Step 3Tuning the Bars
Once you are ready use a belt sander to begin removing mass in small increments. Feel free to smooth out the surfaces and add any artistic effects you may desire. Periodically, check your progress with the chromatic tuner. You can do this by holding the bar approximately at one of the nodes and striking the center. As you remove mass, the bar's frequency will decrease. If you are tuning a bass note I suggest you cut a chunk out of the bottom first. This should be done with a band saw and will make sanding a lot faster.
It is important not to sand too much too fast. If you do, the bar will heat up. The change in temperature will affect the tone produced. So when tuning the notes try to keep the temperature consistently around room temperature.
If you make a mistake and sand too much (making the note flat) don't worry it can be fixed. I found the simplest way was to trim the ends of the bar, making the length shorter. 1/8 of an inch goes a long way.
As previously discussed keep in mind temperature will have a great impact on each bars frequency. Just try to keep an "optimum operating temperature" in mind. Mine sounds great at 80 degrees Fahrenheit. But it is twenty cents sharp at 50 degrees.
Add Comment
