3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build Your Own Electric Guitar!
Step 2DESIGN AND PLAN
DESIGN AND PLAN
  • C:\Documents and Settings\lrshaw\My Documents\My Pictures\Music\guitars\schematics\bridge.GIF
  • C:\Documents and Settings\lrshaw\My Documents\My Pictures\Music\guitars\building pics\foto_320_3.jpg
  • C:\Documents and Settings\lrshaw\My Documents\My Pictures\what_is_scale_length.gif
PRE-DESIGN INFO Before you can design your guitar you must know a few important rules to building guitars. The first and most important is "Know Your Scale Length".
SCALE LENGTH What is a "Scale Lenght?" The scale lenght is the lenght the string travels between the nut at the top of the fretboard and the bridge at the mid section of the base of the guitar. To determine the scale length of your guitar you would measure from the front part of the nut where it meets the fretboard to the center of the 12th fret on the neck and multiplying that by 2. Add about 3/16" to that on the low e string and taper that to about 1/16" added to the high e string. This is called compensation and that is why you see that tapered line on a bridge. Go to Stewart MacDonnaldfor more info. They also have a Fret Calculator that helps you determine your particular scale length in addition to a page dedicated to helping you out with tons of free info for your guitar building projects.The fret is the metal of nickle wire that is raised up off the fretboard. I would suggest buying a neck that has been pre made from a manufacturer that fits the design concept that you want to go with. I bought mine from Guitar Parts USA for about $70. You can pay anywhere from $50 to $300 for a neck at online retailers, but surf around and make sure you are satisfied with what you get. Guitarpartsusa will tell you to buy an expensive neck if you are building an expensive guitar, not a $70 neck. But for mine the $70 neck works just fine. Once you get the neck in and you determine what the scale length is you can lay it all out on paper. I recomend buying all your hardware, pickups and knobs before you draw your final template. This will allow to place everything where you want it and know what size holes to drill for the electronics and how big the cavites will need to be for them and the pickups.
DESIGN AND PLANNING It is best to pre-plan your design concept so you can correct any mistakes on paper before you get to the wood and can't go back. Sketch out some design concepts on paper then, once you have decided on something,lay out a couple of pieces of poster board to draw the body shape out on. You can let you imagination go wild or if you perfer stay with a more traditional design. For this particular guitar I built, I chose to go with a PRS style body design. To get the measurment correct, I pulled a picture of the guitar I was modeling it after from a guitar catalog that was taken straight on and not from the side. I then scaled up the guitar by marking out a grid on the picture and transposed it to some poster board that I had drew a larger grid on. I knew that the pickup rings measured 3 1/2" by 1 1/2" and thats what I used to scale the picture up and get the proportions correct. Another method is to project the image on a wall and trace it to the poster board if you happen to have a projector but I like to draw my template out freehand. You don't have to use this method for the design if you want to come up with you own unique style. Just make sure that take all the parts that will go on to your guitar into consideration first like the neck postition, pick ups and knobs.
PLOTTING OUT THE PEICES Once you have drawn out the shape of the body you can then locate and draw the cavaties that the pickups and electronics will go and set you bridge placement. It is good to know wher the center of the guitars boy is so you can make sure that the pickups and bridge are in good alignment with the neck pocket. I like to take a piece of poster board and trace the fretboard of the neck on it and cut it out, that way I can properly place my bridge according to my scale length.
For the neck pocket you will want to trace the heal of the neck where you want it to be placed. For this guitar I had to extend a peice of the body to attach the neck to since I was copying a PRS which uses a set in neck. I was using a bolt on and didn't have much of a neck pocket to work with.
Next, make sure you give yourself enough room in the electronic cavity to fit all the potometers and switches. Also remember to add about 1/4" of a lip that the control cover will sit on.
After your design has been properly plotted out on the poster board you can cut it out with an exacto knife. Make sure you stay as true to your lines as possible so you have a nice clean line to trace once your ready to. Then lay out the template on body blank and trace away. I like to cut the piece of poster board the same size as the body blank I am using. It makes it a lot easier to line everything up that way. Now you're ready to move on to the next step.
18 comments
Sep 11, 2010. 2:02 PMAlxman says:
What exactly is scale length and how does it help when you're building your guitar? Does it really matter when you are buying a fully built guitar neck?
