*See final slide for a SHOPPING LIST for this project
Remove these ads by
Signing UpStep 1Learn the anatomy
MORE: Landscaping That Prevents Wildfires
To make building stone walls easier, you can use blocks made from cast concrete and molded to look like real stone (available at any home center). They're flat on the top and bottom so they stack neatly, and some interlock for added strength. Glue them together with masonry adhesive. Choose a block with angled sides, meant to form curves when butted against each other. The optimal size for a fire pit is between 36 and 44 inches inside diameter. That will create enough room for a healthy fire but still keep gatherers close enough to chat.
As an added precaution, the fire pit should be lined with a thick steel ring like the ones used for park campfires. These protect the concrete in the blocks from the heat, which can cause them to dry out and break down prematurely.
A fire pit should sit low to the ground, with walls rising no more than a foot off the ground. But for stability, the base of the wall must be buried below ground in a hole lined with gravel, providing drainage and protecting against frost heaves in winter. the gravel also creates a level base for the stones to rest on. Most concrete blocks are about 4 inches high, so if the first course and a half sit underground, and there are two and a half courses above ground with a cap on top, you'll end up with a foot-high wall—just right for resting your feet on while sitting in an outdoor chair.
MORE: Build an Adirondack Chair
MORE: Want More Wall and Less Fire? Try Building This Fire Pit's Cousin, The Sitting Wall
Thanks
We found them to be far less expensive than a custom ring and, when we did the math, were still less expensive than the least expensive rings we could find. We are building a fire pit this year and that is what we are using to line it. The exterior will have the concrete blocks but the inside ring will be all fire brick.
Not horribly dangerous, but i have been hit in the face with rock fragments before. I would just leave the bottom as dirt, plus it is easier to remove the left over coals when you are done.
Whatever you do, never put a concrete slab below a fire, they have a lot of air pockets, and per my experience, will explode and send everyone running.
Another thing that is useless is the trench filled with gravel. What's the point, if you have no drainage. It is just going to fill with water from rain and eventually it will dissolve the surrounding dirt which will cause the sides of the trench to cave in. You are better off leaving holes on the bottom of the block structure so that it drains over the ground surface.
Sand is the superior alternative.
it will drain easily too.
easy to sift out debris later.
Did you build it yourself?
Looks spammy to me.
i like the mud idea better, or clay even. ..
Of course, mine doesn't have a metal liner in it, either.
Is that last image suggesting filling a wheel barrow tire with expanding foam?
I wonder how well it would work though. The foam has the ability to get a flat spot under a heavy load, so eventually your tire would be kinda lumpy and bumpy.
Would it really be worth it in the end?
