8/16-bit Sculptures!
 by Pie Ninja
Featured
Look at that picture below, does that look like a special effect? If you said yes, you're wrong. That is 100% real, and in this Instructable I'll show you how to make your own.
I should start out by saying that this is not my idea, it comes from a guy by the name of sWooZie, a while back he posted a video of a pretty awesome sculpture of Ryu from Street Fighter and after looking through his videos, I found this guide on how to make one, and I thought that I was up to the task.
So far I've made multiple sculptures, Ness, Megman, and a 1-UP mushroom.
Before we get into things, I'd like to thank sWooZie for giving me permission to write this up.
Basically, what we will be doing is cutting up some timber into squares, these squares will then be painted and act as individual pixels in your sculpture. I know some of you will ask, "Why not just get a plain slab of timber and draw a grid on it?" the answer is, that doesn't give the same effect and it also makes painting a giant pain. This method gives you a very nice finished product. You're looking at about 2 - 3 days of hard work to finish this, I did mine over a week, very relaxed like.
Step 1: Gather Materials + Tools
This is a rather easy step, you only need to get a few things in terms of materials:
Timber - You want to get dressed pine. Look for 1" x 1" timber, but really any size will do, the ratio of height to thickness doesn't even need to be 1:1. I, personally, couldn't find any 1" X 1" timber so I ended up getting 31mm x 18mm.
I would also recommend you get a wide plank of timber to use for a base, I just used some scrap I had in my garage.
On a side note, if you desire, you can get primed timber, this has a coat of primer on it that allows for easier application of paint, the downside to this is that you have to sand off the primer on the edges of your timber when gluing, and this is very time consuming. Primed timber is also slightly more expensive then regular timber.
Glue - Just get regular old PVA wood glue, any brand will do.
Paint - This is the tricky part, there are two ways you can get the colours you need, the first is to just buy tubes of acrylic paint in Red, Green, Blue, Yellow, Black and White and then mix your own colours, this is quite cheap.
The alternative is to go to a hardware store or paint shop and ask them to mix your colours for you, I went to Bunning's Warehouse and asked them how much it would cost, they told me $8 per small (100mL) pot, this is very expensive if you are using many colours like in mine, but in some respects makes working easier, because you don't have to worry about running out of your home mixed colours and having to start all over again; this is especially painful when mixing skin tones.
You'll also want to get a few small nails and screws for when you put this on a base, if you're going to put it on a base, that is.
Overall for your materials (if using the cheap paint method) you're looking at around $25 - $70 depending on the type of timber you get, how big a sculpture you're making, and how much paint you use.
Tools:
Drop-saw - This makes cutting the timber a breeze and is essential unless you want to spend 15 - 20 hours sawing the wood by hand. Not everyone has one, but if you're lucky you might be able to find a friend or neighbour who does and will let you borrow it.
Hammer - Self-explanatory.
Screwdriver - Self-explanatory
Paint brushes - You want to get (if you don't already have one) a brush that is about 1/3 - 1/2 the length of your pieces when cut, any smaller and the paint probably won't go on thick enough with the lighter colours.
Sand Paper - If you get primed timber, this is a must for sanding off the primer so you can glue it, otherwise you probably won't need any, but it's always a good idea to have some garnet paper handy in case you get rough edges on your timber.
BrittLiv says: Jul 18, 2010. 10:42 AM
Hi, thanks a lot for the idea, I built the perfect cachepot for my carnivorous plant.
frenzy in reply to BrittLivJul 22, 2010. 8:56 AM
This posting has won today's "I Made It" Challenge. For winning you will receive a 3 month pro membership!
Thanks for using instructables!
http://www.instructables.com/community/I-Made-It-Challenge-Is-Back-Win-A-Pro-Membership/
Torgeirro says: Apr 25, 2012. 2:58 PM
Nice shirt man...
mokuba says: Jun 10, 2011. 3:09 PM
i was in the middle of making a 8bit link, but alas, i forgot my appendages! why didnt you list them in the materials needed!