Feb 5, 2012. 11:14 AMgenghistron says:
If buying a neck there are basically 2 lengths to choose from without getting into custom territory. Fender style guitars use a longer 25.5" scale length, which is one reason they tend to sound 'brighter' than a Les Paul or PRS guitar because when tuned to the same pitch the tension on the string is greater.
Most Gibsons and Les Paul style guitar generally use a 24.75" scale length, slightly shorter than fenders, which provides a slinkier feeling string and overall warmer and more mellow sounding guitar.
If you buy a finished neck and you are building the body then it does not matter what scale length neck you buy as long as you match those measurements to the body.
Mar 8, 2011. 8:11 AMmrmerino says:
scale length is basically the lenght of the string allowed to vibrate. a shorter string generally vibrates at a higher pitch, and vice-versa, a longer string will have a lower pitch. thats why bass guitars have a longer neck. even if we tune two guitars with diff scale lengths to the same tuning, they will have different timbres. shorter scale guitars are mostly for beginners or people with small hands.
the frets on a guitar neck are placed with a specific scale length in mind, the fret spacing is found by dividing the scale length by a non-repeating, non-terminating multiple of the square root of two that i cant seem to recall. unless you buy a neck without frets with the intention of doing them yourself, you need to make sure you get the scale length for the neck right.
Jan 8, 2009. 9:53 AMRichardSamrout says:
hey im going to be building a guitar soon and want to get everything right. does the scale length matter concerning pre-made necks that i can buy online?
Mar 8, 2011. 8:14 AMmrmerino says:
if you buy a pre-fretted neck and botch the scale length, the guitar will never sound right. the fret spacing isnt arbitrary, the distance between them is found by dividing the scale length by a really long decimal.
May 10, 2010. 4:17 PMkylara70 says:
yes it matters, the scale length is for how far apart the bridge is from the nut.
Dec 6, 2010. 7:16 PMacidbass says:
what kind of wood do you use?
Mar 11, 2010. 1:58 AMMrkia123456789 says:
i've never owned an electric guitar (which is obviously why im making one)
and im using my acoustic as a reference for the scale legnth
will it still work??
Jun 20, 2010. 6:07 PMmetdrummer says:
Scale length is scale length. Be it an acoustic guitar, an electric, a bass, or a cello, the concept is still the same. All it refers to is the distance between the nut and the bridge. It's used, primarily, to calculate the fret spacing. So yes, you can base the scale for your electric from the acoustic.
Apr 18, 2010. 12:56 PMlnknprkfrk13 says:
Acoustic guitars while similar to electric, are also very different. I would highly recommend that you DON'T use your acoustic as a reference and instead plan out the scale length on your own to ensure the best final results. If you are new to building electric guitars I would suggest that you find a book dedicated to creating electric guitars, as these have much more information than any instructable can hope to offer.
May 30, 2010. 5:26 PMJS-Division says:
Where did you get those plans for your guitar?
Feb 23, 2009. 3:11 PMkillerguitarman249 says:
do you have to hollow it out
Mar 12, 2010. 12:14 AMMrkia123456789 says:
no you dont have to hollow it out
Jan 8, 2010. 4:17 PMyfrue says:
can you put in three pickups
Jan 14, 2010. 7:49 PMpeach_fart says:
look at a strat or firebird.
Nov 6, 2009. 2:43 PMsirsnailswigbee says:
I'm pretty sure there's supposed to be text at the top of most of these steps, but I'm not seeing it.  Is anyone else having this problem or know a solution?  Great tutorial by the way.  I'm actually going to attempt to make my own bass guitar.  Wish me luck!
Jun 11, 2009. 5:51 AMSgt.Wiggles says:
is that a m1d1 sort of body it kinda looks like it cos i real wana make one and would luv to know what kinda measure ments to use also do u hav n e instructions on how to put a kaoss pad or proximity wah in it?
Jun 7, 2009. 5:32 PMpoopsock says:
i dont know, what is scale "lenght"? just kidding, thanks for the great instructable, im about to build mine right now
Nov 22, 2008. 3:34 AMorangetreelake says:
How do I locate the positions of the pickups? Thanks in advance.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
95
Author:gbuilder
