Build Your Own Backyard Fire Pit by Thisoldhouse.com
Featured
Outdoor fires are so hot right now. Seriously. Mankind has called the hearth home for the centuries, it's true, but these days people are going ultra-retro and getting their heat from stone-walled pits set into the earth. And, why not? On cool summer nights, you can melt marshmallows and nibble s'mores while you lounge in an Adirondack chair, feet propped up on the rock ledge. So if you really want to light up right, do it in style. Take a few days to build your very own ring of fire.
*See final slide for a SHOPPING LIST for this project
Step 1: Learn the anatomy
A built-in fire pit is a glorified campfire, with sturdy walls of stone that help contain the flames and heat. That's especially important in the parts of the country where there's a risk of brush fires. So the first task in building any fire pit is checking local codes on open flames. The pit must be located far from overhanging trees, the house, and any other flammable structure.
MORE: Landscaping That Prevents Wildfires
To make building stone walls easier, you can use blocks made from cast concrete and molded to look like real stone (available at any home center). They're flat on the top and bottom so they stack neatly, and some interlock for added strength. Glue them together with masonry adhesive. Choose a block with angled sides, meant to form curves when butted against each other. The optimal size for a fire pit is between 36 and 44 inches inside diameter. That will create enough room for a healthy fire but still keep gatherers close enough to chat.
As an added precaution, the fire pit should be lined with a thick steel ring like the ones used for park campfires. These protect the concrete in the blocks from the heat, which can cause them to dry out and break down prematurely.
A fire pit should sit low to the ground, with walls rising no more than a foot off the ground. But for stability, the base of the wall must be buried below ground in a hole lined with gravel, providing drainage and protecting against frost heaves in winter. the gravel also creates a level base for the stones to rest on. Most concrete blocks are about 4 inches high, so if the first course and a half sit underground, and there are two and a half courses above ground with a cap on top, you'll end up with a foot-high wall—just right for resting your feet on while sitting in an outdoor chair.
MORE: Build an Adirondack Chair
MORE: Want More Wall and Less Fire? Try Building This Fire Pit's Cousin, The Sitting Wall
Step 2: Lay Out the Blocks
Dry-lay a ring of blocks on the fire pit site, placing them end to end until you have a perfect circle positioned where you want the finished pit to be. To adjust the size of the circle, you may need to cut a block. Hold the block over the gap it will fill, then mark it on the underside at the proper width.
Using a 3-inch cold chisel and a brick hammer, score the block on the mark, and continue the score all the way around the block. Place the block on a hard surface (flat rocks or gravel). Hold the chisel in the score line, then hit it with the brick hammer until the block splits.
Clean up jagged edges with the tail of the brick hammer. Place the cut block into the ring.
MORE: Portable Fire Pits
Step 3: Mark the Pit Location
Make sure all the joints between the blocks are tight and the front and back edges line up. Using a spade, mark a circle in the ground about an inch outside the perimeter of the ring.
Take note of how many stones make up the ring, then remove them and set them aside.
If the blocks you are using are interlocking, remove any tongues on the bottom of the first-course blocks so they will lie flat in the trench. Chip them off with the tail of a brick hammer.
Step 4: Create a Level Trench for the Blocks
Using a spade, dig a straight-sided trench, 12 inches deep and as wide as one block, within the circle marked out on the ground. Then dig down 6 inches in the area encircled by the trench.
MORE: Dig  a Flat-Bottomed Hole
Lay the ring of blocks in the trench to see if all the pieces fit in a circle. If not, dig more to widen the trench. Remove blocks.
MORE: Digging Do's and Dont's
Step 5: Fill the Trench
Fill the trench with 6 inches of 3/4-inch drainage gravel. Using a hand tamper, compact the gravel. If necessary, add more gravel to keep the trench level and even.
Always make sure the blocks line up perfectly in the front and back when you lay them out; a difference of 1 inch in the circle's diameter could create a 3-inch gap between blocks.
MORE: Like Gravel? Use it to Lay a Garden Path
Step 6: Lay and Level the First Course
Place the first block in the ring. Using a 2-foot level, check that it sits level both side to side and front to back. Where the block is too high, tap it down with a rubber mallet. Where it's too low, shim it slightly with a handful of patio base. Make sure this first block is perfectly level and positioned correctly in the trench before moving on.
MORE: Norm Abram's Advice for Choosing and Using Levels
Lay another block next to the first one. Butt the sides together tightly and line up the front and back edges. Using the first block as a reference, level the second block side to side and front to back.
Lay the rest of the blocks in the trench in this manner until the ring is complete and all the blocks you counted earlier are used. Make sure each block is perfectly leveled and lined up tight with its neighbor before moving on to the next one. (You may have to coax the last block into place with a mallet.) Using a 4-foot level, occasionally check level across the ring.