BodenM says: May 2, 2011. 3:51 AM
Must.... resist.... urge... to..... make.... NYAN CAT! Nope, can't do it! This is gonna be my project for the school holidays :D
Masterdragon in reply to BodenMJun 4, 2011. 9:06 AM
I'm going to make Nyan Cat next week. I discovered that you need 902 wooden blocks. And at least ten different colors... This is gonna be hard... XD Good Luck!
CazzPhoenix says: Mar 14, 2011. 3:43 AM
sWooZie was the inspiration for my sculpture as well.. I can't believe as much as I'm on this site that I have not run across this until AFTER righting my instructable lol. Good work though. :-)
JoshyLee says: Nov 10, 2010. 7:33 AM
I don't have access to tools for cutting the wood. I bought my blocks from here. http://www.barclaywoods.com/craft_parts.htm
Celesmeh says: Nov 19, 2009. 8:11 AM
These pictures make it look like its loading...
uglabob in reply to CelesmehOct 5, 2010. 2:26 AM
lol they do
zombiedogfood says: Jul 25, 2010. 10:15 PM
this is awesome, im gonna have to try this
Pie Ninja (author) says: Jul 22, 2010. 11:13 PM
That's beautiful BrittLiv, how long did those take you?
funwithdiode says: Jul 16, 2010. 5:01 AM
That is EPIC I love it XD
chopsuey866 says: Jul 10, 2010. 4:56 PM
Great project!! When I first saw it, I thought it´s only a big board, with the pixels painted on it. But now I see - actually making every pixel out of one wood piece & putting them together, adds all these little imperfections to it on the pixelcorners - that gives it so much "depth" & character - awesome!!
gustavorps says: Jul 5, 2010. 7:59 PM
Very awesome work, you have a online gallery with some more work her?
Roceifin says: Jul 4, 2010. 8:36 PM
or you could use legos!
projectbronco says: Jul 4, 2010. 3:17 PM
Very cool. The Megaman especially is awesome! You could also cut a piece of plywood to the shape you want and have a print shop print a vinyl print of your favorite character. Then just slap the vinyl over the plywood. You would not have the grain of the individual cut pieces of wood showing, but it would be much quicker.
pehlionemusti says: Jul 4, 2010. 2:03 PM
perfecte ...
Mr. Rig It says: Jul 4, 2010. 8:48 AM
Nice job!
James Moxham says: Jul 4, 2010. 6:47 AM
Good stuff. Looks a bit like me mate Mario, but who can tell with 8 bit art. Maybe you need some retro AY-3-8910 sound to go with that? Great design, keep up the good work!
cansei19 says: Jun 20, 2010. 5:52 PM
:D aWesome !
iancarlcute says: Jun 12, 2010. 7:40 AM
great work ill try it at home
JoshyLee says: Apr 1, 2010. 7:40 AM
This is awesome. I'm making a Bubbles from Powerpuff Girls. I'll post a picture when I'm done.
JoshyLee in reply to JoshyLeeMay 14, 2010. 8:54 AM
I added metal hangers on the back instead of a stand.
Pie Ninja (author) in reply to JoshyLeeMay 28, 2010. 4:55 AM
Have you had any issues with the hangers? Or is everything holding together fine?
JoshyLee in reply to Pie NinjaMay 28, 2010. 5:22 AM
They work just fine. But it was terrifying hammering them into the back.
Pie Ninja (author) in reply to JoshyLeeMay 14, 2010. 8:54 PM
That is pretty cool.
