Build Your Own Lab Bench Power Supply
116
Posted
Introduction: Build Your Own Lab Bench Power Supply
converting smbs to lab bench power supply. SMPS or switched mode powersupply is an electronics device that is used to convert AC to DC, AC to AC, DC to DC and DC to AC voltages. The circuit consists of transformer, rectifier, voltage regulator and a filter. The input supply is turned On and Off by MOSFETs and outputs a high efficiency, regulated voltage. The SMPS used in computers is of AC to DC type supply.
ATX connector. As you can see in the image, it is a 24-pin female connector which is used to supply DC supply to the motherboards. Various color-coded wires connect to this connector and each colored wire supplies distinct DC voltage
Step 1: Wire Color
ATX-12V
connector. Latest SMPS power supplies are accompanied by an extra 4-pin connector which supplies 12 volts to energize the central processing unit and others.
Step 2: Dc Direct Out
Step 3: Voltage Agesting
Using buck converter lm2596 to regulate dc volte for output. Voltage agesting probe is smaller so add extra wire to add potentiometer control tha output voltage
Step 4:
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    2 Comments
    Hello there!
    We're glad you want to share something with the Instructables community!
    And we’re here to help you out.
    Due to some recent changes on the site, we are no longer able to publish stand-alone videos and other forms of incomplete posts. In order to be published live on the site, Instructables must consist of the following things:
    - Multiple steps showing how you made your project
    - Written instructions in each step
    - Your own original images
    Beyond making your Instructable simply publishable, this guide (https://www.instructables.com/id/How-to-Create-a-Feature-Worthy-Instructable/) explains what is required to have your Instructables featured by our site editors. It’s very helpful, and definitely worth checking out.
    We would love to review your project again after you have made the necessary edits, and we will publish your project if it is eligible.
    If you have any questions, please feel free to ask right here or send us an email at service@instructables.com.
    Best,
    Instructables Community Manager