A small hit with a mallet can make a big adjustment; work slowly and carefully, block by block.
Step 7: Assemble the Walls
Using a caulking gun, squeeze a zigzag bead of masonry adhesive across two adjacent blocks. Lay a block on top of the glue-covered pieces, centering it over the seam between the two. Make sure any interlocking parts on the blocks fit together well. Continue until the second course is finished.
MORE: Skillbuilder- Squeeze That Extra Bead Out of a Caulk Tube
Step 8: Fill the Pit
Fill the pit with 6 inches of gravel, which will help support the first two courses as they set up. Glue and lay the third and fourth courses, continuing to stagger the joints.
Insert the iron campfire ring into the circle. Adjust it to sit even with the top of the block wall. Fill any space between the ring and the block wall to the top with gravel.
Work quickly and only in a small area at one time; masonry adhesive sets up quickly.
MORE: Wide World of Adhesives
Step 9: Cap the Blocks
Loosely arrange the cap pieces on top of the pit walls. (If you are using natural stone, try to arrange the pieces together like a puzzle.) Lay one stone edge over the next and mark the upper stone where they meet. Also, roughly mark the stone for a 2-inch overhang on the outside of the circle and an inch on the inside. Using a brick hammer and a chisel, score the stone on those marks. On thick natural stone, use a grinder fitted with a diamond blade to score it more deeply.
Lay the stone on a hard surface. Split it by hitting a chisel in the score mark, or by tapping against the stone's edge with the brick hammer until it breaks. Score and split each stone this way, moving around the circle in one direction until you've made a cap that fits together tightly.
If you're using blocks, glue the pieces on top of the wall. If you're using natural stone, combine the dry mortar with enough bonding additive—not water—to make a mix with a peanut-butter consistency.
Wet the wall with some bonding agent. Lay a large mound of mortar on two blocks. With the point of the trowel, make a groove across the mortar. Lay the capstone on top, push it down, then tap it with the rubber mallet to set and level it. Continue to lay the capstones in this manner until the wall is finished. Wait two days before lighting a fire.
MORE: Dyeing Mortar
Step 10: Don't stop now! Pick up another DIY project at thisoldhouse.com
You can...
...Install a Picket Fence
...Put in a Pond
...Add Drip Irrigation
...Build a Tool Shed
...Make a Trellis
SHOPPING LIST
1. CAST-CONCRETE WALL STONES
2. CAPSTONES
3. STEEL CAMPFIRE RING
The one we used here is from MARKSTAAR
4. 3/4-INCH DRAINAGE GRAVEL
5. PATIO BASE
(stone dust)
6. MASONRY ADHESIVE
7. READY-MIX MORTAR
(if needed) to cement a natural-stone cap onto the wall. A 40-pound bag is enough.
8. CONCRETE BONDING ADDITIVE
(aka "milk") to make the mortar more flexible.
1-40 of 46Next »
jblanton1 says: Oct 6, 2011. 3:54 PM
I'm in Texas and we currently have a burn ban due to the drought. I recently needed to burn some limbs on a piece of property that I own (but haven't built a house on it yet). As I was clearing out the brush that had grown up, I noticed where someone had dumped a concrete culvert that had about 6" x 12" half moon chip removed in one end, so I stood the culvert on it's end and used it for a burn "barrel". The hot air goes out the top and sucks in air through the half moon opening in the bottom. Once it starts up, it's like a little jet engine running. I ran it for about an hour and the concrete stayed warm for a LONG time after that. End result is that concrete seemed to make a pretty good fire barrier without fire bricks...
sandraellis says: Oct 5, 2011. 3:33 PM
I like the diagram you have showed below the finished product. Its reassuring to see how stable the fire pit really is. I too appreciate a good fire pit!
rwolkens says: Jul 4, 2011. 10:25 AM
This has given me inspiration. I have an above ground fire pit that my Mom gave me, but it is missing one of the four legs, and the screws that hold the legs to the base ring have rusted and broken off. If I make a base of decorative stone topped off with pavers, and fill the bottom with draining stone that I have laying around, then drop the pan into the top of it with the lip overlapping the pavers, that should work really good and look nice.
dbarajas2231 says: Apr 27, 2011. 9:14 AM
I understand the rational for having a fire ring, to "protect the concrete in the blocks from the heat, which can cause them to dry out and break down prematurely..." but it it absolutely necessary? The link provided for the fire rings price them at $75 to $215.28 and that seems a bit much. Is there some type of stone that I could substitute for the concrete bricks that would hold up to heat better and alleviate the need for the metal fire ring?