Junkyard Dawg in reply to Pie NinjaJul 4, 2010. 12:35 PM
I think I out to do one of these. Mabe I'll do that potted plant from Super Mario Bros. or that 1UP mushroom, or the "?" block, (I could go on forever) Or, If I can find one, mabe I could do something like this for an F-14 Tomcat fighter (one of my all-time favorites)
zombiefire says: May 11, 2010. 5:45 AM
im making one and any one who wants me to make one for a particular price email me at zombiefire@hotmail.com.au
werto87 says: Jan 18, 2010. 3:08 PM
i actually had this exact idea but i was to lazy to actually do it.
i give you major props
Pie Ninja (author) in reply to werto87Jan 23, 2010. 11:22 PM
Well, it wasn't me that had the idea, that would be Swoozie. You should check out his YouTube channel, he's a pretty cool guy.
eyebot117 says: Jan 23, 2010. 9:48 PM
Sounds neat. I'm moving to a new house in a year or two, and that kinda sounds like something fun to make! You'll never be able to guess what game this character is from, because the game hasn't been made yet! (Work in progress)...
Pie Ninja (author) in reply to eyebot117Jan 23, 2010. 11:21 PM
Looks good, remember to post some pics when it's done :)
Squash says: Dec 10, 2009. 3:51 AM
Sweet.  Cool project.  I think I'll try this with the neice and nephews.  They are into gaming characters.  Thanks!  Nice job.
Pie Ninja (author) in reply to SquashDec 11, 2009. 3:32 AM
Make sure to upload some pictures! :)
craig3 says: Dec 9, 2009. 4:22 AM
So when you put it together, you just layered up and up? didn't use anything to keep them flat?
Also, after you've had it for a while, how strong is it still now? im scared that if i make one it will will break apart
Pie Ninja (author) in reply to craig3Dec 10, 2009. 12:45 AM
First question, yes, I did weigh it down, I mentioned that in Step 6.
And as for your second question, generally, PVA glue is pretty strong so bits shouldn't break off unless you're particularly rough with it.
Charly-tan says: Dec 6, 2009. 10:55 PM
As I had told you in the Forums, it's Great.
of course, I've favorited this and voted a 5/5 because it's awesome XD
quesoman says: Nov 27, 2009. 6:37 PM
Hi,
First off I'd like to say this is a great instructable. I personally am contemplating between Mario or Sonic for this project. Maybe both. I think I'm goingto start off with a smaller scale, LEGO version first.
Great Job,
Quesoman
Pie Ninja (author) in reply to quesomanNov 27, 2009. 8:16 PM
Make sure you upload a picture or two. :)
Rogy says: Nov 22, 2009. 8:44 AM
Yes, Celesmeh
Warning 56Kb!!
xD
merijnvw says: Nov 19, 2009. 7:28 AM
 Why not saw the whole thing at once, and just paint along the straight lines, that's not so hard. It is much less work.
justinle13 in reply to merijnvwNov 21, 2009. 10:18 PM
 Hey,
im pie ninja friend,
Its too hard to do. i understand what you , mean by painting along straight lines but it way difficult making sure to not paint over lines and other squares, cutting it and painting them all at once is a preferred option to take, but what's a project without a bit of elbow grease and hard work :)
Justin
Pie Ninja (author) in reply to merijnvwNov 19, 2009. 3:57 PM
You mean, paint the timber before I cut it in one big length?
1up in reply to Pie NinjaNov 22, 2009. 10:35 AM
That's a really nice idea, actually. Great Instructable, by the way!
merijnvw in reply to Pie NinjaNov 20, 2009. 4:23 AM
Last time I didn't see you already wrote: I know some of you will ask, "Why not just get a plain slab of timber and draw a grid on it?" the answer is, that does not give the same effect, this method gives you a very nice finished product.
That was what I meant, I think it wouldn't make a big difference. Maybe even better with one slab of timber, because you won't see the lines between two pixels of the same colour.
Pie Ninja (author) in reply to merijnvwNov 20, 2009. 2:33 PM
You could try it, I personally haven't and I don't plan to. The only thing I'd like to point out is that if you don't get every single one of your lines perfectly straight, it won't look right; it's a lot easier to cut a straight line with a dropsaw than it is to draw about 300 1'-3' lines. That and large sheets of timber have a tendency to warp and bend.
merijnvw in reply to merijnvwNov 19, 2009. 7:28 AM
 it looks good by the way
metalfury says: Nov 21, 2009. 2:29 PM
Hi,
Great instructable!
