Step 5Building the Frame
This is a time to get creative. There are only a few rules to a marimba frame so as long as you abide by those rules; you don't need to worry about how the frame might affect the quality of sound produced by the instrument. And those rules are...
1. The bars must be supported by "marimba string".
2. The string must be supported by braces in between the marimba keys. (Next step.)
3. The frame will also hold your resonators. (if you choose to build them).
Bear those three rules and facts of a marimba frame in mind as you craft it and you should be fine. I suggest you lay out your tuned keys on a large flat surface to get the dimensions for your frame.
You should also consider how high you want the playing surface to be off the ground.
Note in the pictures the frame follows the path of the bars and the string that will later run through the instrument.
Add Comment