Thanks
starshipminivan says: Jun 19, 2011. 7:48 PM
You can use fire brick--the kind used to line fireplaces. Home improvement stores carry them. They are NOT the same as the brick used in construction and they certainly should NOT be concrete bricks. Use these to line the inside of the pit.
We found them to be far less expensive than a custom ring and, when we did the math, were still less expensive than the least expensive rings we could find. We are building a fire pit this year and that is what we are using to line it. The exterior will have the concrete blocks but the inside ring will be all fire brick.
ddpedersen says: May 13, 2010. 7:37 AM
Not sure that putting gravel in the bottom is a good idea.  When the fire dies down and the hot coals sit on the bottom, they heat up the rocks and any air pockets in the rocks can cause them to explode.
Not horribly dangerous, but i have been hit in the face with rock fragments before.  I would just leave the bottom as dirt, plus it is easier to remove the left over coals when you are done.
Whatever you do, never put a concrete slab below a fire, they have a lot of air pockets, and per my experience, will explode and send everyone running.
JRTORRES says: May 16, 2010. 10:02 AM
Actually, it is not air pockets in rocks, it is dissolved water. When water gets heated it comes out of solution and expand to about 700 times its volume causing an explosion. This water exist in concrete as well as other rocks. Volcanic rocks do not contain the water because of their origin, lava actually is dry since it is so hot. So there is no water during solidification. Bottom line is, do not use gravel and if you use concrete block you must cover it with the metal lining. Concrete causes a nasty explosion, lots of water in it.
Another thing that is useless is the trench filled with gravel. What's the point, if you have no drainage. It is just going to fill with water from rain and eventually it will dissolve the surrounding dirt which will cause the sides of the trench to cave in. You are better off leaving holes on the bottom of the block structure so that it drains over the ground surface.
SoDDiggerCpl says: Jun 19, 2011. 10:42 AM
the point of the gravel is it is an easy substance to level, it is used in construction to create level footers. being under the first course of blocks gives the whole ring stability, and allows for level construction.
co1973 says: May 20, 2011. 1:48 PM
The ring of gravel has nothing to do with drainage, per se. If you're not familiar with the construction of stacked concrete retaining walls, the purpose of the gravel is to provide a compactible surface that can be easily leveled prior to setting the stones. Drainage isn't a concern for the firepit because it's no different than the undisturbed ground. it sits on.
Cerasus says: May 13, 2010. 11:49 PM
A dirt bottom is a really, really, really (and I cannot stress this enough) really  bad idea and should never ever be done for reason. Root fires are a reality and is a horrible MoFo to deal with.
Sand is the superior alternative.
GDParduhn3 says: May 26, 2010. 3:37 PM
I ditto the sand bottom,    a really thick layer  , ,  you could go as far to use silica sand  , the high heat resistance stuff they use in the bottom of fireplaces.
it will drain easily too.
easy to sift out debris later.
plznothanks says: May 15, 2011. 8:30 PM
Bear Grylls is the champ at this http://howtohacklife101.blogspot.com/2011/05/how-to-build-fire.html
Thefsxmad says: Nov 20, 2010. 11:04 AM
Loving the Adirondack chair
Did you build it yourself?
hg341 says: Oct 1, 2010. 1:32 PM
you need more pics
Kiteman says: May 14, 2010. 8:49 AM
Riddled with external links.
Looks spammy to me.
SaveOurSkills says: Sep 16, 2010. 2:05 PM
hey the information is very good though... i don't mind him referencing external articles that are relevant. Also I am not opposed to people providing site with excellent content in order to promote their web ventures as long as they stay on topic. True spam just links randomly, the external links were all relevant.
nbue says: Jun 5, 2010. 7:53 PM
How would one go about safely building a fire pit on top of a cement deck? It's the only spot for one in our yard and is also the roof over our underground garage. Ideas anyone?
superant10000 says: Jul 18, 2010. 5:43 PM
My friend Erin has something very similar to what you're asking. http://www.bapatoms.net/photos/pit1.jpg The above is similar to what she has; though hers is bigger than that one. It works perfectly fine, although there are issues with pieces of flaming kindling/twigs being blown in your face when the winds pick up. If you're fully sheltered then it doesn't matter so much and I would recommend you buying something similar. If you're intent on building one DIY, then you could always just build the pit upwards using insulation and keeping a good 12" distance from the burning area base, to your garage roof. I would also recommend checking the supporting weight of the whole structure, because if the roof only supports 600KG and you build a 90KG fire pit on top and have 10 people all sitting around it, you could find yourself all being horiffically maimed then burnt alive. Wow. Was that a bit over the top? :/
adlabens says: Jun 17, 2010. 5:17 AM
I built my firepit in much the same design, but with less. I had a level place in the yard, so I simply set the bricks into a circle (took 12 bricks to make a circle. I got 4 layers of the bricks, less a few gaps in the very bottom for air flow. I broke the tabs off the backs of the bricks, broke a couple of bricks in half (2 for each of the bottom 2 rows), and laid them out. No mortar, no gravel, no metal liner - simply laid out the bricks. Then, I tossed in the sticks & branch pieces that had fallen into the yard from our 4 pecan trees over the past year, & lit it up. Took about 75 minutes from start to finish to do the whole thing, and another 15 minutes to clean up the leftover brick pieces. Two tools - hammer & chisel, and the only material was the bricks, quick & easy & effective.