Thought you might like this:
http://www.capstrat.com/elvis-spotted-in-the-conference-room/
Also includes some techniques for prepping a standard image for this sort of project.
metalfury
erosser says: Nov 17, 2009. 2:10 PM
 NIce work!
You could even do a somewhat subtle version of it with different shades of timber: cherry, oak, etc.  You would have to pick a somewhat simply and well-known design for folks to recognize it, ie Pac-man or Kirby, but it would be rather classy to have just the natural tones of the wood.
Not to say your's is not classy--quite the contrary!
Again, fabulous job.
mathieugfortin in reply to erosserNov 19, 2009. 6:29 AM
Thinkgeek has something like this that I've been meaning to copy for a while now:
http://www.thinkgeek.com/homeoffice/kitchen/a7cf/
Pie Ninja (author) in reply to mathieugfortinNov 21, 2009. 1:14 AM
Very cool, but one thing you should note is that you'd need to use a stain on the timber rather than paints because paint would get easily chipped and end up in your food.
Pie Ninja (author) in reply to erosserNov 18, 2009. 2:49 AM
Very nice idea, but I don't think there are enough colours of wood, sure, you get the browns, deep reds and yellows, but I don't think you'd be able to find blue or green in timber, but very nice idea, maybe I'll try and find a sprite compatible with those clolours.
And stay tuned, my next one is going to be a Megaman, then a Yoshi or Mario :)
Phoghat in reply to Pie NinjaNov 19, 2009. 10:30 AM
Nice project. Did you think of using Leggo?
Pie Ninja (author) in reply to PhoghatNov 29, 2009. 11:09 PM
Not really, mainly because I don't have too much lego, and timber is cheaper.
Pie Ninja (author) in reply to Pie NinjaNov 29, 2009. 11:09 PM
Also, sorry about the late reply.
radiobath in reply to Pie NinjaNov 19, 2009. 7:10 AM
Any *really* old black and white gameboy game could easily be done. Old Link, old Kirby, old Mario...etc.
shawdow7341 says: Nov 20, 2009. 2:38 PM
SO COOL
Liam Wolf says: Nov 19, 2009. 11:02 PM
I don't comment on Instructables often, but this is something I must "Must" do! Thank you for putting up the tutorial.
Pie Ninja (author) in reply to Liam WolfNov 19, 2009. 11:42 PM
Thankyou for commenting. :)
ludo says: Nov 19, 2009. 7:24 AM
Good stuff! Did you varnish after assembly?
If you want to keep the woodgrain and add colour, it is possible to stain softwood with fabric dye. It probably makes sense to test small samples and vary the time the wood is in the dye mixture.
Pie Ninja (author) in reply to ludoNov 19, 2009. 3:56 PM
No I didn't use any varnish, just plain old acrylic paint.
sludge93023 says: Nov 19, 2009. 8:52 AM
Excellently written and presented all the way through.
adam adkison says: Nov 19, 2009. 4:50 AM
any suggestions on where to find good screenshots?
adam adkison in reply to adam adkisonNov 19, 2009. 6:19 AM
Did some checking, found if you type in 'game characters 8-bit sprites' into google and select Images from the search engines you receive a nice selection to pick from.
solipsism says: Nov 17, 2009. 9:21 PM
If you can pick up scrabble cheaply, you could probably do a smaller one with the tiles and not need the power tools.
Pie Ninja (author) in reply to solipsismNov 18, 2009. 2:45 AM
Quite possible, but good luck gluing those tiny edges together. :P
solipsism in reply to Pie NinjaNov 18, 2009. 7:26 AM
you would need a backer to glue them to
Pie Ninja (author) in reply to solipsismNov 18, 2009. 8:57 PM
That would work.
