Step 3Pipe Cutting and Fitting
To solder the joints:
1. Observe safety precautions. Read labels on the solder and flux and follow the listed safety procedures. Always wear safety glasses and gloves. Work in a well ventilated area as flux and solder can produce toxic fumes. Use lead free solder to ensure no contamination of the water in the faucet or to you during assembly.
2. Wire brush the fitting and sand the pipe
3. Wipe both clean
4. Apply soldering flux to both surfaces to be soldered, be careful not to over apply. Avoid skin contact by using a small brush.
5. Fit the pieces together.
6. Heat the pipe and fitting with the torch
7. Move the torch away and apply solder. There should be enough to go all the way around the pipe. Be careful not to over apply.
8. Observe caution as the pipe will be very hot. And the solder may remain soft until it has cooled completely.
Add Comment