rwinscot says: Jun 4, 2010. 2:13 AM
I wouldn't recommend using any kind of adhesive / glue when assembling a fire pit - you run the risk of releasing un-healthy fumes with the heat of the fire. A fire-friendly mortar would be a much better choice. Also, you don't want to make the body of the pit air-tight. Leaving cracks / spaces in the blocks here and there will improve ventilation.
codyhanson says: May 12, 2010. 7:44 PM
 On this picture it says "glue wall blocks together with"....with what?
GDParduhn3 says: May 26, 2010. 3:29 PM
must be air...    !
i like the mud idea better,  or clay even. ..
ahutton1972 says: May 13, 2010. 8:39 AM
Someone explain to me why he is shooting Great Stuff insulation onto his wheelbarrow?
neopirater says: May 13, 2010. 9:20 AM
Perhaps so it never goes completely flat?
naruto the ninja13 says: May 26, 2010. 7:30 AM
ya, we use Great Stuff foaming insulation in our 2 front riding lawn mower tires because its soft enough to move but its a solid so it wont leak out holes in the tire
Covert Koala says: May 20, 2010. 7:39 AM
 I spent a lot of time on a friend's farm growing up and they had two campfire set-ups that worked for years with no problem. The classic ring of stones with dirt in the middle, and an old metal barrel with minor holes on the sides (rust, etc). If you're looking for something fancier I recommend a movable metal fire pit, stands on legs off the ground, walmart has them for $50. A sure campfire exploder is bamboo. My friends and I learned the hard way when we put that stuff in the fire, bamboo is just wooden chambers filled with water.
Vrtigo1 says: May 19, 2010. 12:34 PM
 This isn't a very good guide.  When building a firepit, you need to use firebrick and fire safe mortar.  If you use regular stone, it'll eventually discolor and crack, and can potentially explode if the water inside it boils.
Cerasus says: May 13, 2010. 11:42 PM
What's the motivation of using glue instead of mortar? Seems like mortar is the more timetested choice.
punkhead58 says: May 19, 2010. 8:35 AM
I didn't use either. I took the cheaper and more primitive route with this project....mud.
pedaws says: May 13, 2010. 11:02 AM
rocco says: May 13, 2010. 4:06 AM
This looks cool and all... but, what's the estimate on the cost of materials? (All the hardware and big box stores sell above-ground fire-pits for around $100 these days.)
xtremeleafan says: May 12, 2010. 3:48 PM
 Very nice. But the best fire pit is made from the insides of a washing machine. Remove the tub,which has small holes all round. It's safe and cheap
tytyjul97 says: May 11, 2010. 8:36 PM
my dad and uncles made a fire pit out of my mom garden bricks.
nora says: May 12, 2010. 12:13 PM
 I have one made from the garden bricks... not tempered for fire. They're almost ALL split, discolored, or completely broken. :(
Of course, mine doesn't have a metal liner in it, either.
Tectron says: May 12, 2010. 12:03 PM
Very nice, it seems like overkill to me though, but live out in outer edge of civilization.
trailleadr says: May 10, 2010. 7:43 PM
Nice 'ible.
Is that last image suggesting filling a wheel barrow tire with expanding foam?
oakback says: May 11, 2010. 10:57 AM
 That's brilliant!  Where's the instructable for that?
trailleadr says: May 11, 2010. 8:57 PM
If I had a wheel barrow, I would make the instructable.  Looks pretty straight forward.  Fill tire with expanding foam until it blows up in both you and your spouse's face.  (kidding)
I wonder how well it would work though.  The foam has the ability to get a flat spot under a heavy load, so eventually your tire would be kinda lumpy and bumpy.
Would it really be worth it in the end?
the_Magnificent_Macak says: May 11, 2010. 2:40 PM
Hey that's cheating, DIY via thisoldhouse website?
Weissensteinburg says: May 11, 2010. 3:04 PM
 That's what I thought at first, but look at the member's name.
1-40 of 46Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