KNEX BUILDING IS FUN says: Nov 16, 2009. 7:01 PM
you think it be posible to takea picture of somthing, like ur pet, yourself an idol or any object, take a very low resolution picture n then do the same thing
Pie Ninja (author) in reply to KNEX BUILDING IS FUNNov 16, 2009. 8:55 PM
I don't follow.
Steeltowndude in reply to Pie NinjaNov 17, 2009. 5:50 PM
I understand what he's saying. He's asking if it's possible to take a very low resolution picture of something, so the picture is very blurry and pixelated, and make the picture into one of these sculptures.
KNEX BUILDING IS FUN in reply to SteeltowndudeNov 17, 2009. 7:05 PM
exactly
solipsism in reply to KNEX BUILDING IS FUNNov 17, 2009. 9:17 PM
actually you can use any image and photoshop
filter/pixelate/mozaic  and up the slider
Pie Ninja (author) in reply to solipsismNov 18, 2009. 2:46 AM
Yes, you could do that, but depending on the size of the item you photograph, you could end up needing anywhere between 500 and 100000 blocks, if somebody makes one that big, I will eat my hat.
Pie Ninja (author) in reply to Pie NinjaNov 18, 2009. 2:51 AM
(Praying to god nobody already has, I like my hat.)
illdoyourdrugs says: Nov 15, 2009. 7:56 PM
Dope. I want to make Bowser!
Pie Ninja (author) in reply to illdoyourdrugsNov 18, 2009. 2:50 AM
If you do, make sure to put up a pic so I can see. :)
Treasure Tabby says: Nov 17, 2009. 12:38 AM
Oo, very nice. For a second there I thought you were going to use Lego.
You can probably use cardboard boxes and or foam sheets in case you don't have access to blocks of wood.
would be an excellent decoration for a game room.  :)
Pie Ninja (author) in reply to Treasure TabbyNov 18, 2009. 2:50 AM
Hmmm... carboard may work, but I doubt foam would look right.
Jeffreyyy says: Nov 16, 2009. 10:14 PM
You lol face
haha you actually did it
you gain my respect
i wont laugh at your wild ideas again ;)
guitarman63mm says: Nov 15, 2009. 3:24 PM
Great 'ible, just one qualm:  That first photo is blurry.  Delete the first one on the intro, and leave the second one.
Pie Ninja (author) in reply to guitarman63mmNov 15, 2009. 8:33 PM
I'll get right on it. :)
Angry J says: Nov 15, 2009. 7:31 AM
Awesome instructable.   Very nice.  I want to make a bunch of these now!
Pie Ninja (author) in reply to Angry JNov 15, 2009. 12:51 PM
If you do make sure to take lots of pictures, I'd love to see them. :)
watermelonhead says: Nov 15, 2009. 5:05 AM
Sweeeeeeeeeet~
gotanysparecake says: Nov 14, 2009. 7:43 PM
Nice.
Pie Ninja (author) says: Nov 14, 2009. 3:17 PM
Wow, my first Instructable and it get's featured in less than a day, thank you all for rating! :D
ChrysN says: Nov 14, 2009. 3:01 PM
Great project!
Sunbanks says: Nov 14, 2009. 12:49 PM
That looks awesome!And this is a great instructable :D
bloomautomatic says: Nov 14, 2009. 9:42 AM
Nice work.  Very cool piece of art.  I also like that you did this project with your dad and grand dad.  The only thing better than having something cool that you made yourself is having something cool that you made with your dad.
Vince
Jayefuu says: Nov 14, 2009. 8:57 AM
Someone read my mind... it was too epic to not get featured :D
Jayefuu says: Nov 14, 2009. 3:53 AM
This is awesome! And kudos to you for giving credit where credit's due.
Jayefuu in reply to JayefuuNov 14, 2009. 3:54 AM
PS 4.5*
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
