3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build Your Own Faucet
When I discovered I needed a new faucet for my laundry room sink I didnt want to choose between a cheap faucet that will only last a few years and an expensive one. I decided to build my own.
The faucet is made from ý copper pipe and solder fittings, two ball valves, and two 3/8 threaded fittings.
The specific pipe lengths, configuration, and installation will vary based on your needs and tastes so I leave that for each person to determine what will work best in their situation.
Step 1Tools and Materials
Tools and Materials
Tools:
Drill and drill bits
Hand saw
Tape Measure
Combination square
Pipe cutter
Mallet
Wrench
File
Steel wool
Pliers
Safety glasses
Heat resistant gloves (not pictured)
For soldering:
Wire pipe brush
Sand paper
Torch
Solder flux
Solder
Brush (for applying flux)
Lighter
Materials
Wooden blocks (One 8 in length the other 3 �)
Bolts of greater length than the width of the block
All pipe materials have � solder joints:
2 Ball valves
3 90� elbows (I bought extra in case of problems with soldering)
1 T-joint
2 3/8 threaded converters for attaching supply hoses
1 3/8 pipe thread to 3/4 hose thread adapter
Copper pipe
71 comments
1-40 of 71next »
Nov 12, 2011. 1:51 AMpnielsen1 says:
that is so awesome that is how I am going to make the facettes for my wine making room.
Sep 26, 2009. 6:20 PMSquid Tamer says:
At first I thought it was really ugly, but the more I looked the more beautiful it looked. A simple elegance, what with the slightly differently colored valves and the polished copper. If the wood was stained and lacquered it would look like a weird fusion of ugly home brew and fine woodwork/plumbing.
Jun 26, 2011. 7:11 AMpfred2 says:
That is why you wipe your sweat joints with a nasty flux rag while they're still hot, to knock off the excess solder. Sort of slobs the solder a little further on the pipes though. I think your joints look good.
Oct 22, 2009. 5:44 AMSammyFM says:
It´s so ugly ;-)
Jul 4, 2010. 3:33 PMqwertyzzz18 says:
It might be ugly to you, but i think it's awesome
Jun 26, 2011. 7:05 AMpfred2 says:
it is pretty ugly as far as faucets go these days.
Sep 16, 2010. 2:51 PMTerryCary says:
I built something very similar and ran it out through the wall so I could have warm water to the hose bib for the kids. The problem I found was that with the hose bib closed and both valves open the cold water ran back through the hot water pipes to the house. Just something to watch for, or add check valves. Nicely done, and I haven't had any troubles with the valves, just tighten up the caps once a year.
Jun 26, 2011. 7:03 AMpfred2 says:
You beat me to it but setups like this can backfeed cold water to the hot supply. Laundry faucets are pretty cheap/free so I'd never go this route myself. Other than the block of wood this setup looks OK to me though.
Aug 24, 2010. 12:51 PM2 stroke says:
i dont have a propane torch can i use my stick welder im not sure if that weld copper i does weld steel if it doesn't ill use my whole assortment of stainless steel pipes
Aug 24, 2010. 12:59 PM2 stroke says:
as a plus can you tell me how to get hot water to the garage i dont think of it as a necisity though is it possible to bild this with only a cold water tap i really need a sink in the garage hat clean paint brushes and parts with the hose outside
Aug 25, 2010. 1:45 PM2 stroke says:
di need to look for a drain too the problem is that the drain and hot water is at least about 100 feet away there is a copper pipe runnig accross where i wan the sink and the pipe leads to a garden hose spigot outside can i tap into that copper pipe with a tee fitting and run a stainless steel sink ill get at he scrap yard off that and drain the water outside into a curbside storm drain or into the floor drain in the basemet rite beside the garage underneath
Jul 27, 2010. 2:41 PMCorny76 says:
good idea, I would only replace wooden base with ceramic base (made from cut bathroom ceramic tile). Ceramic material is better water resistant than wood.
Aug 13, 2010. 10:57 AMservion says:
brilliant! with some designing and finishing uou could actually build one that could be very suitable for bathroom or kitchen sinks. If I ever get there I will post pictures.
Feb 18, 2010. 8:07 PMcaseyvitti says:
 Another thing you could do to for more support is switch to threaded galvanized pipe. You also wouldn't have to worry about your soldering skills and the pipes wouldn't have to be polished afterwards.
Jan 5, 2010. 12:36 AMstephenniall says:
Simple idea a bit of Copper pipe and some ball valves !
Im going to make one for a Booth for spraypainting in my shed
Nov 29, 2009. 10:15 PMpheenix42 says:
Fantastic!  If I ever set up a utility sink, I'm doing the plumbing like this!
Nov 9, 2009. 8:52 PMeoingrosch says:
i think this is really cool.  i like the look of it too.  awesome job.  i'll probably make my own, similar to yours.  thanks!
Oct 12, 2009. 9:19 PMSmeeon says:
wow! creative and useful, especially if you have some of this junk laying around like i do. friggen faucets are super pricey for such a simple device. when you don't need anything special for your project there is no reason buying something special in my opinion. good work!
Sep 29, 2009. 8:15 PMWeissensteinburg says:
Cool! I like the way this simplify things. In a conventional faucet, the two pipes combining is always hidden. This feels like a magic trick being revealed :D
Oct 1, 2009. 3:37 AMsaintrojo says:
Nice, thought of doing that a ways back but voted down. Should last a long time. You can get handle extensions which would move the handles away from the valve so you could box it in and neaten it up( maybe for bathroom sink). I used them on a job once( was a union pipefitter for ten yrs) and they come in various lengths.
Oct 7, 2009. 10:31 AMrquackenbush says:
Awesome Instructible!  I was lucky enough to get a sink / faucet for free.   If I hadn't, I would totally build one of these bad boys.
Soldering is a solid, traditional (if not a little messy) way to secure pipes.  If you're interested in keeping it super neat (or you don't happen to have solid pipe sweating skills like me) you could always use epoxy (I've used Copper Bond from Lowes before with no leaks).
It comes out way neater than solder.
But hey - it's a utility sink so it doesn't really matter!
Sep 26, 2009. 3:07 AMannodomini2 says:
Interesting concept, you could use compression fittings if you're not confident with soldering. If you didn't want the industrial look you could clad with wood or some form of plastic. Maybe even plaster and mold it to the shape or design you want
Oct 7, 2009. 10:34 AMrquackenbush says:
You could also use copper epoxy for the joins.  I wouldn't trust compression joints where they're going to get jostled whever someone turns a valve.
Sep 28, 2009. 1:25 PMannodomini2 says:
Mind you, it would probably need to be sealed
Sep 30, 2009. 2:29 PMPadlock says:
I imagine the plaster would crack when the hot water was turned on. The hot water wold cause the copper pipe to expand, which may or may not be significant enough to crack apart the plaster. If it didn't happen the first time, however, a stress fracture would eventually form.
Sep 30, 2009. 2:32 PMPadlock says:
Hmm. I would have stained the base, or atleast painted it. And flipped the left valve 180 degrees. But that's just me and my unnatural need for everything to be symmetrical... Looks very good.
Sep 30, 2009. 10:50 AMmr hymn says:
impressive and sorta steampunkish
Sep 25, 2009. 1:46 PMmdauld says:
Great idea. If you replaced your tee fitting with a gator bite tee from the home store, you could rotate the arm out of the way when you need to put a big object in the sink. The gator bite fittings will easily rotate on the pipes and complete the junk yard rig feel of the project.
1-40 of 71next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:pribich
