks really good but for warhammer 40000 you could put on the top an iterceptor quad gun or icarus pattern lascannon instead of the space cannon/telescope???
Aug 16, 2010. 3:31 PMhitman_kiwi says:
Really well done, I love making Mini War gaming Terrain pieces and painting Warhammer. ( I don't play though for some reason :P ) Will definitely try this out. Here is a picture of a bunker I made.
Sep 7, 2010. 9:06 PMhitman_kiwi says:
Its become my hobby it seems to make these terrain pieces and then let them collect dust.... I guess I really should get into playing sometime and put them to good use!
Quick question where did you get that Water based spray paint because that would sure save a heck alot of time and paint!
Hope to see some more Instructibles on making mini wargaming terrain.
KR
Sep 7, 2010. 9:07 PMhitman_kiwi says:
Oops did not read your reply to Nekoheehee :P
Aug 22, 2010. 8:24 PMKing Julien says:
What do you do with it? lol it looks really good
Aug 16, 2010. 4:45 AMnekoheehee says:
I have to say this looks pretty good :D I have a couple questions if ya don't mind. about how much did the spray paint cost and where did you find it? I've been looking for some water based spray paints for about a week now and I'm thinking I may have to look online. Also do you know if it comes in a large (normal sized) can? I literally have 4 or 5 tables I need to make for a local club ^^; and lastly, what brand basing material are you using? I personally like the colors citadel have, but its too pricey :( Thanks a lot, Neko
Aug 17, 2010. 10:50 AMpatriots8888 says:
foam
Aug 16, 2010. 3:13 PMgmoon says:
Great job--I have friends who are into gaming miniatures. It's not my thing, but they would dig it!
Aug 16, 2010. 11:24 AMjbrecken says:
It might be more fun if instead of gluing the cannon in place, you made a second ring of cardboard sized to fit snugly but not too tightly around the first one and then only attached the outer ring to the mountain. Then the turret would be able to rotate. (And you could hide a figure inside it)
Aug 16, 2010. 11:47 AMzack247 says:
add a motor to rotate it and make it even awesomer!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:vandejake
surfing the net for a great business ideas....anyone with boat plans please forward ;)
