3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
8/16-bit Sculptures!
Look at that picture below, does that look like a special effect? If you said yes, you're wrong. That is 100% real, and in this Instructable I'll show you how to make your own.
I should start out by saying that this is not my idea, it comes from a guy by the name of sWooZie, a while back he posted a video of a pretty awesome sculpture of Ryu from Street Fighter and after looking through his videos, I found this guide on how to make one, and I thought that I was up to the task.
So far I've made multiple sculptures, Ness, Megman, and a 1-UP mushroom.
Before we get into things, I'd like to thank sWooZie for giving me permission to write this up.
Basically, what we will be doing is cutting up some timber into squares, these squares will then be painted and act as individual pixels in your sculpture. I know some of you will ask, "Why not just get a plain slab of timber and draw a grid on it?" the answer is, that doesn't give the same effect and it also makes painting a giant pain. This method gives you a very nice finished product. You're looking at about 2 - 3 days of hard work to finish this, I did mine over a week, very relaxed like.
Step 1Gather Materials + Tools
This is a rather easy step, you only need to get a few things in terms of materials:
Timber - You want to get dressed pine. Look for 1" x 1" timber, but really any size will do, the ratio of height to thickness doesn't even need to be 1:1. I, personally, couldn't find any 1" X 1" timber so I ended up getting 31mm x 18mm.
I would also recommend you get a wide plank of timber to use for a base, I just used some scrap I had in my garage.
On a side note, if you desire, you can get primed timber, this has a coat of primer on it that allows for easier application of paint, the downside to this is that you have to sand off the primer on the edges of your timber when gluing, and this is very time consuming. Primed timber is also slightly more expensive then regular timber.
Glue - Just get regular old PVA wood glue, any brand will do.
Paint - This is the tricky part, there are two ways you can get the colours you need, the first is to just buy tubes of acrylic paint in Red, Green, Blue, Yellow, Black and White and then mix your own colours, this is quite cheap.
The alternative is to go to a hardware store or paint shop and ask them to mix your colours for you, I went to Bunning's Warehouse and asked them how much it would cost, they told me $8 per small (100mL) pot, this is very expensive if you are using many colours like in mine, but in some respects makes working easier, because you don't have to worry about running out of your home mixed colours and having to start all over again; this is especially painful when mixing skin tones.
You'll also want to get a few small nails and screws for when you put this on a base, if you're going to put it on a base, that is.
Overall for your materials (if using the cheap paint method) you're looking at around $25 - $70 depending on the type of timber you get, how big a sculpture you're making, and how much paint you use.
Tools:
Drop-saw - This makes cutting the timber a breeze and is essential unless you want to spend 15 - 20 hours sawing the wood by hand. Not everyone has one, but if you're lucky you might be able to find a friend or neighbour who does and will let you borrow it.
Hammer - Self-explanatory.
Screwdriver - Self-explanatory
Paint brushes - You want to get (if you don't already have one) a brush that is about 1/3 - 1/2 the length of your pieces when cut, any smaller and the paint probably won't go on thick enough with the lighter colours.
Sand Paper - If you get primed timber, this is a must for sanding off the primer so you can glue it, otherwise you probably won't need any, but it's always a good idea to have some garnet paper handy in case you get rough edges on your timber.
94 comments
1-40 of 94next »
Jul 18, 2010. 10:42 AMBrittLiv says:
Hi, thanks a lot for the idea, I built the perfect cachepot for my carnivorous plant.
Jul 22, 2010. 8:56 AMfrenzy says:
This posting has won today's "I Made It" Challenge. For winning you will receive a 3 month pro membership!
Thanks for using instructables!
http://www.instructables.com/community/I-Made-It-Challenge-Is-Back-Win-A-Pro-Membership/
Apr 25, 2012. 2:58 PMTorgeirro says:
Nice shirt man...
Jun 10, 2011. 3:09 PMmokuba says:
i was in the middle of making a 8bit link, but alas, i forgot my appendages! why didnt you list them in the materials needed!
May 2, 2011. 3:51 AMBodenM says:
Must.... resist.... urge... to..... make.... NYAN CAT! Nope, can't do it! This is gonna be my project for the school holidays :D
Jun 4, 2011. 9:06 AMMasterdragon says:
I'm going to make Nyan Cat next week. I discovered that you need 902 wooden blocks. And at least ten different colors... This is gonna be hard... XD Good Luck!
