3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build Your Own Electric Guitar!
Step 3ROUTING THE BODY AND CAVITIES
  • C:\Documents and Settings\lrshaw\My Documents\My Pictures\Music\guitars\LRS Guitar Build\IMG_0091.JPG
  • C:\Documents and Settings\lrshaw\My Documents\My Pictures\Music\guitars\LRS Guitar Build\IMG_0123.JPG
  • C:\Documents and Settings\lrshaw\My Documents\My Pictures\Music\guitars\LRS Guitar Build\IMG_0105.JPG
  • C:\Documents and Settings\lrshaw\My Documents\My Pictures\Music\guitars\SG Guitar Build\24.jpg
  • C:\Documents and Settings\lrshaw\My Documents\My Pictures\Music\guitars\SG Guitar Build\25.jpg
THE BODY This is where your guitar starts to take shape. After you have finnished your design you will need to trace it onto the wood that you are going to use for the template or body. A solid blank of tonewood that you can get from online retailers like Catalina Guitars can run anywhere in the price range of $70 to $250 depending on what wood you use. Some people will tell you that different wood will produce a different tone. While this is true in some cases like the crisper higher pitch tone of Mapel and the warmer fuller tones of Mahogany, you probably won't be able to tell the differnce between using a lower grade wood versus a higher grade more expensive wood. The only time that I would splurge and buy expinsive wood is if I was going to use a clear finish on the body and all the other parts of the guitar were going to be high end quality parts. For my project I didn't have a lot of money, much less the expensive tools to work with to produce a result that I would want to break the bank on.
MAKE YOUR OWN BODY BLANK Another neat trick to create your own body blank for $10 is to get a 3/4" thick peice of Birch Plywood that comes cut into a 4' by 2' board. Simply cut out two rectangular sections of the board that will accomodate your desing and wood glue them together. Be generous with the glue to make sure there aren't any spaces between the boards when you press the two together, clamp and stack weights on top of it so the two peices are joined firmly and let dry overnight. This gives you a a 1 1/2" thick body blank that is rigid and works great for electric guitars. You will have to go with a solid color paint when you finish it but you won't be able to tell the difference between it and the solid wood blank. Plus you'll save a good chunk of change that you can use towards good pickups and hardware. If you want to make the body a little thicker, you can get a 1/4" peice of birch and glue it between the two thicker peices. It's also a good idea to prerout any wire cavities in that 1/4" peice before you glue them together. That way you don't have to worry about drilling them later and ruining the top of your guitar body with the drill.
MAKING A TEMPLATE Once you have traced out your design to the wood you can start routing. I recomend making a template first for the body rout out of 1/4" hard board or something equivalent to that. The professionals use cnc machines to carve and rout the bodies but smaller shops will use templates made from acrylic. The hard board works just fine, but might not last as long. You can also rout the body by hand and forget the template but if you mess up there's no going back so be carefull if you do.
I cut my template with a jig saw and a fine tooth blade to make sure it kept a straight edge. Then i mounted it to the body blank using small screws in the ares that would be routed out later like the neck cavity area and where the pick ups would be. You will want to start routing a bit outside your line or the edge of the template so you can get you router bit to the depth it will need to be at for the ball bearing to follow the template. I use a 1/2"x1" bit with a ball bearing guide on top.I make several passes around the body, lowering the router 1/4" at a time for smooth easy cuts. Once you have made your pass were the bearing runs along side the template, it is much easier to rout and you will end up with a nice squared edge to the body.
ROUTING THE EDGE I like to use a 1/2" round over bit on the edge of the body to give it a nice even curve. You dont have to do this butit is good to round the edges of the body a little bit at least. It's easier to polish the body after you gloss it and you don't risk burning through on those sharp edges.
THE NECK POCKET The next step is to rout the neck pocket and body cavities. For the neck pocket I like to use a 1/4" bit and leave the scrap wood edge around the body to give the router the extra support it needs when routing the neck area. To find out how deep you will have to rout the pocket measure the total thickness of the heal of the neck. Then measure the hieght of the bridge from the bottom to the top of the groove the string will sit in on the saddle and add about 1/8" to it. That allows for the string clearence over the frets. The subtract that from the overall thickness that you came up with when you measured the heal of the neck. That will give you a pretty accurate depth that you will need to carve the pocket down to. Be very careful when you rout the neck pocket! You don't want to make it too big otherwise you end up with gaps between the neck and the body and you don't want to go too deep because it can be impossible to fix. Rout a little bit at a time, and set the neck in each time to make sure you get the proper fit. It shouldn't fit to tight and the pocket should be slightly lager than the heal of the neck because you will have paint accumulation in it which will shrink it a little.
PICKUP CAVITIES Same basic thing here. Be careful routing as you don't want to go outside you lines. The pickup rings tend to be thin along the outter edge, so if you go outside you lines it will look like there is a hole in the body of the guitar once you fit the rings on. Determine the depth that you will need for the pickups you are using. This is usually based on the length of the mounting screws. You will need enough room for them to fit. I use a 1/4" bit for this as well. You can use a template if you want but I do it free hand because any imperfections will be covered by the pickup rings.
