Step 6Adding String Supports
I suggest aluminum rods. Use a band saw to cut the rods to an appropriate length. They should be long enough to accommodate your thickest bar. You will need to split one end of each support to so the string can lay in it. I suggest mounting each rod in a vice grip and using a hack saw to split the aluminum. Then use a screw driver and a good old fashioned hammer to open up the supports into a nice "Y" shape.
If you are recycling some old aluminum like I did, you may need to put a coat of paint on them so they all look uniform.
Finally to mount the supports into the frame you will need to drill holes into the frame at the appropriate intervals for the supports. Your drill bit should be a little small than your supports. Once done, return to the screwdriver and hammer to coerce the supports into their new home.
Notice in second picture below you can see a nylon string running though the braces. This should give you an idea of how it all fits.
Add Comment