Mar 14, 2011. 3:43 AMCazzPhoenix says:
sWooZie was the inspiration for my sculpture as well.. I can't believe as much as I'm on this site that I have not run across this until AFTER righting my instructable lol. Good work though. :-)
Nov 10, 2010. 7:33 AMJoshyLee says:
I don't have access to tools for cutting the wood. I bought my blocks from here. http://www.barclaywoods.com/craft_parts.htm
Nov 19, 2009. 8:11 AMCelesmeh says:
These pictures make it look like its loading...
Oct 5, 2010. 2:26 AMuglabob says:
lol they do
Jul 25, 2010. 10:15 PMzombiedogfood says:
this is awesome, im gonna have to try this
Jul 16, 2010. 5:01 AMfunwithdiode says:
That is EPIC I love it XD
Jul 10, 2010. 4:56 PMchopsuey866 says:
Great project!! When I first saw it, I thought it´s only a big board, with the pixels painted on it. But now I see - actually making every pixel out of one wood piece & putting them together, adds all these little imperfections to it on the pixelcorners - that gives it so much "depth" & character - awesome!!
Jul 5, 2010. 7:59 PMgustavorps says:
Very awesome work, you have a online gallery with some more work her?
Jul 4, 2010. 8:36 PMRoceifin says:
or you could use legos!
Jul 4, 2010. 3:17 PMprojectbronco says:
Very cool. The Megaman especially is awesome! You could also cut a piece of plywood to the shape you want and have a print shop print a vinyl print of your favorite character. Then just slap the vinyl over the plywood. You would not have the grain of the individual cut pieces of wood showing, but it would be much quicker.
Jul 4, 2010. 2:03 PMpehlionemusti says:
perfecte ...
Jul 4, 2010. 8:48 AMMr. Rig It says:
Nice job!
Jul 4, 2010. 6:47 AMJames Moxham says:
Good stuff. Looks a bit like me mate Mario, but who can tell with 8 bit art. Maybe you need some retro AY-3-8910 sound to go with that? Great design, keep up the good work!
Jun 20, 2010. 5:52 PMcansei19 says:
:D aWesome !
Jun 12, 2010. 7:40 AMiancarlcute says:
great work ill try it at home
Apr 1, 2010. 7:40 AMJoshyLee says:
This is awesome. I'm making a Bubbles from Powerpuff Girls. I'll post a picture when I'm done.
May 14, 2010. 8:54 AMJoshyLee says:
I added metal hangers on the back instead of a stand.
May 28, 2010. 5:22 AMJoshyLee says:
They work just fine. But it was terrifying hammering them into the back.
Jul 4, 2010. 12:35 PMJunkyard Dawg says:
I think I out to do one of these. Mabe I'll do that potted plant from Super Mario Bros. or that 1UP mushroom, or the "?" block, (I could go on forever) Or, If I can find one, mabe I could do something like this for an F-14 Tomcat fighter (one of my all-time favorites)
May 11, 2010. 5:45 AMzombiefire says:
im making one and any one who wants me to make one for a particular price email me at zombiefire@hotmail.com.au
Jan 18, 2010. 3:08 PMwerto87 says:
i actually had this exact idea but i was to lazy to actually do it.
i give you major props
Jan 23, 2010. 9:48 PMeyebot117 says:
Sounds neat. I'm moving to a new house in a year or two, and that kinda sounds like something fun to make! You'll never be able to guess what game this character is from, because the game hasn't been made yet! (Work in progress)...
Dec 10, 2009. 3:51 AMSquash says:
Sweet.  Cool project.  I think I'll try this with the neice and nephews.  They are into gaming characters.  Thanks!  Nice job.
Dec 9, 2009. 4:22 AMcraig3 says:
So when you put it together, you just layered up and up? didn't use anything to keep them flat?
Also, after you've had it for a while, how strong is it still now? im scared that if i make one it will will break apart
Dec 6, 2009. 10:55 PMCharly-tan says:
As I had told you in the Forums, it's Great.
of course, I've favorited this and voted a 5/5 because it's awesome XD
Nov 27, 2009. 6:37 PMquesoman says:
Hi,
First off I'd like to say this is a great instructable. I personally am contemplating between Mario or Sonic for this project. Maybe both. I think I'm goingto start off with a smaller scale, LEGO version first.
Great Job,
Quesoman
1-40 of 94next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
19
Author:Pie Ninja