THE CONTROL CAVITY Routing the control cavity is just as important as the neck pocket but with a couple more steps. The best thing to do is to cut out the plastic cover. Trace the pattern that you came up with for it on the plastic then cut it out with a jig saw. Use a fine tooth blade to prevent the plastic from chipping and will also yeild a smoother cut. Once this is done, take your template and reverse it, trace the patern on the back side of the body. Next set your router to a depth that is the same as the thickness of the plastic plate and rout the cavity working out to the line you drew. I do this free hand since the first cut is too shallow for a template. Be careful when you do this and test fit the plate you cut to make sure you get a goo fit. Then you will draw another line about 1/4" along the inside of the cavity you routed out, leaving extra room in areas for the screws you will use later on to secure the control plate. Rout this area out in the same way, working out to the line you drew. When you start to get close to the half way point in the wood start to think about how much wood you need to leave at the bottom. Usualy 1/4" is good but make sure you are careful! I miscalculated once and ended up going all the way through the body. Bad experience.
18 comments
Nov 11, 2011. 4:05 AMpsheminant says:
ok im looking for body designs ... i have a cnc router so pretty much can make what ever takes my fancy ... but i am currently looking for designs to make a start ... any suggestions
Feb 6, 2012. 6:09 PMcharlie.nourse says:
http://guitarz.blogspot.com/2010/01/alvarez-dana-scoop.html
Aug 30, 2009. 12:03 PMNoMadValues says:
I know there are lots of different types of woods being used for the body and necks. But I would like to know, how would Oak and White Ash hold up. I think the hard would would be good for the solid build, but would it diminish the sound quality at all?
Sep 12, 2009. 8:21 AMdragoon119 says:
No actually the harder the wood the better sound quality you get out of your guitar and the softer the wood is the worst the sound is
Mar 8, 2011. 8:18 AMmrmerino says:
i think softer woods have a mellower sound, versus harder sounds from harder woods.
Aug 22, 2010. 2:20 PMrbneville says:
I know this is a little late, but that is not necessarily true. Look up "pinecaster" on youtube. As the name suggests its a telecaster made from pine.Pine is a pretty soft wood, but the guitar still sounds great.
May 13, 2010. 12:18 PMthe-ruler-of-craziness says:
what are the dimensions of the wood for the body blank, thanks.
Jun 15, 2010. 1:40 PMJukebox Hero says:
Typically, body blanks are 22 x 14 x 1.75 inches. I've been putting most every hour of the past week into designing a guitar and I've poured over every single spec for solid body and semi acoustic guitars, so feel free to ask about any other dimensions.
Jun 16, 2010. 2:11 PMthe-ruler-of-craziness says:
Do you know the dimensions for the pickup cavities for a P-90, thanks.
Jun 16, 2010. 4:16 PMJukebox Hero says:
This should be it.
Feb 20, 2010. 1:22 PMsaimirpoda says:
Body you are really fenomenal people. With your instruction i can builld my guitare like i ever liked! Thnx men!!! Really thanks..
Jan 16, 2009. 9:17 PMPYROMANIA122 says:
Nice guide so far. Just out of curiosity would you be able to make the body and neck out of the same piece of wood and save yourself some money by not buying pre made necks?
Jan 4, 2010. 11:19 AMtomvo96 says:
yes, thats how the gibson thunderbird (bass) is made i think, it might be a glued in neck tho, but i doubt it
May 24, 2009. 8:36 PMtigerdog330 says:
dude im doin the same... imma make it mad thin, like the body is an extension of the neck.. http://www.stewmac.com/FretCalculator/ might help you out a bit with the measurements for the frets
Apr 13, 2009. 1:35 PMspiceyweasel says:
Have fun. It's a real pain in the backside.
May 21, 2010. 3:17 PMpenguin.waddle14 says:
 i agree completely. making a neck is terrible.
Jan 24, 2009. 5:50 PMads100 says:
you can find tutorials on making the neck and as long as you've got the right tools it'll be cheaper, but you've got to get the fret positioning just right which is quiet hard and will need some calculating (it can go down to 2 decimal points of a mm). You might be able to get someone or a guitar shop to do the frets for you but it depends if you want to try or not
Dec 26, 2009. 5:25 AMthrobscottle says:
Apologies if I'm wrong , but I'm guessing you used standard twist drills for the ferule holes.  Wood boring bits have a spike in the middle so a straight(er) line of holes should be achievable.  I'm not remotely musical, btw, but I'd love to make a guitar for someone!
Nov 30, 2009. 4:55 PMincubusmadman says:
so im sure my questions are all over this instructable but here is another lol when using a gibson style bridge and tailpiece, how would that all work? how high should i screw the bridge and then how should I rout the neck after that?
Apr 13, 2009. 8:15 PMStick4444 says:
One thing I noticed in this step is the use of tthe router for the entire cut. While this does save time, its hell on router bits. What I would reccomend, would be to trace the template over the blank, and bansaw or jig saw the tracing about an 1/8" larger than the pencil line, then hit up the router on the template. other than that, pretty spot on dude!
Apr 13, 2009. 1:39 PMspiceyweasel says:
Have you considered making metal templates? They take all the worry and hassle out of router work and are nifty to have when your buds say "Cool! I want one!" That leads to you making some bank, bro! I wish I'd made one before I began my Draconis project. I stick with custom made necks I get out of Vegas.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
95
Author:gbuilder
